| Home > Technical Chat > Boost Control - Which Gear Your In | |||||||
26th May, 2009 at 07:15:59pm
Recently ive been having a bit of think about boost control, has anyone tried controlling boost in relation to what gear youre in?
26th May, 2009 at 07:23:42pm
i do it with an apexi AVCR. but a small array of solenoids and microswitches will achieve the same :) go for it, helps driveability no end! turbo 16v k-series 11.9@118.9 :)
26th May, 2009 at 07:29:04pm
Sweet, i gather yours is a little more complicated?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th May, 2009 at 07:36:07pm
its more complicated aye, but needs the car to have the appropriate wiring to work, and its expensive, seriously a couple of solenoids and microswitches and perhaps an override -full-boost-in-al-gears hooligan switch will do just fine :) turbo 16v k-series 11.9@118.9 :)
26th May, 2009 at 07:45:39pm
The tricky part is the solenoids getting them to change the boost correctly. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
3596 Posts Member #: 655 Post Whore Northern Ireland |
26th May, 2009 at 07:57:20pm
IMO, mapping boost with TPS would also be a good idea.
26th May, 2009 at 09:00:47pm
i just use a switch or two for different stages of boost |
26th May, 2009 at 10:01:41pm
Do boost solenoids just open and close? Or can they vary the amount of pressure going through them?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th May, 2009 at 10:15:45pm
they just open and close (unless you drive them with a PWM signal) so to regulate the bleeding you need a valve, any pneumatic valve will do, even those wee plastic clear aquarium valves or any cheap bleed valve :) turbo 16v k-series 11.9@118.9 :)
26th May, 2009 at 10:20:35pm
so 4 solenoids 4 valves and 4 switched lol. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
2645 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
26th May, 2009 at 10:24:52pm
On 26th May, 2009 MikeRace said:
Do boost solenoids just open and close? Or can they vary the amount of pressure going through them?? |
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
26th May, 2009 at 10:45:47pm
my boost is mapped to TPS and gear, it's all managed by my emerald ecu On 15th May, 2009 TurboDave said:
26th May, 2009 at 11:00:58pm
On 26th May, 2009 Jimster said:
my boost is mapped to TPS and gear, it's all managed by my emerald ecu so is mine funnily enough. |
27th May, 2009 at 12:04:44am
There ya go then lol 9.85 @ 145mph
27th May, 2009 at 10:39:22am
How does the ecu know what gear your in??
my boost is mapped to TPS and gear, it's all managed by my emerald ecu 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
27th May, 2009 at 11:38:29am
probably rpm vs speed??
On 27th May, 2009 MikeRace said:
How does the ecu know what gear your in?? On 26th May, 2009 Jimster said: my boost is mapped to TPS and gear, it's all managed by my emerald ecu If something is worth doing, it's worth doing half of. |
27th May, 2009 at 11:45:58am
How does the ecu know what gear your in?? On 26th May, 2009 Jimster said: my boost is mapped to TPS and gear, it's all managed by my emerald ecu It uses wheel speed sensors, and calculates it from RPM On 15th May, 2009 TurboDave said:
27th May, 2009 at 12:00:28pm
ah, clever!
27th May, 2009 at 12:15:00pm
Wheel speed sensors is the way to do this a friend of mine has used a second Mega jolt computer and Edis to make a cheep DIY boost controller.
On 17th Feb, 2009 Rob H said:
28th May, 2009 at 11:34:39pm
On 27th May, 2009 mini13 said:
ah, clever! what i was thinking could be a workable soulution is to have a micro switch on the left of the gearshift that is opperated in 1st and 2nd, and just have a lowerboost for those two. |
29th May, 2009 at 12:40:47am
How does the ecu know what gear your in?? On 26th May, 2009 Jimster said: my boost is mapped to TPS and gear, it's all managed by my emerald ecu It uses wheel speed sensors, and calculates it from RPM Jim, have you got any pics of how you've mounted your wheel speed sensors? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
29th May, 2009 at 10:44:30am
Here are some pics of my speed sensor mounted.
29th May, 2009 at 11:19:38am
cool....are you using the holes in the disc as the trigger ? 9.85 @ 145mph
29th May, 2009 at 11:22:04am
29th May, 2009 at 11:38:58am
On 29th May, 2009 stevieturbo said:
cool....are you using the holes in the disc as the trigger ? I'm using the 'D' lugs which the disk bolts ot the hub with, there are only 4 of them so not the finest resolution but good enough for what I want. You can just about make out the lugs on this picture
