| Home > General Chat > oil cooler or not? | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
18th Aug, 2004 at 07:45:06pm
not sure if i should i use the oil cooler? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
18th Aug, 2004 at 08:44:57pm
18th Aug, 2004 at 09:04:03pm
its going to be my daily car, mainly dual carriageway driving, i'm only going to be running low boost if that makes any difference.
Edited by adam1330 on 18th Aug, 2004. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
18th Aug, 2004 at 10:01:45pm
the thing is to fit an gauge to measure the temps, this is the only way you'll know if you need one or not. Best 1/4 mile 13.2 seconds @116 mph
18th Aug, 2004 at 10:09:05pm
at what sort of temps should i be needing to fit a cooler at then? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
18th Aug, 2004 at 10:14:32pm
if your oil goes over 120 degrees C AlexF |
18th Aug, 2004 at 10:41:11pm
I fitted an oil temp gauge this year to see if i needed a cooler. I did a 4 hour trip down the motorway a few weeks ago and only saw 110deg on the gauge, with general driving it rarely goes over 80deg, so i'm not bothering fitting an oil cooler.
19th Aug, 2004 at 12:30:12am
Yep same here Phil, doing 70mph (4000rpm) i get 110deg and then with a little bit of town driving it goes back down to about 80-85deg. Would probably see 120+deg on a track day but prefer running oil at these temps as it burns off various contaminants. I think another point is the oil you use and what temps it breaks down at?? -MINI CLUBMAN 1380 TURBO- |
19th Aug, 2004 at 06:50:10am
yep good idea to run a temp gauge first as cold oil is a crap oil. turbo running lower c/r will have cooler under crown temps when of boost then n/a engines so most of the time the oil wont get as hot but when blasted the under crown temps will rise higher than n/a but bear in mind oil takes ages to get hot so you may not need one, if you do fit a cooler fit a thermo stat as well at least the oil will reach at least 80 deg.
19th Aug, 2004 at 09:35:57am
i took miniwilliams' advice on his website and fitted one because i have a large sump guard. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
19th Aug, 2004 at 09:50:32am
where do you guys record the oil tempreture from? the sump? On 15th May, 2009 TurboDave said:
19th Aug, 2004 at 11:44:31am
Yeah, would be interested to know where you guys have fitted your senders for oil temp gauges as well. I was considering drilling into the speedo housing or somewhere like that out of the way so that I don't risk knackering gearbox casing...
19th Aug, 2004 at 06:49:23pm
Mines in the sump, speedo end.
19th Aug, 2004 at 07:23:21pm
Yes I can't remember who it was that told me now, but I can remember them saying how there mini ran a LOT hotter with the new sump guard fitted.
19th Aug, 2004 at 08:42:05pm
yep doesnt realy matter were you take the oil temp from as it wont cool down much from sump to filetr housing proberly about .5 deg c.
141 Posts Member #: 2408 Advanced Member surrey / ewell area. |
17th Jun, 2008 at 04:40:14pm
Im gonna fit my temp guage after oil cooler and b4 filter housing as that will give me a post cooled temp as oil goes back into sump. i figure if i do it b4 oil cooler it will tell me the temp after going around engine but i wanna know the sump temp so that is the closest i can get without using sump bolt or other methods. |
17th Jun, 2008 at 05:49:59pm
i recently bought an oil cooler for my mini, im still not 100% sure how useful it will be or if ill need it, im contomplating having it out of the way so it will still have an effect but not a huge one. i want to run 15Psi, +40 over bore, benross head, mega pistons ballanced bottom end ect Drives
17th Jun, 2008 at 05:50:15pm
Holy thread resurection batman !!!!!!! |
17th Jun, 2008 at 06:16:32pm
surely the best place to measure the oil temp is just before it enters the block after the filter, as this will be pretty much whats the engines getting?
17th Jun, 2008 at 06:58:24pm
I always try to maintane 90 deg c or 200 deg F oil temp in my engines I find this burns off all the crap from blow-by but keeps piston and bearings happey and nearly always makes more power dont forget duck tape is a great way of controling oil temp fit a cooler and tape it as you need to reduce or increes air flow,
On 17th Feb, 2009 Rob H said:
1391 Posts Member #: 1686 Post Whore Oxford |
17th Jun, 2008 at 08:44:03pm
to be honest, there not especially espensive i think it would be worth fitting one anyway.
OMG Robert that's a big one |
18th Jun, 2008 at 01:58:22am
not needed in your case IMHO
Edited by BENROSS on 18th Jun, 2008.
18th Jun, 2008 at 02:33:35am
Last year I ran an oil cooler with a 90 degree stat, Even when running in 95 degree ambient temps and thrashing it, the regulator hardly opened, and the oil cooler never really got hot to the touch. In the end I removed it and installed an aux rad instead, seemed to me that using that space to keep the water temps down was more important...
Edited by Turbo Tel on 18th Jun, 2008. website:- http://www.terryhunt.co.uk
18th Jun, 2008 at 07:11:42am
4 years on and im still oil cooler-less. -MINI CLUBMAN 1380 TURBO- |
19th Dec, 2014 at 08:42:39am
I know resurrecting a old thread
