| Home > Introduce Yourself > my clubby turbo | |||||||
286 Posts Member #: 4008 Senior Member near cardiff np12 |
1st Oct, 2008 at 08:15:14pm
my name is rhos from s.wales blackwood
1st Oct, 2008 at 08:17:39pm
Love it!!
1st Oct, 2008 at 08:21:24pm
I've seen pics of that car on here before, perhapse in the forsale section. It's great, russet brown minis are the best! On 7th Nov, 2008 Nic said:
1st Oct, 2008 at 09:29:26pm
welcome
1st Oct, 2008 at 09:32:06pm
Cool! My first car was a Russet Brown Mini!
On 19th Jan, 2010 wil_h said:
1st Oct, 2008 at 09:51:39pm
that looks real clean underneath, proper sleeper motor as well.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
1st Oct, 2008 at 10:56:11pm
Tidy car. :) |
2nd Oct, 2008 at 09:12:43am
This was for sale on here a while ago. My friend was going to have a look but it was in Wales I think.
In the 13's at last!.. Just |
2nd Oct, 2008 at 10:07:22am
The shock value of the standard look cant be beat. Own the day
2nd Oct, 2008 at 10:23:56am
begs for some cake though! |
2nd Oct, 2008 at 10:32:58am
and some more boost apparently it was only running 4psi If something is worth doing, it's worth doing half of. |
2nd Oct, 2008 at 10:44:31am
On 2nd Oct, 2008 minimadmotorman said: No ECU, no bleed valveand some more boost apparently it was only running 4psi
Own the day
2nd Oct, 2008 at 11:09:26am
hi cheers all
2nd Oct, 2008 at 11:13:52am
As miniminor63 said, an intercooler would be the first mod. Then fit a bleed valve in the actuator line to allow you to increase boost. It's probably worth finding out what CR you a running before you increase boost though On 12th Nov, 2009 Paul S said:
Gary's description is best |
2nd Oct, 2008 at 11:18:41am
With the straight cut box and an intercooler you could run a decent amount of boost through it! |
2nd Oct, 2008 at 11:52:25am
a friendly RR would be my first start before tweaking too much. 8-9psi on a standard engine in good condition is more than achievable |
2nd Oct, 2008 at 12:08:34pm
what's cr
2nd Oct, 2008 at 12:13:18pm
Use the search button mate its all here!! |
2nd Oct, 2008 at 12:15:43pm
Just to get you started....
2nd Oct, 2008 at 12:18:14pm
cheers for that the engine was a metro turbo rebored
2nd Oct, 2008 at 12:39:42pm
If your running at standard compression ratio when on boost (say 4psi) your dynamic compression ratio will be around 14:1 may be a little higher say 14.5:1.
Own the day
2nd Oct, 2008 at 12:48:43pm
what head gasket is best to get
2nd Oct, 2008 at 12:57:30pm
For around £13,000 about 270 break with a 16v head lol. then put a 50 shot nitrous kit on the back with a progession controler and give me a call before you take it out that I would love to see.
Edited by Mr Joshua on 2nd Oct, 2008. Own the day
2nd Oct, 2008 at 12:59:51pm
trust me press the search button type in what you want to know and you will more than likely get an answer. i was as green as a five day old cabbage when i came to this forum. i'm still green but not half as bad. If something is worth doing, it's worth doing half of. |
2nd Oct, 2008 at 01:36:13pm
whats a cimetic?
