| Home > Help Needed / General Tech Chat > Are Su's poo? | |||||||
9th Mar, 2009 at 05:16:18pm
Been having loads of issues with the car running lately. Got myself a wide band kit, one min the cars running great then its running crap.
9th Mar, 2009 at 05:33:52pm
SU's are simple, reliable and (I believe) one of the eaiest carbs' in the world to set up.
Edited by turbodave16v on 9th Mar, 2009. On 17th Nov, 2014 Tom Fenton said:
9th Mar, 2009 at 05:43:26pm
do the bike carb. was thinking about something like that for my SC12 setup...
9th Mar, 2009 at 05:57:35pm
Dave, I must have something strange going on.
9th Mar, 2009 at 06:04:49pm
Float chamber needle valve worn/sticking? Fuel pressure too high overcoming said needle jet? Float height set wrong?
9th Mar, 2009 at 06:08:53pm
Have you got another carb to try?
9th Mar, 2009 at 06:09:28pm
Show us a pic of the install. This might reveal something obvious,,, On 17th Nov, 2014 Tom Fenton said:
9th Mar, 2009 at 06:12:02pm
hmm think about the float height. was going to whip it off and have a look. the fuel pressure is about 3psi and I can turn it down on the regulator.
9th Mar, 2009 at 06:13:30pm
an old pic whilst it was getting megajolt
9th Mar, 2009 at 06:15:10pm
9th Mar, 2009 at 06:16:06pm
9th Mar, 2009 at 06:26:50pm
cant see much in the pics but:
9th Mar, 2009 at 06:31:30pm
Do youhave the two holes on either side of the itake (on the filter) that go up to the dashpot? On 17th Nov, 2014 Tom Fenton said:
9th Mar, 2009 at 06:48:44pm
yes but I was thinking that these might be blocked but the sock as its a short ram pipe. Are these holes are to aid the piston lift? if so will it be rich if blocked? I was thinking of trying a Rover V8 intake and then a universal K&N?
559 Posts Member #: 2775 Post Whore Aberdeen |
9th Mar, 2009 at 07:05:55pm
Do you have a heatshield at the bottom of the carb. It is maybe struggling with the heat once the car is up to temp.? |
9th Mar, 2009 at 07:34:24pm
may also be worth replacing the bimetallic strip with something that doesnt change with temp (theres a few threads on it) also.. is it possible the temperature of the charger is affecting the fueling, allowing more or les port wall wetting/atomisation. turbo 16v k-series 11.9@118.9 :)
9th Mar, 2009 at 07:48:49pm
On 9th Mar, 2009 evolotion said:
may also be worth replacing the bimetallic strip with something that doesnt change with temp (theres a few threads on it) also.. is it possible the temperature of the charger is affecting the fueling, allowing more or les port wall wetting/atomisation. You have got to be kidding me port wall wetting WTF this is getting way over my head. I had read about the strip I think I will make one up and pull the carb off again.. look at the float height and decide to keep it or switch to a bike carb..
I dont have a heat shield. I cant seem to get a pattern to the problems.. but I also cant remember setting the float height so it might be my inability... I run a supercharger and I don't care the TB is on the wrong side.
9th Mar, 2009 at 07:55:20pm
well your firing fuel suspended in air through the charger, some of it wil lend up onteh walls and floor of the plenum, some of it will end up in the engine. depending how hot (or some other variable) the charger and its surroundings are will change how the fuel is distributed in the air.
9th Mar, 2009 at 08:03:13pm
I remember hearing about charger temperature problem's on these. I think some of the people in Aus use water injection to cool things down... On 11th Feb, 2015 robert said:
9th Mar, 2009 at 08:13:48pm
There's a few people on ausmini recomneding water/methanol injection when running fairly high boost. On 11th Feb, 2015 robert said:
9th Mar, 2009 at 08:26:46pm
Start by opening up the holes or slitting the gasket to allow air into the dashpot like a factory setup is.
9th Mar, 2009 at 09:14:22pm
IMO its not a heat thing.. I think its a carb thing as I couldn't get the car in decent AFR's at idle even with the jet all of the way to the bridge. So its got to be an SU thing.
9th Mar, 2009 at 10:42:21pm
Are SU carbs in most instalations on standard inlet inclined?
9th Mar, 2009 at 11:13:01pm
nope they dont have a roller shutter.... are you thinking of the one that races Citroen's?
9th Mar, 2009 at 11:27:48pm
Could it be the WBO2 playing up? Isambard Kingdom Brunel said:
