| Home > Technical Chat > Estimated GT1752 Compressor Map | |||||||
27th Feb, 2007 at 07:20:38pm
My best guess at what the GT1752 compresor map looks like.
![]() 6753 Posts Member #: 828 Post Whore uranus |
27th Feb, 2007 at 08:41:57pm
thats well done axel , very interesting , lets hope its near the truth.
27th Feb, 2007 at 08:58:11pm
that would be nice, lets hope so. 12% efficiency increase over my T2 in most areas. that would see some extra power I should think
28th Feb, 2007 at 07:54:09pm
Axel , which comp map did you use ?, some published "56" maps are wrong the 56mm 55 trim is in the 78% from 15lb to 20 lb at 2 pr,
28th Feb, 2007 at 08:41:10pm
Fab, I used the 2056, 56mm, 55 trim 0.53 A/R curve.
1st Mar, 2007 at 03:35:26am
sorry Axel, but def not same map as garrett one,it look more like the 2052 60 trim which I used to guess the 52mm 55 trim
1st Mar, 2007 at 08:09:15am
the deafening sound of searches for turbo by garret echoes round the turbo mini consortium .LOL Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Mar, 2007 at 08:40:42am
there seems to be two maps for the same trim fab , whether its because theres two tip heights and so one map for each height ,
1st Mar, 2007 at 09:12:40am
The two maps for the 2056, the current one on the TurboByGarrett website and the one above are very similar up to 150,000 rpm.
1st Mar, 2007 at 10:29:41am
.. that's pure headacke
1st Mar, 2007 at 11:02:55am
EDIT: Moved to GT17.... thread
Edited by Paul S on 1st Mar, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Jul, 2007 at 07:57:43am
found the correct 56mm wheel for this comp map.
19th Jul, 2007 at 08:17:18am
Hi Axel!
19th Jul, 2007 at 10:40:04am
Same it doesnt like a PR of 3!!
AlexF |
19th Jul, 2007 at 10:51:32am
Well it certinally makes the goods at 2.1.
19th Jul, 2007 at 11:27:22am
On 19th of Jul, 2007 at 08:17am fab said:
Hi Axel! as you made a very good job with the "higher map" and cause the 1752 have a 4.1 tip (so this make me think that it have a less taller and more larger map) can you "remap" from this map: I think it could give the ballpark cheers Fabrice This is my best guess based on the 92.8% scale ratio. As I've said before, this is very similar to my earlier map up to 150,000 rpm and I think it is the same compressor. Edited by Paul S on 19th Jul, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th Jul, 2007 at 01:58:30pm
On 28th of Feb, 2007 at 08:41pm Axel said: this is happy at over 3 alexf , its the one we seems to feel is the right profile just scaled diff on flow
Fab, I used the 2056, 56mm, 55 trim 0.53 A/R curve. ![]() Edited by robert on 19th Jul, 2007. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Jul, 2007 at 02:11:05pm
The only real difference is that map shows the compressor performance up to 190,000 rpm whereas the other one stops at 150,000. That does not mean that the turbo will not run faster than 150,000 and do the higher pressure ratio.
19th Jul, 2007 at 09:06:48pm
????, is that becoming a french forum? |
19th Jul, 2007 at 09:22:50pm
Axel when we are comparing these supposed squaled version of the same wheel, are the squaling is proportional (ie 92.8%) on both axis x (pressure) and y (flow) ? |
857 Posts Member #: 1778 Post Whore Northants |
19th Jul, 2007 at 09:56:23pm
Edited by the real sturgeo, axel shall be reposting what he said later on today. Edited by sturgeo on 20th Jul, 2007. |
19th Jul, 2007 at 10:18:24pm
Bugger, the problem with having two TM members in the same household is that you have to log out and log in etc else you post under each others name as above.
19th Jul, 2007 at 10:21:52pm
so on the graph 2.0 pr line is now 2.3
20th Jul, 2007 at 08:37:57am
On 19th of Jul, 2007 at 10:21pm fab said:
so on the graph 2.0 pr line is now 2.3 ( 2/ 0.8612) and 20 lb is now 21.58 ( 20/ 0.928)... well that's enough headacke for today cheers fab Apolgies fab but I got it wrong yesterday. factor the flow by 0.928 factor the PR by 0.861 I've changed the map in the above post and here it is again. Edited by Paul S on 20th Jul, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Jul, 2007 at 02:30:18pm
Hi Axel
On 26th of Feb, 2007 at 04:00pm Axel said:
If they are geometrically identical, then you can predict the performance of the GT1752 from the GT2056 map. The scale ratio is 52/56 = 0.928 or 92.8% The pressure ratio will therefore vary directly with the scale ratio. Hence a pressure ratio of 2 becomes 1.84. The air flow will vary with the square of the scale ratio - 0.862 - 86.2%. Hence an air flow of 20 lb/min becomes 17.2 does the square of squale is on the pressure or flow side, even if it doesn't matter that much ,one or other ( I tried both), if the prediction is ok (squaled 56mm wheel) this compressor seem to flow "anything" from 80 to 220 bhp and 4 to 20 psi |
