| Home > General Chat > VERY O/T any one know a lot about transformers and inductors ? | |||||||
![]() 6753 Posts Member #: 828 Post Whore uranus |
28th Sep, 2007 at 06:42:32pm
as per title ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Sep, 2007 at 06:54:10pm
a bit,
28th Sep, 2007 at 06:57:25pm
wil !!! is this true ?? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
28th Sep, 2007 at 07:22:41pm
May be able to help too |
28th Sep, 2007 at 07:29:11pm
Is that something like a flux capacitor?
28th Sep, 2007 at 07:39:37pm
I suspect that I don't know the answer, but you could always ask. I wouldn't profess to know a lot but I know people who do. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
28th Sep, 2007 at 07:48:29pm
On 28th of Sep, 2007 at 07:29pm Axel said: exacto axel
Is that something like a flux capacitor? Are you trying to get that lathe working then Robert? ok lads heres the sit .... i need to transform 230 volts single ph to 415 3 ph . i can make a static converter ,run an idler motor off this to smooth the volts and so on ,but im still stuck with 230 v. so off to the magix scrap yard ,and iv found an intersting machine . in it i found a big 15 inch high 3 ph transformer ,220 to 455 volts ,and an inductof half the size .32 mh rating , what i want to knmow is ,if i run the 455 v through the inductor ,what will it do to a) the voltage b) the wave form , im guessing itll reduce the cvolts and smooth the form ,but ,,, is this true !! and if so by how much ? ( god,,, watching pimp my ride ,that westwood needs duct taping !!) so thats the prob ,alll help much appreciated regards robert . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Sep, 2007 at 08:00:12pm
There's no easy way of getting 3ph from a 1ph supply without some electronics gizmo. When you say 3ph transformer do you mean invertor? I have a lathe with a 3ph 415 motor, I bought a 1ph 240 to 3ph 240 invertor for about 200 quid and then rewired the motor from delta to star so it would run on 240.
Edited by neilj1678 on 28th Sep, 2007. |
28th Sep, 2007 at 08:02:33pm
Edited by Paul S on 28th Sep, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
28th Sep, 2007 at 08:14:13pm
On 28th of Sep, 2007 at 08:00pm neilj1678 said:
There's no easy way of getting 3ph from a 1ph supply without some electronics gizmo. When you say 3ph transformer do you mean invertor? I have a lathe with a 3ph 415 motor, I bought a 1ph 240 to 3ph 240 invertor for about 200 quid and then rewired the motor from delta to star so it would run on 240. I've seen 3ph motors running on 1ph by using a suitable sized capacitor between two of the phases but they run REALLY badly! no neil i mean transformer , , to transform 230 to 415volts . i deff dont want to get into a rotary phase converter versus digital inverter (vfd ) . argument !!! lol im happy with my 1 to 3 ph solution ,just want to know bout the inductor effect .
28th Sep, 2007 at 08:16:54pm
28th Sep, 2007 at 08:21:26pm
Got that the wrong way round... was originally star and I had to rewire it as delta. Invertor wiring is pretty simple, should look something like this:
28th Sep, 2007 at 08:24:24pm
IIRC the peak to peak voltages for 230v single phase & 415v 3 phase are exactly the same (the 230v & 415v purely relate to the rms values) you'll struggle to get three phase from a single phase supply, as it involves phase shifting which is a PITA, it's not impossible, but you're better off changing the motor to a single phase one.
28th Sep, 2007 at 08:28:08pm
Ahh, I think I get you, you're converting 1ph 230 to 3ph 230 with your rotary converter and then using the Tx to go from 230 3ph to 415 3ph?
28th Sep, 2007 at 08:32:59pm
yes neil thats right its a 3 ph inductor , .31 mH which is mega henrys , i think ,and total pk current of 200 amps ,,,,er ,think thats big enough haha . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Sep, 2007 at 08:35:02pm
thanks for that axel , but thats not the route i chose to go down . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Sep, 2007 at 08:45:59pm
Millihenrys if it's a small h, if it was mega I think it would be the size of a house! It won't affect the voltage or the 50hz waveform at all, but it will give you a 90 degree (in theory) phase shift between the voltage and the current (pretty irrelevent really) and it will tend to filter out some higher frequency noise.
28th Sep, 2007 at 09:02:52pm
yep your right neil small h ! from what iv been reading it appears that it should act as a) a waveform smoother
28th Sep, 2007 at 09:27:23pm
Nearly right, 1 Henrie = 1000 milliHenrie.
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
28th Sep, 2007 at 09:42:46pm
Anythink to do with autobots and decepticons? Back once again like a renegade master |
28th Sep, 2007 at 09:55:48pm
On 28th of Sep, 2007 at 09:27pm neilj1678 said:
Nearly right, 1 Henrie = 1000 milliHenrie. So Xl=2*3.14*50*0.00031=0.097 ohms. If your motor pulled say 8 amps, you'd get a voltage drop across the inductor of 8*0.097 = 0.78v. In reality it would be a bit more than this because there would also be a bit of internal resistance in the inductor, probably a couple of volts drop at max. excellent neil , thats really helpfull . so my 455v tranny is not going to work on a 415 motor really is it ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Sep, 2007 at 10:27:30pm
It's a bit high but within 10% (just) which is generally considered acceptable. You might find your motor is stamped up as 415/440 anyway in which case it's only 15v high. Also, can you rig up your invertor to chuck out a little less than 220 so you will get less than 455 out of the Tx? |
29th Sep, 2007 at 12:06:31am
415v to 240v transformers only use two of the three phases. you cannot simply use the secondary as the primary and generate three phases, you will however get 415v.
Edited by Sprocket on 29th Sep, 2007. On 26th Oct, 2004 TurboDave16v said:
29th Sep, 2007 at 12:21:47am
I was assuming it was a step up Tx as the post said 220 to 455 but you've got a good point Mr Sprocket.
Edited by neilj1678 on 29th Sep, 2007. |
29th Sep, 2007 at 12:28:35am
One thing to bear in mind is that your single phase supply may not be able to supply the required current if the 3 phase motor is a bit of a monster. |
