| Home > Technical Chat > Hot start | |||||||
169 Posts Member #: 409 Advanced Member Bristol |
22nd Dec, 2004 at 11:23:54am
When my cars a bit toasty, especially in the summer, is an arse to start. It can take up to four attempts. I think this is due to the hot turbo vaporising the fuel in the carb above it. I do have the metro turbo heat shield, but it doesn't appear to do a great deal! Its not the smoothest of looks, especally in a petrol station!! Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
22nd Dec, 2004 at 11:54:40am
On our Set-ups the carbs sits right above a very hot turbo so hot starts will be an issue from time to time.
22nd Dec, 2004 at 12:10:29pm
I have a vented and raised bonnet, but turning the pump off and then starting afresh with cold juice sounds cunning!
22nd Dec, 2004 at 12:26:01pm
No No a old Salisbury....
22nd Dec, 2004 at 01:29:08pm
I have an idea on how to cure this. A couple of my mates both have supercharged G60 golfs, and they both do the same thing......after the engine has been switched off after a run, the fuel pump continues to run. When first noticed they both thought there was a problem, but in fact the clever bleeders at vw have put a FUEL temp sensor in the fuel rail. The VW suffers from heat soak in much the same way as the mini turbo engine, and so it pumps fuel from the tank round the fuel system and then back again to keep the fuel rail cool and prevent hot start problems from vapourised fuel.
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
22nd Dec, 2004 at 05:28:42pm
sounds better than running an anti-percolation fan like the r5 gtt, i think the maestro and montego turbo's ran anti-perc fans too |
23rd Dec, 2004 at 07:47:53am
Good idea that! May look into engineering it!
31st Dec, 2004 at 05:34:06pm
Back in my jet ski days,the norm was a primer(squirt fuel into inlet) instead of choke....
14th Nov, 2008 at 07:57:29am
They call me Mr Vegarrrdd!
14th Nov, 2008 at 08:37:26am
I just live with it - spin the engine with the throttle wide open and it flushes the vaporised fuel through so that as soon as the mixture between the plug points is anywhere near the right level, it fires up.Agree its embarassing in some circumstances, especially if the battery is less than perfect and it starts to slow down before it fires.Its a bit like starting a recalcitrant diesel in that you must keep it spinning till it goes.If you stop and start there is always some more fuel vaporising betwen attempts.The cool fuel idea sounds really cool ! |
194 Posts Member #: 2873 Advanced Member Milton Keynes |
14th Nov, 2008 at 05:41:32pm
Get an electric fuel pump and connect it to the ignition so it only runs wen the key is on acc, so if the car is hot u just switch the key to acc let the pump run abit puttin cold fuel in the rail then she will tick over. |
14th Nov, 2008 at 06:02:10pm
On 14th Nov, 2008 Tweaked said:
Get an electric fuel pump and connect it to the ignition so it only runs wen the key is on acc, so if the car is hot u just switch the key to acc let the pump run abit puttin cold fuel in the rail then she will tick over. All well and good if you have something injection with a fuel rail, but fuck all use on a turbo mini as it will just circulate fuel through the regulator and back to tank, and not get any to the float bowl which is where it is needed.
115 Posts Member #: 2830 Advanced Member Costa del Northern Ireland :) |
14th Nov, 2008 at 07:38:39pm
yup i have the same problem... after a run i guessed it was evaporating fuel that made it hard to start, so i added a carb primer button, the way i have it wired when you press the button the fuel pump runs filling the carb with nice cold fuel again, starts every time :) That mini is determined to Kill me!!!! |
15th Nov, 2008 at 03:57:23am
Get an electric fuel pump and connect it to the ignition so it only runs wen the key is on acc, so if the car is hot u just switch the key to acc let the pump run abit puttin cold fuel in the rail then she will tick over. Thats kinda how mine is wired, pump runs with ignition on. It does not cure it.. As said above it always starts but has that embarrasing 4-6 second delay.. I liked Toms cunning idea but will probably just put up with it.. Edited by Turbo Tel on 15th Nov, 2008. website:- http://www.terryhunt.co.uk
15th Nov, 2008 at 10:45:40am
What about insulating the manifold better? I have the carb shield on with an added layer of heat reflector.
15th Nov, 2008 at 11:59:55am
clicky
Edited by Brett on 15th Nov, 2008. Yes i moved to the darkside |
15th Nov, 2008 at 12:03:41pm
thats probs why it works for me cause mine is fuel injected with fuel rail, but i c wat u mean.
On 14th Nov, 2008 Tom Fenton said:
All well and good if you have something injection with a fuel rail, but fuck all use on a turbo mini as it will just circulate fuel through the regulator and back to tank, and not get any to the float bowl which is where it is needed. Edited by Tweaked on 15th Nov, 2008. |
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
23rd Nov, 2008 at 09:48:30pm
i have the same issue v embarissing in the middle of a petrol station and all ur mates think oooo the mini broke down again!!!! but its just charicter!!!(dam thing) "Tuning should be a compromise between what is possible and what is necessary"
23rd Nov, 2008 at 10:33:07pm
On 23rd Nov, 2008 turbominij said:
but its just charicter!! thats what its all about
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
24th Nov, 2008 at 12:27:54am
i never had this problem before on any of my mini's before i turbo'd my 72. but it does occur now, after some head scratchin!!!
315 Posts Member #: 3013 Senior Member Epsom Surrey |
16th Dec, 2008 at 10:01:45am
mine tends to be a bugger to start aswell when it gets hot but i made up my own custom ally heat shield around the carb
25th Jan, 2009 at 08:48:15pm
Did anyone come up with some plans for toms cunning solution to this problem?
261 Posts Member #: 713 Senior Member Western Australia |
26th Jan, 2009 at 12:48:56am
The washer bottle method seems to be by far the simplest & safest On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
26th Jan, 2009 at 01:53:08pm
washer bottle method? ie u sray the bottom of the carb with water? or have i missed the point "Tuning should be a compromise between what is possible and what is necessary"
26th Jan, 2009 at 10:55:21pm
On 24th Nov, 2008 1972-ANGUS said:
so my new trick on my mini, is a window washer directed at the float bowl. a 4-5 second squirt cools the bowl enough for a first time start. bit of steam but it works!! On 24th Dec, 2008 Nic said:
unusual not to see it listed as an electric supercharger
