| Home > General Chat > how light can u get a mini? | |||||||
20 Posts Member #: 2989 Member |
25th Jun, 2009 at 12:30:18pm
my mk3 mini is a heavy peace of shit and i want it to become lighter. Edited by litenmentuff on 25th Jun, 2009. |
25th Jun, 2009 at 12:34:04pm
These are the lightest by far
25th Jun, 2009 at 12:36:44pm
haha yeah thats more like it! :)
25th Jun, 2009 at 12:40:28pm
If you add up all those 1 & 2 kilos you say are not woth bothering about that soon adds up.
Own the day
25th Jun, 2009 at 12:54:39pm
how heavy is your mini at the moment, does it have a cage fitted?
25th Jun, 2009 at 01:07:36pm
Sounds like you need a hole cutter and you need to start drilling holes in things... On 11th Feb, 2015 robert said:
25th Jun, 2009 at 01:24:13pm
and start thinking outside the box
25th Jun, 2009 at 01:34:50pm
Didn't paul manage to save a kg or 2 from his gearbox casing too? If something is worth doing, it's worth doing half of. |
25th Jun, 2009 at 01:44:29pm
i thought it was more than 2kg's!
25th Jun, 2009 at 01:45:52pm
I left the speedo drive out of my box when rebuilding it, wonder how much that saves hehe. And resistence too Edited by richminiturbo. on 25th Jun, 2009. |
25th Jun, 2009 at 01:54:27pm
its a standard mini clubman as speeking iam puting in a new engine and tought i might as well make it a little bit lighter. |
25th Jun, 2009 at 01:56:44pm
Watching carl has taught me that to build a light car, nothing can be fitted unlightened, pretty much everything can be made to save some weight. You have to look at every single part, the first time you say "thats not that heavy" then you have lost the plot to build a really light car.
25th Jun, 2009 at 02:00:03pm
but how much do u weaken the front subframe by cutting a 100 holes in it ?
25th Jun, 2009 at 02:01:04pm
and 450kgs mini that just crazy thats about 200kg off the starting weight of a mini ? :) |
25th Jun, 2009 at 02:17:34pm
You dont have to cut 100 holes in it!!!
25th Jun, 2009 at 02:18:35pm
On 25th Jun, 2009 richminiturbo. said:
I left the speedo drive out of my box when rebuilding it, wonder how much that saves hehe. And resistence too .
I left mine in. I have heard of the pinion nut coming lose and taking the gearbox & engine with it, If yo uleave it there then the pinion and nut cannot go far On 15th May, 2009 TurboDave said:
25th Jun, 2009 at 02:20:29pm
Dilling circular wholes is fine. The circle is a very strong shape. On 11th Feb, 2015 robert said:
55 Posts Member #: 6376 Advanced Member oxon |
25th Jun, 2009 at 03:52:21pm
you can atually strengthen a pannel with holes, hear me out a moment! :)
25th Jun, 2009 at 04:06:36pm
I agree with you sid, but you need an impressive flaring tool to flare a hole cut in steel as thick as a subframe On 15th May, 2009 TurboDave said:
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
25th Jun, 2009 at 04:11:33pm
I'm sure i read some where on here, that Paul Wiginton said 10% of everythings weight can be lost without affecting its strength.
the pissed up clown stood back up, did a twirl and left bollock naked, |
25th Jun, 2009 at 04:22:03pm
Everything is made with a 'safety factor', so can always be lightened and still be strong enough for its job.
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
25th Jun, 2009 at 04:50:21pm
Fit a suzuki engine, 40-50 kg:s saved internationally known as "big" swede |
25th Jun, 2009 at 04:54:52pm
On 25th Jun, 2009 matty said:
Ive now started cutting bolts down so they are just long enough for the nut the other side....fuck I need to get out more! ![]() You mean you are not back drilling the heads yet, HA, amateur :-p
25th Jun, 2009 at 05:32:54pm
socket heads come pre back drilled sort of... On 25th Jun, 2009 Tom Fenton said:
Ive now started cutting bolts down so they are just long enough for the nut the other side....fuck I need to get out more! ![]() You mean you are not back drilling the heads yet, HA, amateur :-p On 28th Aug, 2011 Kean said:
25th Jun, 2009 at 05:39:07pm
Carl once explained to me, if it doesn't break then it's over engineered On 15th May, 2009 TurboDave said:
