Home > Introduce Yourself > my vauxhall 8v turbo
16vmini
Member #: 5037
i know its not a-series , but i know you guys like a good turbo mini so thought i would post some pics of my project.
my 8 year old helping to get the vauxhall 2litre 8v engine in.
I have picked up some LET pistons from the 16v turbo engines , so will slap these in to lower the CR.
Engine in , and IC placed at front , will mod the slam panel and this will allow the IC to move backwards some more.
After a few minutes of playing this seemed the most sensible place for the turbo to go :
I have some laser cut flanges ( a little thin but will do for now )
The turbo is some cheap one , that you guys will cringe at i guess lol.
Will be collecting some weldable elbows and T peices today to make up a basic Log type manifold.
I will also be running on a Megasquirt when i get that far.
will keep you guys posted.
Hello
Interesting project, good luck with it.
welcome , i love the 8 v engine good choice lots of torque.
Hi There
looks good
Welcome, looks like you've got an enthusiastic little helper there! I like the look of vauxhall engines, deffinately on the cards for the next project!
Turbo looks snug.
Where's the eight year old?
looking good, is that a t3 turbo?
wont the LET pistons have cutouts for 16v?? your only running 8v will this work?
16vmini
Member #: 5037
yea , thats a T3 turbo ...
they do , but wont effect things (well in my small brain they wont) .. if anything it will just be a little lower CR than in the LET
vauxhall boys have used LET pistons in the 8v with no problems
Matt
hello and welcome; interesting project!
keep us posted, looks interesting so far.
G13B
Member #: 1376
Looking good Matt, really fast progress to:cool:
looks a great project
16vmini
Member #: 5037
collected the pipe fittings today , just need welding together :
Kean
Member #: 341
aka T2clubby
South Staffs
Looks good, those pipes were made for the job!
16vmini
Member #: 5037
yea . just a small amount of trimming ..
16vmini
Member #: 5037
Can I ask where you got the pipewrk from.
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Looks like a cool project !
How much modification is done to the front subby to get the engine to fit ?
"Try to take over the world!"
madcatminis
Member #: 5327
Dudley, West mids
Hi chap. Nice work so far. As well as doing a turbo mini I'm also doing a vauxhall 2.0 16v conversion for my clubman. The think the LET pistons will be sound as long as you don't use a high lift cam. What subframe are ya using, or have ya fabricated ya own up?
madcatminis
Member #: 5327
Dudley, West mids
Ahh i see your using the allspeed engine mounts. I know this as thats the frame I brought. It's an awesome piece of kit. Well engineered. *happy*
16vmini
Member #: 5037
mines a little different (still from allspeed just a 1 off ), as i wanted more room to run the down pipe :
i got my pipes from BSS
16vmini
Member #: 5037
ok , only got an hour tonight :
welded the two T peices together ,once i ground them a bit to match the ports :
Then ground down the other side of the T to allow for one of the elbows to line up with the port :
i kept seam welding each peice , so when i was finished i knew it was not going to move all over the place :
i have now tacked it to the flange , and tonight i will weld the T3 flange on , then the turbo should bolt up under its own weight...
16vmini
Member #: 5037
i could not be arse to grind down all the welds .. as i thought this should be as strong as it can be .... does not need to be pretty ...
