Home > Help Needed / General Tech Chat > How noisy is noisy - s/c drops
dazibee
Member #: 1356
TRURO, CORNWALL
Righto. A lot of you guys run straight cut drops. Most say they sound great but are noisy. Also a techical advantage over helical. I have never been in a mini with straight cut drops (i have heard plenty go past) and soon may need to fit them to my mini. I am worried about the noise - If the car gives me a headache I will not want to drive it every day to work etc?
So... peeps that drive straight cut drop gear minis most days- is the noise toleratable ( have I made up that word?) I have my stereo on anyway at a moderate level so if that drowns out the gear noise, then all ok. How noisy?
Richie
Member #: 628
the sc drops guard against side loading which tends to kill off hellacles, if you go for a 24 tooth setup rather than the 23 its slightly quieter, and i have also heard that the timkin idlers help reduce noise slightly.
as for overall noise it is not intrusive IMHO and to be fair if your engine spec is so great it requires SC drops and an X pin diff you wont be worried about headaches because you will be screaming everywhere.
a good indication of the sound is on Jims "VIDEO OF COMB" if you can find it, however he also has full SC gears so they are louder than stock, but it gives you the general idea.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
dazibee
Member #: 1356
TRURO, CORNWALL
Errr dunno how this ended up in the wanted section. Whats the procedure to move it?
Kean
Member #: 341
aka T2clubby
South Staffs
You need to bend down and plead forgiveness from the Fentonator!
I'm move it now buddy
Hehe! Sigged.
Anton
Member #: 764
Staffordshire
search youtube for minin00b... I have a video of mine in traffic that gives you a good idea
Look at jimster moving stuff around, with his balls all shiny!
I was worried about my drops been knackered at first as they rattle while stood still. To bo honest there not as loud as id had thought they would. Any turbo motor needs SC imo.
http://uk.youtube.com/watch?v=mUiGZ2Wv62A this is mine around LLandow, cant find the combe videos
Mr Joshua
Member #: 1954
Luton Bedfordshire
Maybe this is the place for this question if not flame away.
The noise issue was always at the back of my mind when I decided to fit SC drops due to the fact the helical set-up killed my other gearbox. To try and reduce the noise and free play I shimed mine 1 thou under the the tolerence given, but they were noisy all the same to the point I took the engine out and fitted my donnar motor.
So my question. What gaps do you all set your drops to?
Own the day
The shimming will make no difference to the noise, it is the backlash between the crude gear tooth profile that makes the noise.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Along the thought line I was going. So can the gaps be closed down to a few thou?
When I got mine there was no advice as to what gaps to set which I thought odd.
Own the day
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Someone on here mentioned not fitting a gearbox/block gasket and just using sealant and they said that quietened them down a bit.
On 7th Nov, 2008 Nic said:
naeJ
m
that is a good vid :) it can bloody shift
dazibee
Member #: 1356
TRURO, CORNWALL
Just watched the you tube vids. The straight cut noise was at the level I expected it to be - ie. louder than the exhaust.
Just watched this. I think some sex wee came out!
I've got a straight cut box, stright cut drops and a big super charger. Can't wait. It should sound the dog's dangleys!
Turbo Tel
Member #: 588
Delaware, USA
I must say that since changing to the 2.95 diff the SC noise has dropped to a tolerable level.. Before that I was wondering if they were worth it.. But now they are staying.
It may be that as they bedded in they quietened down a bit, plus I re-shimmed them when I had the engine out.
The cooling fan makes quite a racket as well...so as someone said, I don't have a clue what my exhaust sounds like!
terry
Edited by Turbo Tel on 15th Jan, 2009.
i have only the straight cut final drive fitted at the moment and it is not as loud as the straight cut transfer gears on their own, but together the can become ear numbing on a long drive. obviously a straght cut gearset woul add to this again
Am afraid i carnt help, ive got sc gears and drops and its fookin amazing, theres no better sound.
Rick
dazibee
Member #: 1356
TRURO, CORNWALL
Turbo Tel. What FD did you have before the 2.95 when it was too noisy?
take a look at my vidios
Nick
Member #: 154
Midlands
my old car was my daily drive with sc drops and box and that was fine noise wise. just turn the stereo up a bit, or fit a full width dash and some soundproofing behind it.
dazibee
Member #: 1356
TRURO, CORNWALL
Benross , just watched one of your youtube vids. I can cleary hear your pasenger say fuckin jesus above the din. Your car sounds pretty quiet despite its spec.
slater
Member #: 1291
Suffolk / Birmingham
http://uk.youtube.com/watch?v=926J83-vVrs
in a sound dedened metro
dazibee
Member #: 1356
TRURO, CORNWALL
Just watched the metro. I could cope with that level of noise no probs. What sort of soundroofing do you have. It seems very efective. I have dynamat in my mini - not impressed.
