| Home > For Sale > Turbomini Shop - New lines added - intercooler hosing | |||||||
21st Apr, 2004 at 02:18:32pm
Right, im currently trying to source parts at better prices for all you turbo fans out there. Prices are likely to change but only downwards as i get better suppliers. Also the range will get larger as i get more requests etc. This is going to take a few days to get sorted so bear with me Edited by iain on 28th Jun, 2004. |
21st Apr, 2004 at 07:07:30pm
Hi! Is that oil feed a stainless one? Is this the one you mentioned on miniclassic? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
103 Posts Member #: 31 62horses at the wheels and counting |
21st Apr, 2004 at 07:35:43pm
What about intercooler hosing??
![]() 439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
21st Apr, 2004 at 09:33:19pm
Hi! Is that oil feed a stainless one? Is this the one you mentioned on miniclassic? i believe its braided ..... makes things a lot easier NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
21st Apr, 2004 at 09:40:16pm
Yep it is mate, hoping to get that price right down over the next couple of days though, checking out some new suppliers.
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
21st Apr, 2004 at 10:05:18pm
You can sell me a rebuilt kit for my T3 for 50,00 quit, you can add a few for postage to holland as well, remember also the other bits i am after?
21st Apr, 2004 at 10:13:46pm
Send me an email arno with what exactly your after and ill sort it out. Postage on the rebuild kit should hardy be any more at all. Ill get a couple on friday. Edited by iain on 21st Apr, 2004. |
21st Apr, 2004 at 11:05:21pm
I think what your doing is spot on Iain. It'll be like a Turbominis shop!!
22nd Apr, 2004 at 09:13:21pm
yeha this is great iain!
22nd Apr, 2004 at 09:15:26pm
Give me till tomorrow chaps atleast as im sorting out some more bits and getting the prices the best i can.
22nd Apr, 2004 at 10:27:34pm
bloody hell, might as well have got my little sister to do it Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
84 Posts Member #: 255 Advanced Member |
26th Apr, 2004 at 07:10:21pm
Hi, I'm trying to remember if the top feed hoses come with the union to the top of the turbo (i'm missing mine - have 3 threaded holes where a union should be) or a part that replaces it, as I have seen some that use a banjo bolt direct into the centre of the three holes instead of the bolt on block.
26th Apr, 2004 at 09:38:52pm
They all use a banjo, even std metro turbo. The holes either side im guessin are for a different application where a flange would bolt on.
195 Posts Member #: 26 Advanced Member Cannock |
27th Apr, 2004 at 12:42:24pm
what did they say about the oil feed pipes ? |
27th Apr, 2004 at 01:34:33pm
havent rung them yet |
28th Apr, 2004 at 09:47:42am
How about finding a supply for the T3/T2 manifold/turbo gasket, and the turbo/elbow gaskets?
28th Apr, 2004 at 10:07:25am
Ok mate, ill look into those few bits and bobs, going to see yet another hosing supplier tomorrow!
141 Posts Member #: 162 Advanced Member |
1st May, 2004 at 09:31:28am
yea i have a series 2 turbo intercooler and i am needing some hosing how much am i looking at, and ware would be the best place to fit it |
7th May, 2004 at 11:05:46pm
iain your a bad bad man!!!!
7th May, 2004 at 11:11:14pm
Iain, who are the turbo rebuild kits made by? are they garrett? On 15th May, 2009 TurboDave said:
7th May, 2004 at 11:14:00pm
Iain, not sure how far you want to take all this, but you may want to look at www.theonlinecart.com On 15th May, 2009 TurboDave said:
7th May, 2004 at 11:23:48pm
Want to take it as far as possible |
10th May, 2004 at 01:14:04am
iain im after some intercooler pipes, the size im after is 50mm blue silicon hosing and some stainles pipes can you help please |
10th May, 2004 at 08:01:58am
i can get hold of hosing no problem and also stainless pipe. Let me know what quatities of each you require and angles etc and ill get you a price.
10th May, 2004 at 07:25:01pm
right thanks for the reply. i am after some blue 50mm in diamater hosing about a meter long if possible and the same for the stainless pipe thanks again |
