| Home > Help Needed / General Tech Chat > What have I done wrong here? | |||||||
13th Apr, 2008 at 09:00:13pm
In the 13's at last!.. Just |
13th Apr, 2008 at 09:28:14pm
Did you pull the CV up using the nut and a big flat washer, but leaving the tapered split washer out? On 26th Oct, 2004 TurboDave16v said:
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
13th Apr, 2008 at 09:49:44pm
Is the taper washer on one side warn / deformed due to wear? Is one of th bearing races not seated (fully home)?
13th Apr, 2008 at 09:50:43pm
Mine has only got the tapered split washers on both sides. There has never been any flat washers.
13th Apr, 2008 at 09:53:14pm
On 13th Apr, 2008 shane said:
Is the taper washer on one side warn / deformed due to wear? Is one of th bearing races not seated (fully home)? Shane Tapered washers both were fine from memory, I'll check though. I built up the hubs together and I'm sure the races were properly seated. Again I'll check this before ruling it out. In the 13's at last!.. Just |
13th Apr, 2008 at 09:56:01pm
I had wear on one a few years ago, the castle nut face would sit so far into the hub the split pin would lock on the castle nut.
13th Apr, 2008 at 10:05:42pm
is there to much friction not causing it to be tightend up fully? Drives
13th Apr, 2008 at 10:06:13pm
I've got a new spare one. I'll compare the two. Cheers Shane. In the 13's at last!.. Just |
13th Apr, 2008 at 10:07:48pm
Looking at the pics. Would that tapered washer not sit further back in comparison to the wheel/hub, if it was worn?
13th Apr, 2008 at 10:10:03pm
look at how much thread you have on each side, one sits alot futher back (the one your having problems with) than the other Drives
13th Apr, 2008 at 10:17:35pm
I think that the one that is further back is the one at fault. The split pin barely catches the castle nut.
13th Apr, 2008 at 10:35:26pm
On 13th Apr, 2008 theoneeyedlizard said:
I think that the one that is further back is the one at fault. The split pin barely catches the castle nut. I think this is your problem, the wear is usually on the mating face with the castle nut, swap over (from side to side) and see if the problem swaps sides? Or fit a new one lol (less work) Shane. |
13th Apr, 2008 at 10:40:45pm
I'll try it, but there's more than 2-3mm of extra thread
13th Apr, 2008 at 10:46:59pm
On 13th Apr, 2008 Sprocket said:
Did you pull the CV up using the nut and a big flat washer, but leaving the tapered split washer out? On 13th Apr, 2008 theoneeyedlizard said:
Mine has only got the tapered split washers on both sides. There has never been any flat washers. Sometimes it pays to go back to basics and RTFM
13th Apr, 2008 at 10:49:00pm
Have you also knockeed over the lock tabs on the ball joints?
13th Apr, 2008 at 10:55:31pm
Yes the lock tabs are just on the other side.
14th Apr, 2008 at 08:38:23am
Are the nuts the same length? They look different to me. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th Apr, 2008 at 08:39:40am
I agree with paul, the nuts doo look diferent On 28th Aug, 2011 Kean said:
14th Apr, 2008 at 08:49:44am
I think your nuts being uneven is the problem! PMSL https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th Apr, 2008 at 09:13:30am
I think you're onto something guys! lol! It could be the difference in the angle of the photo, but I agree my nuts do look different. I'll check it tonight.
14th Apr, 2008 at 09:17:09am
On 14th Apr, 2008 theoneeyedlizard said:
I agree my nuts do look different. I'll check it tonight. Make sure you cough! Lol Edited by matty on 14th Apr, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th Apr, 2008 at 09:19:09am
Ah, that's what I've been doing wrong!
14th Apr, 2008 at 09:43:24am
I have come across different thickness nuts on my car giving exactly the same problem.
14th Apr, 2008 at 09:48:05am
I hope that this is the problem. Easy fix!
928 Posts Member #: 65 Post Whore South Yorkshire |
14th Apr, 2008 at 10:22:59am
I'd put the tie bar to bottom arm bolt in the other way up as well, that way if the nut comes loose and falls off the bolt won't fall out. |
