| Home > Help Needed / General Tech Chat > Restictors | |||||||
4 Posts Member #: 7481 Junior Member |
12th Nov, 2009 at 03:30:06pm
Hi All,
12th Nov, 2009 at 03:32:33pm
I'm not sure what you are getting at buddy. The only application of restrictors to turbos I know is in rallying where they all have to use a restrictor which is a hole of a set diameter, to basically limit power.
12th Nov, 2009 at 03:39:20pm
FYI
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
12th Nov, 2009 at 03:41:03pm
to follow on from what Tom's saying, I believe the rally cars use the restrictor, to limit bhp whilst still producing monsterous torque figures. they can make huge torque through running mental boost, but power is ultimately limited by the airflow through the restrictor, which i think is something like 34mm on the WRC cars, it's very small anyway, I seem to remember it being comparable to an SU in size! Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
12th Nov, 2009 at 03:46:33pm
Right, so by inserting a restrictor, it increases torque levels (like i thought) But increases turbo lag. So is it possible Anti-Lag can be fitted to a mini without an ecu?
12th Nov, 2009 at 03:49:31pm
12th Nov, 2009 at 03:54:24pm
no.
On 12th Nov, 2009 Luke-Russell said:
Right, so by inserting a restrictor, it increases torque levels (like i thought) But increases turbo lag. So is it possible Anti-Lag can be fitted to a mini without an ecu? Cheers On 28th Aug, 2011 Kean said:
12th Nov, 2009 at 04:41:59pm
The rally cars use the restrictor because it is in their rules, and they have to. If they did not have to have it, they would not.
12th Nov, 2009 at 04:43:27pm
If you seriously believe this to be true then bolt a plate onto the inlet of the compressor and drill a 5mm hole in it. Hey presto 300lb/ft.
Right, so by inserting a restrictor, it increases torque levels (like i thought) But increases turbo lag. So is it possible Anti-Lag can be fitted to a mini without an ecu? Cheers http://www.twin-turbo.co.uk
12th Nov, 2009 at 04:54:37pm
Not being funny but why bother even thinking about this?? do you have a turbocharged mini, if so what torque figure do you have?
12th Nov, 2009 at 05:34:58pm
Right people, not to put anyone down, i was asking if its possible to insert a restictor into the turbo!!!! Ben H, to clarify, i have a pretty good knowledge with cars engines etc, im undertaking a level 2 motorsport engineering course at the moment as im only 16. In the past 6 months, i have been involved in a full rebuiltd on a subaru impreza 2.0 ej20. This involved stipping down the engine and components down completly, it needed a rebore as it blew a hole right through piston number 3. So it was rebored to a 2.1 by alan jefferies, fitted withwosner pistons, it now has forged internals, closed deck block, ported and polished head, roger clark motorsport race bearings, 18g td05 turbo with a 32mm restictor in it, all gaskets replaced with comutec,replaced the top mount intercooler to a front mount, uprated fuel pump with swirl pot, 660 injectors, simtec ecu fitted with anti lag. At present its running 340 bhp with 388 pound foot of torqe. Had to restict engine to 340 bhp as gearbox, td05 turbo and maf sensor start to break down at 350 hp.
12th Nov, 2009 at 05:46:02pm
Yes, but a restrictor is not the answer. If you want lower down torque, build a high compression engine with a small turbo.
12th Nov, 2009 at 05:50:50pm
Right, just to clarify this.
12th Nov, 2009 at 06:53:45pm
restrictors get used in scoobys when all the cat's are removed as the standard boost controll is to slow and you get a boost spike and hit fuel cut. if you have proper boost controll (remember to use your own lines as the subaru lines have a restrictor pellet) you do not need or want the restrictor.
12th Nov, 2009 at 07:46:08pm
Right lads i no fook all about turbos and compressor maps etc.
12th Nov, 2009 at 08:04:58pm
12th Nov, 2009 at 08:06:10pm
On 12th Nov, 2009 cossierick said:
Right lads i no fook all about turbos and compressor maps etc. Ive had my turbo rebuilt buy a local company near us (turbo center ) and in all his waffling i got told he would fit me a 360 thrust bearing and bigger inernal wheel, obviously the bigger blades will cause more lag so he recond to compensate this they fit a tapered restrictor to try and help. (am sure ive got a pic somwhere, give me 5). So thinking about it its prob just bolocks and ive been had but ho well nothing i can do now. Rick will more than likely haveRick, if the turbo centre ypou refer top starts with "Well Lane" it been bollocks ,lol |
12th Nov, 2009 at 08:15:57pm
http://www.turbocentreuk.co.uk/
12th Nov, 2009 at 08:33:32pm
looks like a standard metty compressor housing to me On 28th Aug, 2011 Kean said:
12th Nov, 2009 at 08:43:05pm
nah its had a cone pressed in, im assuming the blades are wider than the opening to them? turbo 16v k-series 11.9@118.9 :)
12th Nov, 2009 at 08:52:27pm
They do go past the cone, so have i been fed a load of shit or is it there for a reason
12th Nov, 2009 at 09:23:18pm
the only possible thing i can think of is this effectively increases the tip height of the compressor so the air has a longer sealed path to gain momentum, so should be able to sustain a given boost with less shaft speed, but this will only work if the restrictor cone thingy is a bawhair away from the compressor wheel, otherwise itll jsut act as a restrictor. either way, its strangling the turbo, wouldnt be in mine thats for sure. even if it works. turbo 16v k-series 11.9@118.9 :)
12th Nov, 2009 at 09:25:23pm
Right, I can see that fitting such a device to the compressor inlet would fool it into thinking that it was a lower trim compressor wheel. It would accelerate the air going into the compressor quicker and as the outer part of the compressor blades would be blanked off, it would behave like a smaller turbo.
12th Nov, 2009 at 10:09:49pm
Sorry luke for jumping thread, hope its all helping tho
12th Nov, 2009 at 10:32:20pm
i would! turbo 16v k-series 11.9@118.9 :)
