| Home > Technical Chat > are we mesuring boost correctly? | |||||||
30th Nov, 2007 at 09:12:31am
i've been having a little trouble with air/fuel ratio and boost control/pressure and thought about boost pressure in general.
30th Nov, 2007 at 09:33:45am
Velocity pressure only really comes into the equation where you have large changes of cross sectional area.
Edited by Paul S on 30th Nov, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Dec, 2007 at 08:26:19pm
Right guys, after spending many hours on this forum and researching as much as I can for my Turbo 998 project I think i am at last beginning to understand the ins and outs of some of the problems and misconceptions.
Edited by danboy on 22nd Dec, 2007. |
22nd Dec, 2007 at 08:54:43pm
On 30th of Nov, 2007 at 09:12am Turbo Shed said:
some people seem to be getting good power from say 10psi and others can run more boost but get less from it. is this due to a better flowing engine using more velocity pressure and thus need less static pressure? I've still to get the text books out to quantify the velocity energy, but i don't think it is significant as Dave says. However after reading the original post again, the big thing missing is temperature. 10 psi and no intercooler is going to give far less power than 10 psi and an efficient intercooler properly installed. Also 10 psi from a GT1752 will give more power than 10 psi from a T3, simply because of the efficiency of the compressor and the lower air temperature as a result. Edited by Paul S on 22nd Dec, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Dec, 2007 at 09:09:56pm
Paul, you are dead right in what you say above regarding Boost vs quoted power. In fact I think it' totally pointless to quote x bhp @ y boost as a change in intercooler efficiency will give more power for less boost.
22nd Dec, 2007 at 09:13:49pm
At the risk of being shot down, I also think that if you get an intercooler with 100% efficiency you could run 10.5:1 compression ratio on 15 psi!
22nd Dec, 2007 at 09:27:05pm
Also:
22nd Dec, 2007 at 09:32:32pm
. Edited by danboy on 22nd Dec, 2007. |
22nd Dec, 2007 at 09:32:36pm
22nd Dec, 2007 at 09:32:42pm
22nd Dec, 2007 at 09:32:58pm
22nd Dec, 2007 at 09:34:42pm
22nd Dec, 2007 at 09:39:57pm
Pentuple post! Must be a record?! LOL.
22nd Dec, 2007 at 09:41:12pm
have you got the shakes Dave??.lol |
22nd Dec, 2007 at 09:48:16pm
On 22nd of Dec, 2007 at 09:41pm fastcarl said:
have you got the shakes Dave??.lol ROFL |
22nd Dec, 2007 at 09:53:26pm
On 22nd of Dec, 2007 at 08:54pm Paul S said: On 30th of Nov, 2007 at 09:12am Turbo Shed said:
some people seem to be getting good power from say 10psi and others can run more boost but get less from it. is this due to a better flowing engine using more velocity pressure and thus need less static pressure? No it's not, this is totally incorrect. It's due to the temperature change of the inlet charge. In terms of turbo, head & exhaust there is no such thing as "velocity pressure" being an Additional factor. Gas Law (P1,V1)/T1=(P2,V2)/T2. No mention of "velocity" I am not being patronising but i have to explain things simply so i can get it clear in my head. If you slow down the process of the induction cycle it will go as follows. 1) Pressure builds against a closed inlet valve. P high V low 2) valve opens and gas begins to flow P low V high 3) velocity of the gas increases to fill the void. 4)Inlet closes and the cycle repeats Apart from the corresponding drop in temp of the inlet gas there is no additional energy introduced into the system. There cannot be an additional "velocity pressure" over and above the measured boost pressure. The increase in power for a given boost pressure can only be due to lower inlet temperature and or less restriction to flow. regards Dave |
22nd Dec, 2007 at 09:55:08pm
Fookin hell I have only just hit the button.
22nd Dec, 2007 at 10:02:21pm
the point to this is that if fuel pressure is to rise with boost pressure, which boost pressure should be used? The fuel pressure inside the carb is determined by the tapping that goes through the carb flange that connects the float chamber to the plenum, are you thinking about that? Or are you thinking about the fuel pressure coming out of the regulator? website:- http://www.terryhunt.co.uk
22nd Dec, 2007 at 10:02:53pm
Nice innovation this automatic posting !!!
22nd Dec, 2007 at 10:09:31pm
On 22nd of Dec, 2007 at 09:55pm danboy said:
Fookin hell I have only just hit the button. But it' nice to know you are watching Dave yes Dave, but you hit it 5 times,lol |
22nd Dec, 2007 at 10:21:21pm
22nd Dec, 2007 at 10:22:51pm
What you have to remember is that boost pressure all starts out as velocity energy in the compressor wheel, then converts to pressure energy as it slows down.
22nd Dec, 2007 at 10:24:13pm
some people seem to be getting good power from say 10psi and others can run more boost but get less from it. is this due to a better flowing engine using more velocity pressure and thus need less static pressure? No it's not, this is totally incorrect. It's due to the temperature change of the inlet charge. In terms of turbo, head & exhaust there is no such thing as "velocity pressure" being an Additional factor. Gas Law (P1,V1)/T1=(P2,V2)/T2. No mention of "velocity" I am not being patronising but i have to explain things simply so i can get it clear in my head. If you slow down the process of the induction cycle it will go as follows. 1) Pressure builds against a closed inlet valve. P high V low 2) valve opens and gas begins to flow P low V high 3) velocity of the gas increases to fill the void. 4)Inlet closes and the cycle repeats Apart from the corresponding drop in temp of the inlet gas there is no additional energy introduced into the system. There cannot be an additional "velocity pressure" over and above the measured boost pressure. The increase in power for a given boost pressure can only be due to lower inlet temperature and or less restriction to flow. regards Dave I didn't say that did I? Or have I been drinking as well! Edited by Paul S on 22nd Dec, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Dec, 2007 at 10:24:18pm
turbo tel, are you as pissed as I am about to become?
22nd Dec, 2007 at 10:51:22pm
On 22nd of Dec, 2007 at 10:24pm danboy said:
turbo tel, are you as pissed as I am about to become? Dave Unfortunately no! I pulled standby this weekend so have to stay sober.. but wait till 5pm on Monday.... EDIT.. consoling myself with a shandy.. Edited by Turbo Tel on 22nd Dec, 2007. website:- http://www.terryhunt.co.uk
