| Home > Help Needed / General Tech Chat > BMW K 16v head conversion | |||||||
![]() 28 Posts Member #: 1397 Member Nr. Oxford |
2nd Dec, 2006 at 11:15:17am
elo people ive just joined hows it going,
Pictures here >>> Photobucket
2nd Dec, 2006 at 11:17:44am
Try the search fuinction top right, this will give you plenty to read.
2nd Dec, 2006 at 11:22:48am
i did a search for "bmw 16v head" and it only returned 3 topics. maybe im not searching right...
2nd Dec, 2006 at 11:25:39am
Search for "K1100" then search for "BMW".
2nd Dec, 2006 at 11:29:37am
I don't normally do this but as my dog has decided to shit on the carpet and the smell in the workshop is now unbareable I've decided to retreat to the house and surf the net.
2nd Dec, 2006 at 11:36:50am
Specialist Components (JohnK on here) can supply most of what you need including the build guide / destructions!!!!
2nd Dec, 2006 at 11:38:51am
cheers rob, reading them all now...
2nd Dec, 2006 at 12:05:05pm
yeah it does look good, but im also looking at the MRSPD kit, they do the maching the the head and the block as well. manifold is cheaper with MRSPD too.
1425 Posts Member #: 690 Post Whore Norfolk |
2nd Dec, 2006 at 02:02:17pm
hi J Whizzle - if you'd like any information which you can't find easily on here on the conversions feel free to pm me
If Carling made Mini engines
2nd Dec, 2006 at 02:11:03pm
cheers John
2nd Dec, 2006 at 03:11:10pm
having done the conversion myself, but not using anyones kit, it's lots of work, go and spend your money with John K, it will save you time and money in the long run.
2nd Dec, 2006 at 05:15:46pm
when i get round to finding a head and a budget(<<<<<<Gotta finish the rest of the car first!!) to do the conversion i will definately be buying a kit cheers jimster.
Edited by j_whizzle on 2nd Dec, 2006. Pictures here >>> Photobucket
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
2nd Dec, 2006 at 06:17:38pm
Yeah i have to agree with jimster. I am doing my own conversion and making the kit myself, i only live round the corner from John K and regularly pop round to see him. If i hadn't had done so much of my kit already i would have bought one of johns kits. As it is i may build a k100 8v 998 for my mini30 buying the bits instead of the way i have gone about doing the 1275 for my blue car. The man hours it has taken is about the same as i would have earned doing proper work instead of using the facilities we have at work!! |
2nd Dec, 2006 at 06:46:39pm
cool.
2nd Dec, 2006 at 07:38:12pm
i have used a 1275 a+ block and a K1100lt cylinder head. I have seen the 8v used on an 850 block but not the 16v. The 998 block shouldn't present any problems as being slightly shorter it all fits in. As for the work i don't think there would be any less work over a 1275 block.
2nd Dec, 2006 at 08:56:39pm
cool, so you did it as a uni project? O/T but what uni did you go to and what did you do? im loooking for next September...
2nd Dec, 2006 at 10:01:17pm
Yeah i did it as my HND Motorsport Engineering project, i went to Brooklands College in Surrey to do it.
2nd Dec, 2006 at 10:09:53pm
cool will look at brooklands cheers.
2nd Dec, 2006 at 10:11:46pm
thanks Jim and Anthony, Ant you'll have it built soon!
2nd Dec, 2006 at 10:21:03pm
cheers John, ive emailed you Pictures here >>> Photobucket
2nd Dec, 2006 at 10:28:08pm
Hi J - if you can get a 1100RS is the best starting point for a 16v or any of the 8vs as they all came with nice bumpy sticks as std. You can go some way to centering the bores by offset boring but you'll never get them all equel - 1+2 will always mirror 3+4. I don't believe this is a problem - the nice thing about the comapct BMW chamber is it keeps the valves well away from the cylinder walls - hence does not limit the gasflow into the cylinder in the same way as do heads which have the valves rammed out against the walls.
2nd Dec, 2006 at 10:31:05pm
ok cool, ill keep an eye out for heads but they are quite rare arent they? where have you sourced yours from?
2nd Dec, 2006 at 10:34:20pm
J try Motorworks or James Sherlock or good old ebay - these three seem to have the majority of them!
3rd Dec, 2006 at 10:04:06am
quick look on motorworks complete 16v head with all cam gear etc. £350, doesnt seem too bad. just gotta finish the rest of the mini first...
3rd Dec, 2006 at 11:07:18am
J, I use a 1275 A+ block and an LT head, standard valves and Cam. I've not played with cam timing yet, but I think the cams should work well with my turbo.
