| Home > General Chat > This is not what a piston should look like | |||||||
![]() 166 Posts Member #: 7347 Advanced Member Dewsbury |
7th Nov, 2009 at 05:05:31pm
7th Nov, 2009 at 05:07:52pm
Thats fine stick it back in I seriously doubt it! |
7th Nov, 2009 at 06:24:40pm
detonation
7th Nov, 2009 at 06:31:15pm
Very true 10 points Own the day
7th Nov, 2009 at 07:15:35pm
rings dont look bad lol ebay the ring set?
Yes i moved to the darkside |
7th Nov, 2009 at 07:26:41pm
Ahh well lol ... The Omega's are now fitted thanks to benross ..
7th Nov, 2009 at 08:45:48pm
i've seen worse, but 8 out of 10 for efforts :) Best 1/4 mile 13.2 seconds @116 mph
7th Nov, 2009 at 09:02:31pm
One has to try lol ... very costly though.. just wanna drive the bugger !!
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
7th Nov, 2009 at 10:30:07pm
Bit of chemical metal and that'll be right! On 20th Jan, 2011 apbellamy said:
I have a bit of a fetish for tools |
![]() 140 Posts Member #: 1367 Advanced Member Cape Town, South Africa |
8th Nov, 2009 at 08:56:17am
question.. how long do you reckon those would have lasted(standard pistons) if fueling and ignition were spot on and running medium to low boost? The same will just happen to the Omegas if the fuel/ign problem is not sorted, will it not? |
8th Nov, 2009 at 09:07:36am
apparently not mate , Benross has lowered the CR ratio by opening up the chambers in the head + the omega's have a 10cc dish . so now the motor is a low C motor ... hope that makes a little sense as it dosent to me ..
8th Nov, 2009 at 09:14:14am
On 8th Nov, 2009 Spooner said:
... hope that makes a little sense as it dosent to me .. Brilliant pmsl I seriously doubt it! |
8th Nov, 2009 at 09:30:41am
Makes perfect sense matey, you are in good hands at Steve's.
8th Nov, 2009 at 09:35:43am
i am a bit worred that mine will look like this when i get my finger out and split the motor Crystal Sound Audio said:
8th Nov, 2009 at 09:45:21am
Lol Well ya just gonna have to grin and bear it .. i could not really afford this but .. i love minis and could not bear not to see her on the road ...
8th Nov, 2009 at 09:54:39am
well again in theory mine should not look like this as ive had no detonation and a nice CR
8th Nov, 2009 at 09:57:29am
well all my standard pistons had bits missing .. the crancase comp was hurrendous .. oil n smoke bellowing out of every orrifis :(
8th Nov, 2009 at 10:44:02am
On 8th Nov, 2009 CR# said:
question.. how long do you reckon those would have lasted(standard pistons) if fueling and ignition were spot on and running medium to low boost? The same will just happen to the Omegas if the fuel/ign problem is not sorted, will it not? Quite a while, I'm sure that there are a couple of people on here producing decent power with stock pistons, just racking my brain to remember who. Isambard Kingdom Brunel said:
8th Nov, 2009 at 12:48:07pm
i heard the std turbo pistons was very good Yes i moved to the darkside |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
8th Nov, 2009 at 01:29:24pm
iv had it aswell :(
David. |
8th Nov, 2009 at 01:43:25pm
Ahh.. im talking of standard 1275 pistons, not the turbo ones. Have a rebuilt engine with a cr of 8.5, and thinking of running low boost.. 6-7psi. but i understand I will have to make 100% sure the AFR's are right with not much advance to avoid det. |
8th Nov, 2009 at 01:55:35pm
They have a much thinner crown, so it will take a lot less detonation to kill them. On 11th Feb, 2015 robert said:
8th Nov, 2009 at 02:01:46pm
That I understand, though how does a thin crown relate to land breakages? Is that not just down to the piston being made from a lesser quality alloy? |
8th Nov, 2009 at 02:45:09pm
My theory is that standard pistons would be fine with the right CR, fuelling, ignition and decent IC up to 10 or even 12psi.
8th Nov, 2009 at 03:54:27pm
im confused ore the pistons picture both the metro turbo pistons?
