| Home > Help Needed / General Tech Chat > WHY WONT MY FUEL REGULATOR BRING MY FUEL PRESURE BELOW 7.5PSI | |||||||
196 Posts Member #: 2301 Advanced Member Blackpool , Lancashire |
13th Aug, 2009 at 01:39:58am
i HAVE A METRO TURBO FUEL PUMP AND REGULATOR (EVEN TRYED MY SPARE REG) AND THE LOWEST i GET DOWN TO IS 7.5 PSI. MY FUEL PRESURE GAGE ONLY GOES TO 15PSI AND WHEN i TURN IT UP IT NEARLY SNAPS THE NEDDLE ON THE GAUGE i WOULD SAY IT WELL IN TO THE 30PSI
http://s256.photobucket.com/albums/hh167/boz-reb-2303/
13th Aug, 2009 at 06:00:24am
ho big is your return line & is it unrestricted? If something is worth doing, it's worth doing half of. |
13th Aug, 2009 at 06:58:13am
Where are you taking the boost signal from? Isambard Kingdom Brunel said:
13th Aug, 2009 at 07:25:56am
i'm going with the return line being too small. |
13th Aug, 2009 at 07:47:07am
or a dodgy fuel preasure gauge... On 11th Feb, 2015 robert said:
13th Aug, 2009 at 12:44:17pm
I'm going with the caps lock getting stuck Own the day
13th Aug, 2009 at 05:53:22pm
Yes the return is unristricted and the out side of the pie mesures 6mm I have 2 returns one from the regulator and the other from the carb. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
13th Aug, 2009 at 05:58:54pm
Im taking the boost signal from the feed from the regulator to the carb, but i get the same reading if I take it from before the regulator. the fuel presure gauge is a mac one and its in good working order. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
13th Aug, 2009 at 06:00:31pm
whats the caps lock ? http://s256.photobucket.com/albums/hh167/boz-reb-2303/
13th Aug, 2009 at 06:00:32pm
so your tank return is 6mm outside diameter? So about 4mm internal. That's a tad small! Try 8mm internal diameter. On 11th Feb, 2015 robert said:
13th Aug, 2009 at 06:07:04pm
ok will do Ive just taken that size off lol thought it was a bit on the large size. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
13th Aug, 2009 at 06:12:52pm
nope, the bigger the better (up to a point) with fuel pipes, especialy the return.
13th Aug, 2009 at 06:28:19pm
Thanks, its a good job I dont throw aneything away. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
13th Aug, 2009 at 08:21:57pm
ok ive done that . just the job well i got it down to 4psi and then the battry went flat and the boster packs flat so ill have another go tomorw. Thanks for all the help. Darren http://s256.photobucket.com/albums/hh167/boz-reb-2303/
13th Aug, 2009 at 08:28:55pm
sods law.... On 11th Feb, 2015 robert said:
13th Aug, 2009 at 09:04:32pm
Just one final point, what do you mean by
On 13th Aug, 2009 boz-reb-2303 said: ...
Yes the return is unristricted and the out side of the pie mesures 6mm I have 2 returns one from the regulator and the other from the carb. .... the bit about two returns, the other from the carb ??? It doesn't quite make sense - the regulator should return the excess fuel to the tank and the carb just get the 3-4psi - what do you mean by return from the carb ??? Schrödinger's cat - so which one am I ??? |
444 Posts Member #: 2885 Senior Member |
14th Aug, 2009 at 12:10:52am
Are you meaning signal line from carb to reg which should infact be signal from plenum. |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
14th Aug, 2009 at 10:04:56am
i think he means the outlet that isnt used anymore for use with the old ecu thingy!!! perhaps! float chamber vent? |
14th Aug, 2009 at 02:12:42pm
Thats what I was thinking. Own the day
14th Aug, 2009 at 11:05:40pm
The second return well ...
14th Aug, 2009 at 11:21:27pm
Does this help:
15th Aug, 2009 at 12:31:54am
no 4 http://s256.photobucket.com/albums/hh167/boz-reb-2303/
15th Aug, 2009 at 08:38:17am
Should be blocked off. |
18th Aug, 2009 at 10:10:01pm
So your fuel tank is, at the moment, seeing manifold boost pressure? lol |
25th Aug, 2009 at 05:50:17pm
Done everything I should have, not getting fuel out of float bowl any ideas http://s256.photobucket.com/albums/hh167/boz-reb-2303/
