Home > Help Needed / General Tech Chat > White Smoke Under Acceleration
jonb_5
Member #: 3193
Torbay, Devon
Hi
I am thinking this is valve stem seals but just want some comformation.
Under acceleration roughly 3-4k onwards the mini will smoke out the exhuast, when looking in the mirror you can see a fair bit, not enough to stop seeing through it easily though.
Just wondering what this could be?
Jon
turbo oil seals possibly
Nick
Member #: 154
Midlands
white - water or brake fluid
blue- oil
black - fuel
....usually
Mr Joshua
Member #: 1954
Luton Bedfordshire
Think possative its tyre smoke *happy*
Own the day
jonb_5
Member #: 3193
Torbay, Devon
Im pretty sure it is white, will take it out again when it stops raining and double check.
Is it possible that it could be a blown head gasket.
Is there a way to check this?
Thanks
Jon
stefaz
Member #: 1656
stoke-on-trent
compression test or a leakdown test if you have the kit
how old is the turbo ?
jonb_5
Member #: 3193
Torbay, Devon
Hi
Its a N/A engine, so no turbo unfortunately.
Anyone local have a compression tester that I may be able to borrow?
Jon
probably head gasket then
if its white smoke if its losing water as well the head gasket is the suspect.
also do the cr test
philc
Member #: 1346
bromsgrove
do you have oil in the radiator or white sludge??
jonb_5
Member #: 3193
Torbay, Devon
Not that I know of.
Will check! Going to also go for a drive and get someone to drive behind me to double check the colour of the smoke.
I have done a water and oil change and have not seen either in the other if you see what i mean!
Jon
jonb_5
Member #: 3193
Torbay, Devon
O.K.
Got my GF to follow me today in the mini.
I gave her the choice of:
White
Blueish/Grey
Black
She reaconed Blueish/Silver. Which is good for me as its just using more oil and can do the head when planned in a couple of months. It is definately using oil and I havnt noticed the water level dropping.
What do you reacon?
Jon
philc
Member #: 1346
bromsgrove
mine used oil, i have re-seated the valves and put new stem seals on, seems to have done the trick for the time being. try using a different oil like valvoline. could also be your piston rings, but you can check that when you take the head off
Compression test results?
My turbo was pissing oil out as some people saw at avon and the smoke was white, just to throw a spanner in the works.
He's not running a turbo though.....
I know, im referring to the colour of the smoke, id say guides were gone.
jonb_5
Member #: 3193
Torbay, Devon
O.k
The results are in:
I bought a Gunson compression tester from halfords, and after a bit of discount got it for £10.50. Never thought it would be as easy to use as it was either. Only 20 minutes and I am done.
I warmed the engine up and then took all the plugs out.
The results are:
195 190 180 195
What does everyone reacon?
Jon
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I'd say all is OK.
On 7th Nov, 2008 Nic said:
naeJ
m
Nice high figures and within 10% of each other.
It depends on what the static CR is, as to what you would actually expect the average reading to be but 180 plus would be good on a normal engine.
If you want a better test on the rings (but nowhere near as good as a leakdown test) do the compression test again on a warm engine, then put a couple of squirts of oil from an oil can down each spark plug hole and repeat the test and see if the readings increase.
Edited by Rod S on 29th Jul, 2009.
jonb_5
Member #: 3193
Torbay, Devon
What is a leak down test?
Jon
A leakdown test basically involves pressurising each individual cylinder with compressed air through the spark plug hole when it is stationary (not running on the starter motor and in a position where both valves are closed, preferably TDC on the firing stroke) and seeing how fast the pressure drops.
It needs a bit more complicated equipment than a simple compression tester.
But the use of a compression tester, especially if you repeat the test with a bit of cold oil in the cylinders to increase the piston ring seal temporarily, will tell you most things.
Jay#2
Member #: 648
As far as the type of smoke is concerned, you'll know blue smoke by the smell. Of course not so easy to check if your smoking at 4000rpm.
naeJ
m
