| Home > Help Needed / General Tech Chat > OT plz help chaps i'm stuck & my car wont start!!!!! nissan silvia??? | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
15th Dec, 2008 at 01:11:07pm
how do chaps, i have a nissan silvia the early s12 model with multi-point injection
![]() 2102 Posts Member #: 432 Post Whore Swindon |
15th Dec, 2008 at 01:14:50pm
immobaliser??
Edited by Mini_Andy on 15th Dec, 2008. |
15th Dec, 2008 at 01:16:05pm
i've took the alarm & immobilisor off! as a precaution really so i dont have to take it into account whilst i try to get her going! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
15th Dec, 2008 at 01:25:15pm
have you had it working since you took it off? |
15th Dec, 2008 at 01:27:30pm
double and triple check all of your timing mate. that is where my money lays.
15th Dec, 2008 at 01:32:42pm
it was running fine before & after the alarm/imobilisor, it is an aftermarket one! & the car does'nt have a OE alarm/imobilisor
15th Dec, 2008 at 01:35:40pm
set it to TDC on No1 and check it all over, get your firing order, and check the leads are in the right order. if they are then it should fire (if this is the problem) and then you can check the ignition timing with a light to get it correct. |
15th Dec, 2008 at 02:01:07pm
leads ae correct, firing the same as mini, 1342,
315 Posts Member #: 3013 Senior Member Epsom Surrey |
15th Dec, 2008 at 02:03:59pm
i had a m8 who had this same problem before and i cant remember what it turned out to be but he looked it up on a nissan forum
15th Dec, 2008 at 02:10:28pm
i've took all the leads to sensors on & off a few times so they are clean & making good contact, its just spinning over & not catching on aything to fie :/
15th Dec, 2008 at 02:11:31pm
yes the crank sensor will let it spin but not start |
15th Dec, 2008 at 02:16:20pm
On 15th Dec, 2008 clubminiflip said:
am i right in thinking if the crank angle sensor is fooobared the motor wont start???? Usually it won't start as the crank angle pickup is needed to do the timing (is this the error code you are getting ???) On 15th Dec, 2008 clubminiflip said:
will any other sensors stop the motor starting? Some will be absolutely required, others that fail may just put the EMS into "limp home" mode (fairly obvious when it happens). Fault codes by flashing light codes are usually very reliable - so long as you have the table to look up what the code means. Schrödinger's cat - so which one am I ??? |
15th Dec, 2008 at 02:20:01pm
i hope it aint the crank angle as in the manual it says its a whole new dizzy to sort it as the crank angle senser is in the dizzy! gonna have a look on think automotive if they have a simular part that i can retrofit if thats the trouble!
15th Dec, 2008 at 02:21:05pm
oh yeah its a 3 wire crank angle sensor if that gives anyone any clues! SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
15th Dec, 2008 at 02:31:06pm
can you not get one from a scrappy? or borrow one from a mate? |
15th Dec, 2008 at 02:31:43pm
in the plug to the crank angle sensor you should have 12v 0v and signal going between 0&(probably)5v.
15th Dec, 2008 at 02:36:02pm
mini13 i'll give that a go 2moro sounds a good idea there!!! the voltages you state are the same as in the manual so i'll see if i can get to the connections!
15th Dec, 2008 at 02:38:58pm
if it were me if this is a known common issue i would break into the wire with some form of connector so i could measure there in the future :) On 28th Aug, 2011 Kean said:
15th Dec, 2008 at 02:40:52pm
heres a pic of the dizzy & the cran angle/postion senser & the boost hose that blew @ 7.5psi
15th Dec, 2008 at 02:42:06pm
i think thats what i'll be doing mini13 as a just-incase measure in the future, well....... aslong as iget the bugger running SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
15th Dec, 2008 at 02:43:44pm
how do chaps, i have a nissan silvia the early s12 model with multi-point injection it turns over fine, good spart & fuel, it has a crank position sensor in the dizzy, dont know if anyone is familer???? fuel pump is werrrrrrinnng away so i think thats okk, i have a walbro 255ltr per hour one on order anyway! what can i check? i'm a bit stuck but need to persevere & get her going! it was running fine i feel somat may have broken down in the system somewhere i have changed plugs & regapped them, new leads dizzy cap & rotor, fuel filter, it was running fine before changing these items but it was difficu;t to start, seemed as though fuel was'nt getting through or the spark was'nt igniting, but i've checked these & they seem ok, i have a multimeter to do other checks but i'm not sure where to start??????? any help is appreciated Did you run the engine for a very short time then switch it off before it really got up to temp? It may be flooded, especialy in this cold weather. I have had this on a Nissan Micra, and the Wifes Seat Arosa does the same thing. Its easy to stop it happening, make sure there is some heat in the engine before you switch it off. On 26th Oct, 2004 TurboDave16v said:
15th Dec, 2008 at 03:17:01pm
i'd drove the car frm my house to my unkles to work on iit, so about 10min drive then turn'd it off so i dont think??? its flodded, there are no petrol wiffs SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
15th Dec, 2008 at 03:41:32pm
am i right? is it think automotive that does cps, afm's etc etc someone on here recomended a place that does automotive sensors but i cant find it?????? SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
81 Posts Member #: 934 Advanced Member halifax, west yorks |
15th Dec, 2008 at 06:44:01pm
there is an s12 tech section on the 200sx owners club sxoc.co.uk
15th Dec, 2008 at 07:29:05pm
is it a CA18et? never worked on one of them before, however take a step back and start with the basics.. dont skip anything here on a hunch or because you "know" its ok.
the ecu has a self diagnose setup on it!
