| Home > Help Needed / General Tech Chat > rocker cover breather | |||||||
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
10th Mar, 2009 at 07:41:02pm
I am having a few problems with oil over the top of the rocker cover ( just enought to be a pain and requier constant cleaning)
"Tuning should be a compromise between what is possible and what is necessary"
10th Mar, 2009 at 11:20:43pm
the A series like mass breathing so more the better especially on a forced induction one, have a breather fitted onto the rocker cover as well
10th Mar, 2009 at 11:21:57pm
Yep, the more breathers the better. |
11th Mar, 2009 at 11:18:46am
ok sounds like more breathers is the way forward
11th Mar, 2009 at 11:41:15am
Standard cap? |
11th Mar, 2009 at 12:07:29pm
Is that one of the alloy rocker covers where the bit that the cap fastens to is just pressed into the hole with nothing but a small lip to hold it in place? If so the preasure is probably pushing the oil through the gap.
11th Mar, 2009 at 12:53:50pm
with in the cover hole there are 2 tabs which the cap clamps down too is
11th Mar, 2009 at 12:58:34pm
Those little silver caps have a hole in the top of them and oil mists out of there.
11th Mar, 2009 at 01:38:44pm
yes thats it does have a little hole
11th Mar, 2009 at 01:52:25pm
I don't know if there's any other caps that will fit that type of r-box. Personally i'd just screw a small self tapper into the hole to block it. |
11th Mar, 2009 at 02:02:55pm
i've tried an mg cap on mine.
11th Mar, 2009 at 02:30:33pm
On 11th Mar, 2009 Turbo Phil said:
Personally i'd just screw a small self tapper into the hole to block it. if you cant fix it bodge it!!! i love that!!! and a bodge that works tecknicaly is a fix!!! "Tuning should be a compromise between what is possible and what is necessary"
11th Mar, 2009 at 02:52:09pm
11th Mar, 2009 at 02:55:03pm
Huh i thought you wanted a breather and now you want to block it up...I'm confused lol. |
11th Mar, 2009 at 03:02:44pm
add a breather to the rocker cover and block a hole in the cap... On 11th Feb, 2015 robert said:
11th Mar, 2009 at 03:30:29pm
On 11th Mar, 2009 apbellamy said:
add a breather to the rocker cover and block a hole in the cap... thats what i was thinking no oil coming out the little hole and plenty of breathing "Tuning should be a compromise between what is possible and what is necessary"
11th Mar, 2009 at 03:39:41pm
If the rocker cover is like mine (plus the fancy dan MED bit) it has a flat spot to the back right of the cap. you could drill and tap this for a bit of bent pipe or something and then plumb a breather pipe up to the rest of your breathers.
11th Mar, 2009 at 07:19:47pm
i have the same problem, i have breathers at either side of the rocker, I put the query to TM's who suggested piston rings may have worn. Edited by philc on 11th Mar, 2009. |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
11th Mar, 2009 at 07:39:27pm
turbominij- you engine bay looks well sexy from that pic!! got any more lol |
11th Mar, 2009 at 07:46:35pm
i dont have any breathers on the cover bar the pin hole in the cap and it is coming out of there i think.
16th Mar, 2009 at 04:29:20pm
update:
Edited by turbominij on 16th Mar, 2009. "Tuning should be a compromise between what is possible and what is necessary"
16th Mar, 2009 at 05:34:03pm
looks good. another idea that I might borrow... On 11th Feb, 2015 robert said:
16th Mar, 2009 at 07:00:28pm
works a treat like that i get very little oil out the cap and can always block the hole in the cap compleatly if need be "Tuning should be a compromise between what is possible and what is necessary"
16th Mar, 2009 at 08:24:23pm
Looks really neat, and sounds simple to do. |
16th Mar, 2009 at 09:04:18pm
Where did you get the bolt and banjo bit from? On 11th Feb, 2015 robert said:
