| Home > General Chat > Charge Cooler - Suck through | |||||||
18th Sep, 2009 at 10:30:07pm
hello all, there has been a great thread started by Andy500 talking about the Eaton and his findings.
297 Posts Member #: 2276 Senior Member sheffield / derby |
18th Sep, 2009 at 11:52:47pm
do you mean something like this??
19th Sep, 2009 at 11:39:11am
The biggest problem with cooling an already mixed A/F charge is that if you get the temps too low then the mixture will start to seperate. This start to cause all sorts of problems.
19th Sep, 2009 at 08:37:31pm
So how do the V8 boys cope? switch the cooling on via a temp sensor?
Edited by gr4h4m on 19th Sep, 2009. I run a supercharger and I don't care the TB is on the wrong side.
1391 Posts Member #: 1686 Post Whore Oxford |
19th Sep, 2009 at 08:58:14pm
They don`t. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
19th Sep, 2009 at 09:29:59pm
weel from Andy's last post. There are some kits out there
19th Sep, 2009 at 09:31:27pm
will bringing the temps down effect the AFR and if so weaker of richer? I run a supercharger and I don't care the TB is on the wrong side.
20th Sep, 2009 at 10:59:38am
Am I missing something...I can't see why everyone wants to do a suck through setup, when it should be easy enough to make a blow through? Edited by matty on 20th Sep, 2009. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
20th Sep, 2009 at 12:31:39pm
Matty, that last one looks like it was more effort to make suck-through than it would have been to make blow-through! On 12th Nov, 2009 Paul S said:
Gary's description is best |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
20th Sep, 2009 at 12:34:48pm
thats very similar to how I'll be doing my Eaton set up matty, but using that configuration in suck through is just plain madness!
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
20th Sep, 2009 at 02:07:30pm
I'm going suck s/c through as a starter engine. I plan to build a new engine later on with a bigger blower and run blow through with an i/c. Doesn't exactly look like it will be too difficult to do at all. My aim for that one is 200 bananas. On 11th Feb, 2015 robert said:
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
20th Sep, 2009 at 02:40:07pm
On 20th Sep, 2009 Prawn said:
! that setup just needs a turbo carb in the standard location, and and intercooler plumbed in, and it could be brilliant. This would be making it a blow through? with the intercooler after the s/c bit before the carb? Sorry, im just new to superchargers and im still not sure what gets blown and where to suck ![]()
In boost we trust |
20th Sep, 2009 at 02:46:41pm
yep that would make it blow through,
20th Sep, 2009 at 03:01:14pm
That pic is a suck-through??? So has the same issue for charge cooling... I run a supercharger and I don't care the TB is on the wrong side.
20th Sep, 2009 at 03:35:25pm
yea, that setup is suck through still, for some rediculous reason!
20th Sep, 2009 at 06:27:18pm
does anyone have any data on what the issues are with this type of charge cooler. It was mentioned above that too cold is bad, so how cold is too cold,and how it effects the Air fuel Ratio?
20th Sep, 2009 at 06:30:55pm
Just don't forget to engineer some serious dump/recirc valve to let out the air when the throttle is closed. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Sep, 2009 at 06:38:36pm
Paul why would it need to be dumped more when its cooled than not? I run a supercharger and I don't care the TB is on the wrong side.
20th Sep, 2009 at 06:44:33pm
On 20th Sep, 2009 gr4h4m said:
Paul why would it need to be dumped more when its cooled than not? You only need the recirc valve if going blow through. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Sep, 2009 at 08:39:48pm
Paul why would it need to be dumped more when its cooled than not? I assume Paul is referring to blow through, rather than suck through. You won't get the big positive pressure issues between the compressor and throttle plate on suck through because the charger creates negative pressure at the throttle plate rather than positive. On 12th Nov, 2009 Paul S said:
20th Sep, 2009 at 08:45:19pm
just checking..Anyone know anything about the charge cooling plates above? I run a supercharger and I don't care the TB is on the wrong side.
34 Posts Member #: 1634 Member |
22nd Sep, 2009 at 10:48:38pm
I have talked to a company in aus about their intercooler kits for commodores, they sit under an m90 ontop of the inlet in the aussie v6 engine, a small rad core with water being pumped through, i figured i could make it work with my sc12 kit, however its much too large, he even gave me a cad drawing of the measurments |
23rd Sep, 2009 at 11:26:59am
yea, that setup is suck through still, for some rediculous reason! Matty was simply refering to charger location, as by mounting the charger at the front of the engine, you're still able to use a turbo carb in the standard location. that way, you can plumb the charger onto the back of the turbo carb, with, or without an IC (obviously you'd do it with an IC, as thats the main advantage of blow through) that's what I'll be doing with my eaton setup, using standard turbo fuelling stuff. Got it in one...
869 Posts Member #: 2443 Post Whore Cheshire |
24th Sep, 2009 at 09:15:50pm
On 22nd Sep, 2009 crazy1275 said:
I have talked to a company in aus about their intercooler kits for commodores, they sit under an m90 ontop of the inlet in the aussie v6 engine, a small rad core with water being pumped through, i figured i could make it work with my sc12 kit, however its much too large, he even gave me a cad drawing of the measurments Would be great if you could share this as i maybe able to adapt for the M45. Cheers Andy |
24th Sep, 2009 at 10:12:48pm
Iv`e just had a through about this, what about a cooler before the carb in a suck through setup.
