| Home > Help Needed / General Tech Chat > Engine starts but cuts out-fuelling problem help please!! | |||||||
9th May, 2009 at 03:50:14pm
I'm having trouble getting my new engine started and i'm a bit stumpped to be honest!!
Edited by richminiturbo. on 13th May, 2009. |
9th May, 2009 at 04:02:58pm
if its turning over really fast, have you checked the tappet clearances? you may have the valves open all the time? |
9th May, 2009 at 04:19:21pm
I've done the valve clearances and theyre all ok.
9th May, 2009 at 04:39:30pm
I know sweet FA about megajolt, but it sounds as if yours is not behaving as it should either in spark intensity and/or timing.The experts on here will soon put you right. |
9th May, 2009 at 04:52:37pm
Lets have a pic of your crank sensor arrangement.
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
9th May, 2009 at 05:04:25pm
check the compression too just to be absolutly sure youre getting all 4 ingredients Edited by Monkeh on 9th May, 2009. |
9th May, 2009 at 05:11:33pm
check you have the wires connected right on the vr.
9th May, 2009 at 05:51:52pm
Thanks for the replys fellas.
Edited by richminiturbo. on 9th May, 2009. |
9th May, 2009 at 06:03:17pm
It's very easy to wire up the coil so that the firing order is wrong.
9th May, 2009 at 06:16:40pm
No luck after changing the leads round.
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
9th May, 2009 at 06:51:46pm
From what you said above, it sounds like you have wired the +12v power incorrectly. Both jolt and EDIS require power while cranking, and if the LED goes out on jolt when your cranking, this is your problem.
Edited by Carl S on 9th May, 2009. |
9th May, 2009 at 07:13:11pm
Ahhh thanks soapsud.
9th May, 2009 at 08:33:08pm
i doubt you have buggered the coil pack, sounds like you need to check the wiring again. Do you have in line fuses, these should be 5v |
9th May, 2009 at 10:36:51pm
No fuses in the megajolt/edis system no.
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
10th May, 2009 at 12:08:38am
If you are not getting a spark then it could be the VR sensor wired back to front. |
10th May, 2009 at 01:34:07am
yes as miniboo says, a common cause of no spark from EDIS is the VR sensor being wired the wrong way round, switching the wires should fix this. |
10th May, 2009 at 01:38:22am
Ok, will have a go!
Edited by richminiturbo. on 10th May, 2009. |
10th May, 2009 at 01:42:33am
Could be something simple as loose/crossed wires chap. You'l have it going in no time!
10th May, 2009 at 07:40:26am
On 9th May, 2009 richminiturbo. said:
No fuses in the megajolt/edis system no. No idea what the problem is, i'll run the lives off the same circuit and see what happens. Dont think it will make a difference as to why it isnt sparking, as it wont spark with just the edis gubbins connected? well it a good idea to put inline fuses to protect your mj from surges. as miniboo check the wires from the vr. if you have access to a multimeter, check you have readings at the vr, pip & saw, these will be very small readings |
10th May, 2009 at 03:35:29pm
I've just switched round my feeds to everything so theyre running off the same feed.
10th May, 2009 at 04:02:34pm
Set your multimeter to read a nice low Voltage mate and check to see if you get a signal on the pip/saw wires like said above.
10th May, 2009 at 04:41:43pm
again, at the coil pack, check you have voltage there |
10th May, 2009 at 05:21:51pm
Ok, i'm getting a 12v at the coil.
10th May, 2009 at 06:17:05pm
I just tested continuity across 1+4 , 2+3 on the coilpack and didnt get anything.
10th May, 2009 at 06:29:39pm
across the ht terminals?
