| Home > Help Needed / General Tech Chat > Clutch Problem...*Sorted* | |||||||
11th May, 2009 at 09:01:57pm
Will you please have a look at these pictures and someone tell me whats wrong, The diaphragm looks real close to the centre nut on the flywheel, and why is there that little bit sticking out on the plunger arm, i think its bearing on the nut when i press the clutch. spec is, new ultralite fly, grey cover, racing plate,new nut and keywasher, new slave and bearing, i hasten to add i have converted to preverto from verto. engine runs fine but cant get a gear at all.
Edited by chinlesswonder on 17th May, 2009. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
11th May, 2009 at 10:10:16pm
That nipple on the bolt is a mystery... I grind it off out of principle. It does look like you could be hitting this as your plunger sticks out a long way from the bearing. On 17th Nov, 2014 Tom Fenton said:
11th May, 2009 at 10:12:58pm
thats what i thought, what about the diaphragm, in anyones opinion is it too close to the centre bolt, how much does it move when the clutch is pressed down, i'm thinking of packing the plunger out a tad with a thick washer 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
11th May, 2009 at 10:22:18pm
the diaghram moves around 180 thou according to fastcarl. On 28th Aug, 2011 Kean said:
12th May, 2009 at 07:34:46am
whats with the spring washer on the plunger? is that a verto plunger with the bearing? |
12th May, 2009 at 05:56:14pm
no, apparantly it is a pre verto 'wok' had the long arm on it, ill double check though. Seems odd though as the bearing is a loose fit on the shaft and only held on with that crappy retaining washer 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
12th May, 2009 at 05:58:32pm
Any thoughts on the diaphragm and how close it is to the centre flywheel nut?. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
12th May, 2009 at 06:10:56pm
that plunger looks wrong! the bearing should be a push fit, the bearing should be about flush with the end of the plunger, and i've never seen one with the washer thing.
12th May, 2009 at 06:31:08pm
that plunger is the same as the preverto one i'm using (with a verto flywheel lol) I think they ARE LOOSE TO MAKE THEM SELF CENTRALISING oops.
12th May, 2009 at 06:39:25pm
keith, its a vertro plunger you need a pre vertro one and make SURE you have the right bearing to suite!
12th May, 2009 at 07:50:20pm
what about the diaphragm cover plate, does it look like its fitted right, it looks awful close to the centre flywheel bolt 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
12th May, 2009 at 08:31:06pm
getting a bit confused now, i have this plunger which says its pre verto
12th May, 2009 at 09:33:34pm
right kieth, the top one is the wrong one, which i guess is the one you have.
12th May, 2009 at 09:42:06pm
Right, cheers Steve, it is ordered 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
16th May, 2009 at 10:52:41am
Got the new plunger and bearing, pressed it on in the vice, nice and tight, fitted it to the car again and bolted everything up, gave it a try and its still the same, can't get a gear, arm is moving fine, running out of ideas now. Any one got any suggestions?. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
16th May, 2009 at 11:03:18am
is the bearing making contact with the pressure plate ? and the pressure plate is disengaging ?
16th May, 2009 at 11:13:12am
bearing is definately making contact with the plate, not too sure if its disengaging when i push the pedal down, it looks from my previous picture that the pressure plate is hitting the nut holding the flywheel on, theres only about 5mm between them. Is it possible the primary gear in some way is jammed into the flywheel?. As i recall, when i first ran it, the clutch worked ok for about 6 or 7 presses, got gears no prob lem when i tried it in the street, then i felt something 'give' when holding the pedal down, like the thrust bearing had moved back on its shaft, that was the last time it worked. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
16th May, 2009 at 11:32:04am
how many drive straps do you have on ?
16th May, 2009 at 12:21:36pm
brand new orange diaphragm, new lightened backplate and ultrlight flywheel, all from minisport, all balanced by them, its got 2 drive straps on each lug 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
16th May, 2009 at 12:25:44pm
Just had another thought, could it be the goodridge flexi pipe i'm using, it is the verto one from the previous slave cylinder, i got the pre verto slave but didn't replace the pipe. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
16th May, 2009 at 04:36:08pm
What condition is the clutch arm in ? And have you correctly adjusted the throw out stop bolt ?
16th May, 2009 at 05:59:09pm
clutch arm looks ok, bit old but no cracks or serious worn bits, i got a new clevis pin just to be safe. I have wound the throw out stop nut right back just to try and eliminate that,still no joy. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
16th May, 2009 at 06:21:09pm
first thing kieth, the orange wont do the duty, get a double grey buddy and make sure!
Edited by BENROSS on 16th May, 2009.
17th May, 2009 at 05:27:58pm
Stripped the whole clutch apart at the weekend, soon as i released the backplate i found the problem, couldn't turn the clutch plate by hand, took flywheel off and the primary gear was stuck solid, couldn't turn it at all. Pulled it off the taper and retrieved the spacer at the back, then realized, it was on the wrong way, it has an ever so slight chamfer on one side that goes to the crank, so assembled it correctly and its fine now. can't for the life of me see how i missed this when i built it. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
17th May, 2009 at 07:13:40pm
there you go kieth, the clutch would not idle at all
