Home > Technical Chat > twin or triple turbo?
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
I was wondering if anyone had considered this besides me. A twin or triple turbo set up. Twin using one shared pip and then two on the sides or a triple using three small turbo's each with it's own pipe and support brackets. If you were to build three different turbos, using them for different power levels I think this might be a good set up, obviously barring the problem with fueling and set up... Also the amount of exhaust pressure would have to be played with... Thoughts anyone?
-James
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Sounds like fun to fit together in the vast expanses of a mini engine bay
On 30th Apr, 2010 Rod S said:
Gary's description is best
Waste of time. A single turbo can be sized to achieve what is required to make a useable car, be it a road car or an out and out racer.
miniswordsman
Member #: 6558
I think it would be a nightmare to fit into a mini's engine bay, and as far as having a single turbo in the bay, yes it can be made very useable, but wouldn't it be nice to say you have the only triple turbo'd mini in the world? And if change up the compressor wheels and such couldn't you make each turbo spool at different times and have a constant turbo spool thereby increasing acceleration? It's just something to toy around with, not necessarily for useability...
-James
Ben H
Member #: 184
Melton Mowbray, Pie Country
The only real reason / need for a twin turbo is because you have two piston banks, i.e. V or Flat. It just makes the plumbing easier. To just do it for the sake of it seems a waste. Modern turbos can do everything you need without the hassle.
http://www.twin-turbo.co.uk
Oli
Member #: 1910
Wilts
Wasn't someone on here building or experimenting with a twin turbo set up on a k1100 head?
Or am i mental?
I say do it. I don't know if anyone was doing a twin turbo, but in case they are, bypass that idea and go straight to a triple. After all, a single turbo can make 250hp easy in a 1300, so two must be 500hp and three must be 750hp.
Let us know how you get on. *smiley*
Edited by turbodave16v on 6th Aug, 2009.
GaryOS
Member #: 2810
Dublin, Ireland
VNT will do that for you
miniswordsman
Member #: 6558
I'm thinking, going back to a thread I had spoken of a 1430cc ealier, triple turboing a 1430cc with turbo's built for the low rev(1500-2000) all the way to the top end. Might give the acceleration that people say is lacking in a turbo 1430, as I gathered that people thought a turbo was just not economical on a 1430. I'm going to drop one in a clubman, with the motor moved just a shade forward to help with clearances...
-James
http://www.mgcars.org.uk/cgi-bin/gen5?runp...al-show-08.html
miniswordsman
Member #: 6558
Gosh that's pretty.
GaryOS
Member #: 2810
Dublin, Ireland
I think it's more the gearbox raping torque and achieving a suitable CR that is the problem
PaulH
Member #: 2340
Dublin Ireland
An A series crank has 3 main bearings and 4 con rods that’s 1.33:1 ratio of condors to main bearings, The A series is an under square engine that means its stroke is longer that its piston is wide.
These two things combine to make an engine that hammers cranks at the best of time then we turbo them meaning we are hammering the crank even harder. Now you want to make the engine more under square. This will only compound the problem further you need to buy TBASE and read it before you go any further.
rd,
P
On 17th Feb, 2009 Rob H said:
miniswordsman
Member #: 6558
Now, I don't want to be daft with this, but what I'm gathering from all the responses is that it's more or less pointless and possibly terminal to the engine to turbo put that many turbos on an a series, especially a 1430cc. While I'll agree that it might kill the motor, I don't see it as pointless. It may not give me any more power, or it may, but it will be unique and fun to drive. If multiple turbos is pointless, so would be EFI because the carb does the same job.
Unfortunately, on a mini with siamese inlet ports, a carb really doesn't do the same job as efi.
miniswordsman
Member #: 6558
It may not give you the exactness of EFI, but it still gets the car going, and plenty of people are pushing out the same bhp figures as the ones with efi, they just haven't spent the bundle of cash on efi.
GaryOS
Member #: 2810
Dublin, Ireland
EFI isn't strictly about power. In some ways it it equivelent to MJ versus a dizzy. A dizzy will always make the same peak HP as MJ but there is still a world of difference in driveability etc.
Just build the triple turbo and prove all us doubters wrong
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
LOL!! STOP!! HAMMER TIME!!
rd,
P
Hi Paul,
Are you in the park at the weekend?
Regards
Camac
edit: hey gary, you going?
Edited by 1972-ANGUS on 7th Aug, 2009.
Condors ????????............ *oh well*
*happy*
Edited by Sprocket on 7th Aug, 2009.
miniswordsman
Member #: 6558
lol. I was wondering if anyone else caught that.
evolotion
Member #: 83
Glasgow, Scotland
you need to read more. 3 turbo's will not give you more torque/power than one single turbo. Anyone who says otherwise is obviously takign the piss.
a stroked a-series will stress the already overstressed crank more. doesnt matter how many turbo's you have, this is just basic physics.
efi (except for the select few who are TESTING the code) is NOT better than a carb on an a-series. the fastest 5 ports on this forum are all carb. efi is in its infancy on teh a-series. its not liek other engiens.
Denis O'Brien.
evolotion
Member #: 83
Glasgow, Scotland
and dont meen to nit-pick paul but your average V8 has a ratio of 1.6:1, doesnt make all v8's naturally flawed :)
Denis O'Brien.
miniswordsman
Member #: 6558
It may not make more torque or power than a single turbo, but wouldn't it be possible to create the same amount of torque through the rev range, or a good portion of it, with multiple turbos? I'm just looking at feasibility here, as I think it would be fun to try. It might blow up in my face, literally, but fun to watch.
Or just fit a twin screw blower and be done with it.
Oh...and fabricate a new gearbox and clutch to handle it.
evolotion
Member #: 83
Glasgow, Scotland
no.
Denis O'Brien.
