Home > Help Needed / General Tech Chat > Mini Sport 4 pot Alloy calipers, are they any good?
longy
Member #: 2727
Bicester
Hi Guys loooking at uprating my crappy drums to 4 pot calipers to fit under my 10's and was looking at the Mini Sport calipers, just wanted to hear some of your views on them.
1972 998 TURBO SLEEPER
do a quick search it has been coverd before
longy
Member #: 2727
Bicester
thanks
Be careful, 4 pots might not fit under all 10" wheels even on 7.5" discs.
longy
Member #: 2727
Bicester
oh ok, im planning to use 6x10" wellers
I'm running the early minisport calipers under 5x10 revolutions. seem to work ok although I did have problems initially with siezed bleed valves - understand the new ones are a slightly different design now
Hopefully they come with bleed nipples on both sides now.
longy
Member #: 2727
Bicester
they only have a single bleed nipple on the back
philc
Member #: 1346
bromsgrove
i have kad four pots with 2 bleed nipples, fit like a glove under my lovely 6x10 mb's. mmmmmmmmmmmm
In my case it was Mambas (6 X 10) that I couldn't get a definative answer to.
One forum told me they wouldn't fit without a small spacer, others said it would be OK.
About 18 months ago I had a look at a box of the MiniSpares ones (not MiniSport) at my local supplier (who sells on some MiniSpares stuff) and the leaflet inside specifically stated "these may not fit under some 10" cast alloy wheels such as Mambas..."
That was 18 months ago so the designs may have changed - I can't find anything on the MiniSpares web site to confirm what that leaflet said 18 months ago.
So I took the safe option and bought the standard 7.5" AP calipers.
More recentley, I discovered that there are three different versions of the Mambas anyway, superfically the same but not actually the same......
Jay#2
Member #: 648
Northern Ireland (ex AUS)
KAD have a pdf with a template of their caliper and disc setups, it would be good if the others could do the same. I don't have a hope with my reverse rims sadly.
On 7th Nov, 2008 Nic said:
naeJ
m
longy
Member #: 2727
Bicester
ive just spoken to someone and they have 7.9" vented discs under 10" wellers, so it looks promising
dont forget some wellers are diffrent offset. some styles of them can fit under "modefied" metro turbo setup. as for reverse rims, you can fit them with KAD calipers :)
Edited by Paul R on 30th Oct, 2008.
Jay#2
Member #: 648
Do Tell! I thought with a non-vented 7.5" disc and a spacer between the wheel and flange it might but did't know they will fit otherwise.
naeJ
m
well they are reverse rims on that pick up, they had a knock mark on one wheel but it was buckeld. they are kad 7.5 setup with solid disks i belive it is a cooper S flanj on it though, i will try and find out for you
Mr Joshua
Member #: 1954
Luton Bedfordshire
I had a set of standard 2 pot's on a set of mamba alloys years ago no spacers required. Back then it was either weller's or mambas on 10s if you wanted to run discs as the cooper s disc set up's were like hens teeth
Own the day
Jay#2
Member #: 648
Actually Paul your right, a re-read of the KAD wesite mentions reverse rims as one of the wheel types that should fit with a solid disc and their calipers. A phone call may be made to KAD tomorrow me thinks. Sorry for the hijack!
naeJ
m
BadgerBaiter
Member #: 2257
Brighton
I am hoping I can get a set of the 6pot KADs I have under my 9 x 10s... haven't tried yet, if that fails I have a pair of 8 x 10s for the front to have a go with . . .
http://www.jolyonway.com
longy
Member #: 2727
Bicester
i bit the bullit an brought the 7.9" vented kit from mini sport, ive just assemblied them and found that the caliper is offset from the disc, i did hear about some people spacing the disc from the flange, any ideas?
by how much,
Are the discs vented or solid? Also what drive flanges have you got?
longy
Member #: 2727
Bicester
they are vented and im using metro flanges, its offset by about 8mm
are you using metro disks, you must be if vented,
are you using mini uprights,
yuo will have some missmatched components
longy
Member #: 2727
Bicester
im using mini uprights, metro flanges and the discs are 7.9" vented grooves mini sport discs. i think it must be the flanges
you cannot mix metro flanges with mini disks,
metro flanges are thinner so have adeeper bell on the disk to put the disk in the right place,
if you vented disks are specials for the mini , you need mini flanges,
were disks expensive, youd be better off using both metro flange and disk
