| Home > Help Needed / General Tech Chat > The damage, what has caused this? | |||||||
17th Jul, 2006 at 09:22:17pm
So this is the piston that was obviously buggered and had zero compression for the obvious reason
17th Jul, 2006 at 10:14:07pm
the top one looks like nitrous has done its worst , the bott looks like seisure.
17th Jul, 2006 at 10:24:35pm
On 17/07/2006 21:22:17 wil_h said:
the other 3 were in a similar condition of varying condition. Right as I’ve seen nothing like this before, and I don’t know my arse from my elbow, I’m in the perfect position to comment. The wear appears to be on the "sides" adjacent to the grudgen pin, as the piston is widest on the skirt parallel to the grudgen I would have expected the pistons to wear there first if the bore clearance is too small, unless the bore is not perfectly round. I presume you’ve checked the bore & piston clearances? Another possibility is that the clutch is not set up right and is forcing the whole rotating assembly over to the side, have you checked the end float? Isambard Kingdom Brunel said:
17th Jul, 2006 at 10:25:31pm
DET!!!! AlexF |
17th Jul, 2006 at 10:27:10pm
Looks like det has taken out the first pictured piston, second one is odd though?
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
17th Jul, 2006 at 11:09:48pm
get the bores checked properly with a bore guage, i think sommat funnys up and i have a feeling i've seen it before. I wont go into detail here. I've seen the future and tbh its Pie
17th Jul, 2006 at 11:13:44pm
http://www.hadmac.com/piston_%26liner.htm On 26th Oct, 2004 TurboDave16v said:
18th Jul, 2006 at 07:43:09am
No N2O, purely boost.
1171 Posts Member #: 107 Post Whore Sunny Sussex |
18th Jul, 2006 at 07:56:32am
how many miles had they done - thats scary
18th Jul, 2006 at 08:06:28am
They had done 3 events and a couple of RR sessions; so maybe 50 or 60 miles. But as I said, I still have the old pistons which are in perfect condition and had done 4 seasons. I don't think it's a piston problem, well it isn't. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Jul, 2006 at 09:07:33am
i would say that the top piston has got too hot from detonation ,possibly due to lower octane or extreme atmos temp we had at avon ,the first step is it get hot ,starts eating at the strength of the ring lands ,they then nip up and the piston as it rocks in the bore pushes the rings flush with the piston wall,at this point the combusting gases find a new path down past the 3 compression rings ,and out the oil control slots into the crankcase ,then this localised path gradually heats the top till its soft enough to be eaten away ,.
Edited by robert on 18th Jul, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Jul, 2006 at 11:22:43am
All that sounds like a reasonable expination
18th Jul, 2006 at 11:52:06am
Did you have a fuel filter block?
AlexF |
18th Jul, 2006 at 12:12:39pm
The fuel filter was deffinately a restriction, but this has happend on many occasions, for various reasons, and nver resulted in this before.
18th Jul, 2006 at 01:00:15pm
Cheers Peter.
18th Jul, 2006 at 01:09:23pm
Ahh. T2 running 65% T3 running 70% Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Jul, 2006 at 01:13:25pm
From the logs taken on the day (not including inlet temp unfortunately, and the O2 sensor is not working either) it only ran 217KPa which is about 17psi, so even the boost was not silly.
http://www.twin-turbo.co.uk
18th Jul, 2006 at 01:27:37pm
something else that may have some relavency is that if you were running the t2 ,instead of the t3 ,your exhaust back pressure could have been higher ,the t2 r5 turbine is 47mm big dia 35.25 small dia,whereas the t3 is58.5 and 48.5 ,so could well create less back pressure ,this creates less exhaust reversion and hence less contamination of the incoming charge with hot exhaust gases, which is deff a detonation encourager!... did you record this bp on the rr compared to the t3 bp,wil? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Jul, 2006 at 01:56:47pm
superb post there peter!
AlexF |
18th Jul, 2006 at 03:39:05pm
Great advice from Peter and Robert there.
18th Jul, 2006 at 04:07:43pm
18th Jul, 2006 at 05:19:55pm
Jim,
AlexF |
18th Jul, 2006 at 06:49:06pm
Oil cooler ? who needs an oil cooler ? lol |
19th Jul, 2006 at 07:26:46am
[quote=mini1071s,18/07/2006 12:43:49]If insufficient octane is a cause of detonation, as I understand it then pulling timing only makes it worse in fact as you are starting the combustion process even earlier.
Edited by robert on 19th Jul, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
20th Jul, 2006 at 08:29:41am
it seem to be det for me, I think the t2 is on boost earlier, this making the "T3" ignition curve too agressive, making a big difference in events. about exhaust restriction T2 have a smaller turbine wheel , but a larger A/r (0.35 vs 0.25) this meaning that it is in fact more perméable than the T3 (less restricted) .
