| Home > General Chat > some Lancia turbo porn | |||||||
326 Posts Member #: 1323 Senior Member |
4th Apr, 2009 at 12:15:15am
4th Apr, 2009 at 07:32:45am
http://www.youtube.com/watch?v=LTIKUYMlhoo On 20th Oct, 2015 Tom Fenton said:
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
4th Apr, 2009 at 09:03:48am
so have i got this tright,
4th Apr, 2009 at 11:57:40am
yeh, sort of like two head mashed onto one block? |
4th Apr, 2009 at 04:16:45pm
http://www.arpem.com/racing/lancia_ecv/ecv_3.jpg
Edited by carl talbot on 4th Apr, 2009. |
4th Apr, 2009 at 06:06:28pm
imagine the time taken to port that bad boy! hahaa |
4th Apr, 2009 at 06:09:53pm
Im confused??? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
4th Apr, 2009 at 06:17:59pm
On 4th Apr, 2009 MikeRace said:
Im confused??? thats because you a thickie,lol |
4th Apr, 2009 at 06:35:07pm
isnt it just opposed inlets to keep the head temp down rather than having 2 red hot ex valves next to each other? "Turbo's make torque, and torque makes fun"
4th Apr, 2009 at 06:47:32pm
That design is clever....
4th Apr, 2009 at 06:47:38pm
Well each turbo is fed by its own set of exhaust valves by the look of it, I guess you can get away with smaller primarys and increased gas velocity this way?
4th Apr, 2009 at 08:23:30pm
it runs 2 small turbo's and closes off one turbo at low rpm, giving the 2 litres feeding one small turbo this spools it up realy fast and when the desired boost level is reached or it goes above a certain rpm the second turbo opens up to provide yet more boost and allowing more exhaust gasses to flow, its a very clever way of doing stuff but mega complicated, the supra, aristo, skyline, the tt soarer and a fair few others use a similar system but only having 4 valves + 2 ports per cylinder its alot simpler Edited by Brett on 4th Apr, 2009. Yes i moved to the darkside |
4th Apr, 2009 at 08:58:15pm
On 4th Apr, 2009 Brett said:
it runs 2 small turbo's and closes off one turbo at low rpm, giving the 2 litres feeding one small turbo this spools it up realy fast and when the desired boost level is reached or it goes above a certain rpm the second turbo opens up to provide yet more boost and allowing more exhaust gasses to flow, its a very clever way of doing stuff but mega complicated, the supra, aristo, skyline, the tt soarer and a fair few others use a similar system but only having 4 valves + 2 ports per cylinder its alot simpler skyline doesnt run a turbo setup like that, and by the looks neither does this lancia. both turbos are fed gasses at all times. :) turbo 16v k-series 11.9@118.9 :)
4th Apr, 2009 at 09:10:17pm
The only sequencial twin turbo set up I can think of is the RX7. On 7th Nov, 2008 Nic said:
4th Apr, 2009 at 09:12:28pm
On 4th Apr, 2009 Jay#2 said:
The only sequencial twin turbo set up I can think of is the RX7. and toyota 1jz and 2jz :) Edited by evolotion on 4th Apr, 2009. turbo 16v k-series 11.9@118.9 :)
4th Apr, 2009 at 09:13:49pm
On 4th Apr, 2009 evolotion said:
and toyota 1jz and 2jz :) What are those to a non-import person? On 7th Nov, 2008 Nic said:
4th Apr, 2009 at 09:15:16pm
toyota supra , lexus soarer, toyota / lexus Aristo/GS300 :) 2.5 and 3.0 TT turbo 16v k-series 11.9@118.9 :)
4th Apr, 2009 at 09:17:43pm
4th Apr, 2009 at 09:20:56pm
yip, if you get the opportunity to drive one they have a very distincitve power delivery :) there is a valve in the hot and cold side of the "rear" turbo that blocks it off so all 6 cylinders feed the front turbo untill a predetermined boost / RPM point, where the valves open and the second turbo spins up. turbo 16v k-series 11.9@118.9 :)
4th Apr, 2009 at 09:39:37pm
Legacy GT (and a few other variants) is twin sequential turbos too. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
784 Posts Member #: 912 Post Whore North Yorkshire |
5th Apr, 2009 at 07:33:41am
This is the car it was designed for the Lancia ECV Group S.
Edited by Si P on 5th Apr, 2009. I drill holes in everything..! |
5th Apr, 2009 at 08:08:09am
and by the looks neither does this lancia. both turbos are fed gasses at all times. :) i dont want to start an argument, but i was relating to this engine diagram and yes it does run as i stated i have researched this before you can clearly see the egcv after the left hand turbo!!
and for the cars i listed as twin sequential turbo, yes i agree as i recall the Skyline (twin turbo) runs parallel turbo system, i have driven all the 'engines' i listed and indeed owned my own 2JZGTE powered rocket the sequential system is not to be underestimated
5th Apr, 2009 at 10:38:48am
im a bit confused now, are you saying that the digram is a sequencial setup?
5th Apr, 2009 at 12:55:30pm
It looks like it could be, there is a big actuator on the end of the left hand turbo to bypass exhaust gasses until it is called for, there is also some kind of valve on the outlet of the left turbo to stop the other turbo back feeding through it when it is not making any boost.
5th Apr, 2009 at 03:21:20pm
my bad brett , never noticed the valve after teh left turbo :) turbo 16v k-series 11.9@118.9 :)
