| Home > Help Needed / General Tech Chat > Intercooler fitment and front rad...gulp! | |||||||
25th Sep, 2007 at 11:55:10am
Ive just offered up my newly aquired IC and it certainly looks like it going to get enough air. Edited by matty on 25th Sep, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Sep, 2007 at 11:56:55am
Picture u/s. If its the bit I think you are referring to, chop it off.
25th Sep, 2007 at 11:57:41am
Pic working. You can chop the threaded boss off that sticks out on the inner wing side, I wouldn't go quite as far as the line you've drawn though.
193 Posts Member #: 1297 Advanced Member Sunny Stockport |
25th Sep, 2007 at 12:01:04pm
I used a metro transfer case on mine which has the extra lump on the front and cut mine in a similar manner to what you're suggesting, not quite as far as the red line though. I'll try and get a pic of it |
25th Sep, 2007 at 12:04:47pm
Ah that would be good to have a pic. :)
25th Sep, 2007 at 12:09:58pm
Pic taken from below the car, I cut the case so it was just flush with the flange on the starter
25th Sep, 2007 at 12:29:04pm
Second picture looks better Matt, I'd keep the ring intact as much as you can, the bit in question has been removed on The DON and is fine, if you are feeling rich you might consider a Brise starter to save some more room?
25th Sep, 2007 at 12:32:56pm
25th Sep, 2007 at 12:34:31pm
Ive already twisted the starter round so the solenoid is on top. you can see the bolt hole relocated. A brise starter would be nice but im determined to get it to work with this one..lol
Edited by Tom Fenton on 25th Sep, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Sep, 2007 at 12:36:16pm
Rule of thumb, i.e. if my thumb fits in the gap it's enough clearance! My whole engine bay is like that |
25th Sep, 2007 at 12:39:23pm
Looks good buddy make it happen!
25th Sep, 2007 at 01:29:04pm
I'm actually thinking i should have fitted one of these in mine rather than the bimmer one....
25th Sep, 2007 at 02:02:50pm
Matty, I thought that you were selling the turbo lump and building a twink?
In the 13's at last!.. Just |
25th Sep, 2007 at 04:54:26pm
Been there, done that, wih the EXACT same bits and gave up, keep the intercooler and use an MPi rad, that way it will fit Edited by Sprocket on 25th Sep, 2007. On 26th Oct, 2004 TurboDave16v said:
25th Sep, 2007 at 08:02:23pm
Matty, all looking good mate ..... sure you will get it in there.
25th Sep, 2007 at 08:12:20pm
TD5 methinks. On 17th Nov, 2014 Tom Fenton said:
26th Sep, 2007 at 11:02:32am
Matty i ground mine all the way back and even some of the starter motor casing if i remember rightly, no probs :) |
26th Sep, 2007 at 01:15:59pm
Yeah TurboDave's correctomondo, its a TD5 IC.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
27th Sep, 2007 at 08:08:34pm
i could be wrong, but not sure that's going to give you a great deal more than the cossie cooler. It's tall, long and thin, which will slow the air down. The cossie one is smaller but deeper so keeps air speed up.
27th Sep, 2007 at 10:40:13pm
The main problem is the throttle bodies will probably be to far forward to fit the 2wd cooler in front, thats why im trying a different one. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th Sep, 2007 at 11:45:16pm
On 25th of Sep, 2007 at 04:54pm Mini Sprocket said:
Been there, done that, wih the EXACT same bits and gave up, keep the intercooler and use an MPi rad, that way it will fit On 26th Oct, 2004 TurboDave16v said:
28th Sep, 2007 at 05:26:11am
i think it will work very well, as there will be more heat lost from the front to the back of the cores . and if its of a td5 then its more than up to the job, thinking that the td5 is well over a 2ltr engine. always looking for them bigger bunches of bannanas |
28th Sep, 2007 at 08:58:48pm
i've got a rad an intercooler the same, never did get them fitted but kept them as a project later on. if you look at jims car, they move the front end a bit further forward. you wouldnt notice and gives vitle space.
29th Sep, 2007 at 08:56:58pm
Sprocket, did you use a subframe with the original or slightly forward engine position of the later cars?
29th Sep, 2007 at 09:53:34pm
MPi rad fits because ou can get it to sit along side the starter motor, the TD5 intercooler will fit infront of the engine inbetween the front panel, this will work.
It also reduces the drive angle of the hardy spicers, which is a good thing.
