Home > General Chat > Float Chamber Extension?
Metro Turbo
Member #: 437
Sunny Blackpool
Hi
Avonbar sell float chamber extension plates...is anyone using one of these with good results?
ALSO....
Are the modified needle valves they sell up to much?
My turbo is running 151 BHP and 157 lb f at 17psi....I was thinking it could be a useful addition to help my next hike in power?
Be interested to know what you lot think.
Cheers, Tim
Edited by Metro Turbo on 1st Jan, 2007.
89' Metro Turbo
157 BHP , 170 lb ft @ 15psi .... So far....
Mikeanics Rolling Road
WINNER OF RETRO CARS SHOW BEST 80's MODIFIED CAR
these have been discussed before, i think it was decided that there was no reason to have it
Metro Turbo
Member #: 437
Sunny Blackpool
I did a search, but couldn't find a thread covering it...
Tim
89' Metro Turbo
Carl
Member #: 95
liverpool-on-sea
i use one of there modified carb needles and springs. done the job for me.
Tim
i couldnt find it either
Metro Turbo
Member #: 437
Sunny Blackpool
I too currently use the high boost spring, but this is a different part of the carb. Avonba describe it as;
Modified Needle Valve:
This part allows more fuel to enter the float chamber. A must for anyone running 15psi or more. As used in the metro challenge.
https://www.speedgenie.co.uk/avonbar/Images/nvalveweb.jpg
Tim
89' Metro Turbo
Carl
Member #: 95
liverpool-on-sea
oh i see, no ive not got one of them. have you got a problem with fueling?
I've not got one either...
Metro Turbo
Member #: 437
Sunny Blackpool
No this is purely something i was looking at fitting to help the increased fuelling when I up the boost and throw more fuel down its neck...
Tim
89' Metro Turbo
Carl
Member #: 95
liverpool-on-sea
you only need to up the fueling IF it needs it and this wont be known until you carry out the future mods and you get it tuned.
I used one of the float bowl extensions....and they are a strange thing.
They extend the float bowl, with the addition of a spacer.
Now, that seems very pointless. because the jet still sits in exactly the same place. So all teh extension does, is allow a larger reservoir of fuel, to sit below the actual pickup in the bowl, so it would still run out of fuel at the same time.
So it actually seems totally pointless. I had to modify my jet to make it longer, so that it was at the bottom of the extended fuel bowl.
As for needle valve. initially I drilled a few SU ones out, but found them difficult to seal again afterwards. I ended up with a butchered weber based 3mm needle valve in mine..
Drilling holes around the body of the valve can also assist fuel flow into the float bowl, once its past the needle valve seat.
surely theyre only useful if your suffering with a poor fuel pump that cant keep up with filling the fuel bowl
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
At any given pressure, for any given orifice size, there is a particular flow rate (same principal as the bleed valves). If that flow isn't enough it doesn't mater how hard your pump tries the engine will drink it faster than the pump can fill it. In that case there are only two options, larger flow area (bigger hole) or increasing the pressure.
I personally have no idea of the limit of the standard needle valve's flow in terms of how many bannanas you can produce before the carb can no longer feed it's appitite.
Ive no idea what my AFR's where. But on a sustained high speed 4th gear run ( 1 2, 3, 4 ), perhaps as long as 1 minute when embarassing Cossies etc, I did run out of fuel at times.. I tried a larger needle valve, and upping the fuel pressure as much as I could.
All of these did help. But for that extra peace of mind, I also opted for the larger fuel bowl. ( and a big hammer to modify the bulkhead again )
Its so much funnier when you just keep pulling and pulling away, and there is nothing they can do about it *happy* Before those mods were done, I could only do short balsts up to high speeds, then starvation kicked in and had to slow sooner than I'd like.
After all the fuel system mods, I could then hold my car as long as I wanted in 4th, and never experienced any problems.
I think the large needle valve I ended up with, would probably be sufficient though. I just wanted belts and braces approach.
RogerM
Member #: 1217
Interesting .... obviously I have never been trying hard enough!!!
I will have a look at mine when I have it apart and see if I can come up with a way of getting a little more in for min spend. Shouldn't be a problem with the build for my girlfriend's car though but I like to work these things out so if I have a eureka moment I'll post up.....
Metro Turbo
Member #: 437
Sunny Blackpool
At the rolling road, with the needle filed down as much as he dared, we couldn't feed enough fuel to support 20PSI boost. I was thinking about modifing the jet and changing fuel pump...
I can see your point about the extended fuel resovoir, its not of benefit if the pump can't keep up.
Tim
89' Metro Turbo
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I had no problems at the top end with 170 bananananas on a std carb with modified needle.
Alex
AlexF
Carl
Member #: 95
liverpool-on-sea
every engine seems to be different in the fueling department for some reason
Metro Turbo
Member #: 437
Sunny Blackpool
Alex
Strange... Ah well, i can only say we tried it on the rollers, but we couldn't get any more out of it with the standard pump and modified needle, 17psi was the max.
tim
89' Metro Turbo
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Was the carb rebuilt including the choke etc?
Alex
AlexF
Metro Turbo
Member #: 437
Sunny Blackpool
Yep its had a full rebuild. RR operator said more fuel pressure and modifying the jet was the next step to get the boost up further.
Tim
89' Metro Turbo
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hmmm more fuel pressue altering the fueling - using a carb?!
I haven't found that it does that.
Alex
AlexF
i dont know what everyone else is using, but im running a cavalier sri pump
turbochargedstu
Member #: 908
gateshead
i used the float extension and modified needle valve. it sorted my fuelling issue from york out. i was running out of fuel halfway down the strip. can gun it all day now!
balls to the blower!!!
Metro Turbo
Member #: 437
Sunny Blackpool
I didn't realise people were running different pumps, the cav sri pump sounds like a good option.
Tim
89' Metro Turbo
