| Home > Technical Chat > Piston Design | |||||||
29th Oct, 2008 at 09:11:42pm
Ok guys taughts on this,
On 17th Feb, 2009 Rob H said:
30th Oct, 2008 at 07:13:13am
I would say so yes, sharp edges and quick/even distribution rarely goes together.... |
30th Oct, 2008 at 08:25:18am
is this for a 5 port head? On 28th Aug, 2011 Kean said:
30th Oct, 2008 at 08:50:14am
I did mine the classic "D" shape (a "D" on its side but with a large flat bottom).
30th Oct, 2008 at 09:46:40am
I recognise that large flat bottom ! |
30th Oct, 2008 at 11:05:56am
Sore lads I ment to say its for the bmw 16v racer Edited by PaulH on 30th Oct, 2008. On 17th Feb, 2009 Rob H said:
30th Oct, 2008 at 06:19:08pm
I dont see any OEM pistons like that so I would say there is nothing in it other than expensive machining? On 26th Oct, 2004 TurboDave16v said:
30th Oct, 2008 at 06:31:51pm
what about making them more like this: http://www.minimania.com/web/item/RE-A1117...%20PISTON%20SET |
30th Oct, 2008 at 06:34:53pm
have you got any pictures of this?
On 30th Oct, 2008 Rod S said:
I did mine the classic "D" shape (a "D" on its side but with a large flat bottom). I retained the flat top around the outside because (after everything I read) it seems to be important, along with deck height, for getting the "squich" right. Assuming it's a standard head of course. Whether I'm right or not remains to be seen.... do you need to do cut outs for your valves still or has the design you have done clear it all? i think i have seen some cossie pistions like that before. Drives
30th Oct, 2008 at 06:35:03pm
do you mean radiusing it Sprocket I think you are right I have been on the Omega, AE and wiseco as well as a few other ones and the all show pistons with my current design but none with my proposed design On 17th Feb, 2009 Rob H said:
30th Oct, 2008 at 06:37:37pm
I will be doing the dry build during the next two weeks Paul and I check clearence but I suspect I will still need cut outs On 17th Feb, 2009 Rob H said:
30th Oct, 2008 at 06:40:49pm
BTW here are my wiseco pistons for my NA 16valver: |
30th Oct, 2008 at 06:42:52pm
On 30th Oct, 2008 Paul R said:
have you got any pictures of this? On 30th Oct, 2008 Rod S said:
I did mine the classic "D" shape (a "D" on its side but with a large flat bottom). I retained the flat top around the outside because (after everything I read) it seems to be important, along with deck height, for getting the "squich" right. Assuming it's a standard head of course. Whether I'm right or not remains to be seen.... do you need to do cut outs for your valves still or has the design you have done clear it all? i think i have seen some cossie pistions like that before. Here, (not great photos)... http://www.turbominis.co.uk/forums/index.php?p=vt&tid=246578 BUT, remember, these are for the "A" series head with heart/kidney shaped chamber so "need" the flat bit around the outside for "squich".... I wish I could actually spell that right... No cut-outs required because head has vertical valves Schrödinger's cat - so which one am I ??? |
30th Oct, 2008 at 06:48:42pm
yeah i couldnt really get in my head an imaged of what you ment a D on its side with a flat bottom. tbh i still dont :) but atleast i know i need the edges for my pistons when i get them and machine them as im going to have a 5port head :)
Edited by Paul R on 30th Oct, 2008. Drives
30th Oct, 2008 at 07:08:26pm
miniminor63 what size ae those pistons ?
30th Oct, 2008 at 07:37:31pm
i would say 73.5 as it is a N/a Drives
30th Oct, 2008 at 07:58:37pm
why 73.5 mm? its 72.5 mm pistons as a matter of fact, so I do not make the block "useless" when worn at 73.5 mm |
30th Oct, 2008 at 08:03:44pm
i was meaning a 1380cc i thought they used 73.5mm pistons :) as your doing a n/a build i assumed it would be 1380.
30th Oct, 2008 at 08:04:50pm
:) its not a 1380, its a 1343cc engine. |
30th Oct, 2008 at 08:11:44pm
+60 long stroke? or custom pistons and bore size? Drives
30th Oct, 2008 at 08:15:35pm
pistons are wiseco ones, so custom. one can get 72.5 mm pistons from different other places now though. The stroke is standard 1275. |
30th Oct, 2008 at 09:32:47pm
Here are my STD Powermax pistons with 16v cuts. Note the cuts are all identical across the pistons because of the special boring carried out On 26th Oct, 2004 TurboDave16v said:
30th Oct, 2008 at 09:43:32pm
Sprocket could you tell me the thickness of the center of the crown in the pic with the sectioned piston On 17th Feb, 2009 Rob H said:
30th Oct, 2008 at 09:50:34pm
7mm. Those turbo pistons are tough old boots!! On 26th Oct, 2004 TurboDave16v said:
30th Oct, 2008 at 09:57:14pm
:lol that they are,
