| Home > Help Needed / General Tech Chat > supercharger,little problem... | |||||||
![]() 281 Posts Member #: 441 Senior Member |
13th May, 2005 at 10:59:17pm
hi guys |
13th May, 2005 at 11:03:41pm
oh and the fuel pump is wired to the +side of the coil,and the earth is linked to the earth by the battery terminal in the boot. |
14th May, 2005 at 12:26:38pm
speak to vmax? Crystal Sound Audio said:
14th May, 2005 at 04:06:06pm
get an inertia switch in your fuel pump loom somewhere (wotn solve the problem, but a damn good idea none the less) i would suspect the needle valve/ float level/float vent, personally! at teh very least its somewhere to start looking. turbo 16v k-series 11.9@118.9 :)
14th May, 2005 at 09:50:26pm
alrite chaps,i found the problem! basically when wiring up the solid state pump i copied my turbo, using the +
14th May, 2005 at 10:28:00pm
Not sure what you think you;ve achieved with the re-wiring, it's basically the same?
14th May, 2005 at 11:34:24pm
no, i think the pump only worked when key was on cranking positon,drove for abit and used whatever petrol it pumped in,then cut out,starts back up and does the same thing,now its constantly running when plugged onto the fusebox on ignition,its fixed the problem so musta been that!! lol
15th May, 2005 at 03:06:32am
or your runnign the balast ignition system, and the 6-9v that they run on non-cranking, isnt man enough to run the pump. and by runnign the pump from teh fuzebox you give the pump a proper 12v. turbo 16v k-series 11.9@118.9 :)
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
15th May, 2005 at 11:39:02am
Dan, i've got a filter king filter/regulator if you need one, it's brand new and the pressure has been adjusted to 3.5psi already. |
