| Home > For Sale > SH Eng mechanical clutch actutation | |||||||
1425 Posts Member #: 690 Post Whore Norfolk |
6th Jan, 2008 at 10:51:23am
No longer required - very very good bit of kit, used by Mig boys a lot, direct from pedal clutch actuation (pre verto) - nice ratio, not too heavy with a grey
If Carling made Mini engines
6th Jan, 2008 at 11:26:55am
Actually quite interested in this. Have you sent the cam yet? On 13th Jul, 2012 Ben H said:
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
6th Jan, 2008 at 11:35:24am
i think i might have this john! bloomin clutch on the rally car is forever playing up
David. |
6th Jan, 2008 at 11:49:35am
I'll take it if nobody else has. :) |
6th Jan, 2008 at 11:55:41am
***sold** to mini93
6th Jan, 2008 at 01:36:31pm
BOLLOCKS!!
6th Jan, 2008 at 02:30:01pm
I always miss everything i want
6th Jan, 2008 at 03:25:06pm
sorry guys :p i rearly get there 1st always miss bargins but not today! David. |
6th Jan, 2008 at 05:34:32pm
out of curosity, can anyone explain to me how this works, im feeling rather dim today, a pic of it on the car would be tremendous!
6th Jan, 2008 at 09:09:55pm
I don't think that is a silly question at all. Either that or I am dim too? http://www.twin-turbo.co.uk
6th Jan, 2008 at 09:25:34pm
http://www.shengineering.co.uk/pcmclutchkit.aspx
Edited by cossierick on 6th Jan, 2008. |
1300 Posts Member #: 829 Post Whore essex |
6th Jan, 2008 at 10:33:51pm
I think it uses the metro cable and arm on the gearbox 1293 Turbo mini
6th Jan, 2008 at 10:39:32pm
I think you have to drill through your bulkhead, and then you have a steel rod going from the pedal to the linkage.
6th Jan, 2008 at 11:29:19pm
john said a hole has to be drilled in the bulkhead and drill the pedal for the clevis pin
David. |
6th Jan, 2008 at 11:47:56pm
I keep looking at it ? are you using the std arm on the housing 1293 Turbo mini
6th Jan, 2008 at 11:59:01pm
id imagin thats how it works, the kit looks like it has conection that lock to the arm (on the gold part, imagin that as the female point and the arm is male) David. |
7th Jan, 2008 at 02:18:02am
On 6th of Jan, 2008 at 10:39pm Nic said:
Im wondering if the mechanism does, or can be adapted to make the pedal feel much lighter CLutch cover dictates pressure. You can play with leverage here there and everywhere. But at the end of the day. The clutch cover is fixed, and still requires xxx lbs to release.. The only way to reduce effort at the pedal, is to increase the stroke of the pedal. 9.85 @ 145mph
7th Jan, 2008 at 07:40:21am
Sorry guys busy doing mini stuff
7th Jan, 2008 at 09:30:03am
I felt this when John had it fitted in his gold mini, on a grey iirc.... felt nice and light and controlable.
7th Jan, 2008 at 12:47:17pm
I guess that this relies on the engine being solid mounted then? Otherwise it could be a pain. http://www.twin-turbo.co.uk
![]() 568 Posts Member #: 1200 Post Whore Bristol |
7th Jan, 2008 at 09:31:16pm
considering the price of a new master and slave cylinder plus braided pipes it doesnt work out too bad considering the amount of slaves etc ive had to replace over the years! will deffo get one for the maguire
Edited by pickmeup on 7th Jan, 2008. |
17th Apr, 2009 at 10:17:12am
Any one got a picture of one of these fitted? Isambard Kingdom Brunel said:
![]() 2102 Posts Member #: 432 Post Whore Swindon |
17th Apr, 2009 at 10:47:19am
how heavy would these feel on a standard clutch set up? |
17th Apr, 2009 at 10:54:18am
there is one fitted to the sheepspeed miglia, I'll get some photo's for you. It feels about the same weight on the pedal as a hydrolic system On 15th May, 2009 TurboDave said:
17th Apr, 2009 at 11:37:33am
Nice one Jim, if you could also get a picture showing how high up the pedal it bolts on that would be fantastic, as I'm trying to work out what I'm doing with my pedal box. Isambard Kingdom Brunel said:
