| Home > General Chat > Effects on boost with distance it travels | |||||||
17th Dec, 2009 at 04:08:00pm
How is the boost effected if it has to travel a longer than usual route?
I seriously doubt it! |
17th Dec, 2009 at 04:09:56pm
yes , long inlet from turbo should cause more lag as it takes longer to pressurise , but once up to pressure it will /should make same boost as a short tract.
17th Dec, 2009 at 04:11:19pm
Do sharp bends cause pressure loss? Is this how the restrictor in standard plenum works? If something is worth doing, it's worth doing half of. |
17th Dec, 2009 at 05:00:31pm
In theory yes. In practise I doubt you'd notice any difference.
17th Dec, 2009 at 05:45:51pm
Supposedly each 90 degree bend in charge piping is equal to a 1psi pressure loss.
17th Dec, 2009 at 06:16:29pm
I know Richard had all sorts of issues with his fuelling when he was taking the boost signal from the turbo as opposed to the plenum, which suggest that there's a noticeable drop in pressure. Isambard Kingdom Brunel said:
17th Dec, 2009 at 06:49:40pm
like tom say in theory yes. I would think from the cars i've been in if you get the correct turbo some times there is almost no lag. Best 1/4 mile 13.2 seconds @116 mph
17th Dec, 2009 at 06:54:03pm
On 17th Dec, 2009 minimadmotorman said:
Do sharp bends cause pressure loss? Is this how the restrictor in standard plenum works? it depends on the area of the cross sectional area of the pipe . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Dec, 2009 at 06:57:01pm
do a we bit o maths, how much volume is contained within a large hose run. how much air is cunsumed by your engine at x rpm. from this you can work out how long it will take to compeltely replace all the air in the pipes. this is the time that will add to lag :)
17th Dec, 2009 at 08:17:11pm
As above, yes, but you'll never get too much pipe or too big an IC under a mini bonet.
17th Dec, 2009 at 08:19:00pm
On 17th Dec, 2009 wil_h said:
As above, yes, but you'll never get too much pipe or too big an IC under a mini bonet. It wont be under my bonnet I seriously doubt it! |
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
17th Dec, 2009 at 08:26:31pm
surely you cant loose pressure over a length of pipeing unless its leaking.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
17th Dec, 2009 at 08:28:36pm
true, but it is leaking, through the valves, into the cylinders then out the exhaust. On 28th Aug, 2011 Kean said:
17th Dec, 2009 at 09:03:16pm
Think of bends and the IC as a restriction. Forcing air through the restriction causes a loss in pressure. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Dec, 2009 at 09:20:44pm
now i can understand that. i was thinking of 8psi of boost signal at the carb rather than at the turbo outlet. as the signal is taken from the turbo outlet the rectriction would push back against the turbo telling the actuator that theres 8psi there. whereas the carb may only be seeing 6psi.
Edited by MONSTER HEDGEHOG on 17th Dec, 2009.
17th Dec, 2009 at 11:44:10pm
if your contemplating rear mounting the turbo, this will add a fair bit of lag, but due to the exhaust side of things more than the air side of things. turbo 16v k-series 11.9@118.9 :)
18th Dec, 2009 at 08:03:23am
On 17th Dec, 2009 MONSTER HEDGEHOG said:
if this is right then you dont loose pressure, you gain signal. correct? Well you do lose pressue, because you mad it in the first place. But if you're happy to think it's a gain in signal then the effect is the same. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Dec, 2009 at 08:13:14am
If you are thinking of mounting the intercooler in the boot this is problematic due to ram air. If you really are struggling for space look for a charge cooler solution. http://www.twin-turbo.co.uk
18th Dec, 2009 at 08:30:34am
Not looking at the back of the car, Im just thinking of hiding it all under the wings with a charge cooler so I can keep a MK1 looking engine bay and make my own plenum that looks like a standard tin air filter.
18th Dec, 2009 at 09:23:37am
SNEAKY!!! |
18th Dec, 2009 at 09:42:33am
Pressure loss is a function of the square of the velocity. Halve the velocity and you get a quarter of the pressure loss.
18th Dec, 2009 at 10:05:22am
Not sneaky Nic, Id say classy (if it works)
18th Dec, 2009 at 10:06:35am
I'd like to see a twin su turbo.
18th Dec, 2009 at 10:08:09am
Im sure I could find something to seal it off another carb or TB I seriously doubt it! |
18th Dec, 2009 at 10:09:31am
Do it! If something is worth doing, it's worth doing half of. |
