| Home > Help Needed / General Tech Chat > minispares aus (hypertech 1360 pistons) overbore size? | |||||||
17th Aug, 2009 at 09:52:27pm
i bought some +60 pistons from aus minisport last month. they should take my block to 73mm, or 1360
17th Aug, 2009 at 10:11:33pm
Plus 60 is NOT 73mm (1360cc)
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
17th Aug, 2009 at 10:22:34pm
I did exactly as Rod says and I have the 73mm pistons in my daily. I actually took all 4 pistons in and also got them fitted to the rods. Specified clearance and came back a couple of days later jobs a goodun On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
17th Aug, 2009 at 10:23:29pm
cheers for the reply. im pretty sure that i have the 73mm, that would take the cc to 1360?
17th Aug, 2009 at 10:35:14pm
It appears you have the 73mm ones (ie, about +094) which is 1360cc
17th Aug, 2009 at 10:38:34pm
if they have slots in the oil ring groove, they are +60, if they have holes, they are 73 or 73.5mm
17th Aug, 2009 at 10:43:21pm
yes, have holes, i remember now they are def. 73s.
17th Aug, 2009 at 11:09:29pm
You don't have to tell the machine shop the actual "overbore" size, just tell them you want a nominal 73mm but with a specified skirt clearance and give them one or more pistons for them to measure accurately.
Edited by Rod S on 17th Aug, 2009. Schrödinger's cat - so which one am I ??? |
17th Aug, 2009 at 11:26:03pm
hi, cheers for the replys. i think im going to take the block and pistons down tomorrow, and see what they think. they are a bit stroppy, hance all the questions!
18th Aug, 2009 at 04:55:00pm
iv just got back from the machine shop. the people there will not overbore an engine unless i am able to supply the exact size that i wish the bore to be machined to.
18th Aug, 2009 at 04:58:13pm
Find another machine shop.
18th Aug, 2009 at 04:59:42pm
+1
On 18th Aug, 2009 Tom Fenton said:
Find another machine shop. If something is worth doing, it's worth doing half of. |
18th Aug, 2009 at 05:05:48pm
plus 2
18th Aug, 2009 at 05:07:01pm
yea, it is a bit of a cop out. there arent any other machine shops around here though. they also have a very good reputation. |
18th Aug, 2009 at 05:12:26pm
how much should such an overbore cost roughly? |
18th Aug, 2009 at 05:20:14pm
Scholars in my part of Suffolk were (a year ago) charging £18 per cylinder for a standard job ie, where they supplied the pistons so they didn't need to measure my own.
18th Aug, 2009 at 06:36:58pm
they quoted me £200 plus vat. minisport/minispeed etc charge under £100, though dont know if they want to suply pistons. have looked in yellow pages and will call a couple of other machine shops in the area for quotes tomorrow.
18th Aug, 2009 at 06:42:27pm
isnt Jimster in your area? could ask if he uses anyone local. On 28th Aug, 2011 Kean said:
18th Aug, 2009 at 07:05:45pm
How much !! ? I pay £50 for mine to be bored & honed & the jobs always spot on. |
19th Aug, 2009 at 03:06:14pm
picked my block up this morning. have also phoned all of the engineering places in the yellow pages. the best i can get is £150 plus vat local.
19th Aug, 2009 at 06:07:45pm
You wont go far wrong with Minisports Machine shop, while some other products may be suspect
19th Aug, 2009 at 09:15:58pm
will be on the phone to them tomorrow to organise things.
19th Aug, 2009 at 10:09:04pm
my local machine shop is about 80quid for an over bore if i supply the pistons, i called in today to have my block looked over Yes i moved to the darkside |
19th Aug, 2009 at 10:37:58pm
What was the verdict brett?
On 19th Aug, 2009 Brett said:
my local machine shop is about 80quid for an over bore if i supply the pistons, i called in today to have my block looked over If something is worth doing, it's worth doing half of. |
19th Aug, 2009 at 11:01:58pm
On 19th Aug, 2009 minimadmotorman said:
What was the verdict brett? On 19th Aug, 2009 Brett said: my local machine shop is about 80quid for an over bore if i supply the pistons, i called in today to have my block looked over just needs new bearings all round, crank mint block will getaway with just a hone...BUT... cant get accralites in std bore
the big end on piston 3 (i think) had an awesome groove down the middle of the bearing but no mark on the crank
piston rings was fooked though lol blow by 24/7 cam bearings fooked the beaks on the cam badly worn and the followers very pitted, they was all up for replacement anyway so no biggie
just on the accralite website now
