| Home > Help Needed / General Tech Chat > Really need some help!! | |||||||
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
20th Dec, 2009 at 04:24:35pm
My original plan was to use the original MEMs ECM to run the Eaton M45 - but as was pointed out on this very site - it didn't happen.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
20th Dec, 2009 at 04:29:01pm
Ignition timing?? On 11th Feb, 2015 robert said:
20th Dec, 2009 at 06:28:07pm
when is it mis firing? could be fuel. I run a supercharger and I don't care the TB is on the wrong side.
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
20th Dec, 2009 at 06:48:04pm
ht leads on correctly?
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
20th Dec, 2009 at 07:09:28pm
On 20th Dec, 2009 apbellamy said:
Ignition timing?? That's what I'm thinking. On 20th Dec, 2009 gr4h4m said:
when is it mis firing? could be fuel. It's missing all over the shop! It's bad at the low, not as bad mid to high, but still bad enough to cause problems. There ain't no excessive petrol smell, but the plugs very sooty. The Vmax kit came with a pressure regulator - but do you think the standard pump is up to the job? On 20th Dec, 2009 MONSTER HEDGEHOG said:
ht leads on correctly? Definitely on correctly. Double checked and even had the Mrs take a look (supplied with the correct info re Coil Pack). The Mrs is raging! Just found out the RATM beat that wee fanny Joe to #1 - maybe I should tell her I've paid for 6 RATM downloads from iTunes!! lol "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
20th Dec, 2009 at 07:45:41pm
Is anyone else running the Emerald ECM?
20th Dec, 2009 at 09:41:45pm
Just give stuart a ring, im sure he will give you some advice |
23rd Dec, 2009 at 04:37:29pm
usually any missfires under boost are caused by a lean mixture ..... if all other avenues have been checked,
23rd Dec, 2009 at 06:28:09pm
could you not stick a dizzy on it temp to eliminate emerald from the equation? "Turbo's make torque, and torque makes fun"
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
23rd Dec, 2009 at 09:11:43pm
If you are using Wasted Spark coilpack with your ECU, it's worth fitting a 20 microfarad capacitor off a Ford coilpack to prevent misfiring.
24th Dec, 2009 at 05:26:20pm
post up a screen shot of your fuel and ignition maps.
26th Dec, 2009 at 05:40:41pm
On 20th Dec, 2009 Nic said:
Just give stuart a ring, im sure he will give you some advice I'm gonna wait until the New Year - give him a break and hopefully new baby will have arrived save and sound. On 23rd Dec, 2009 BENROSS said:
usually any missfires under boost are caused by a lean mixture ..... if all other avenues have been checked, have you a wide band lambda gauge fitted ? if not i would have a rolling road session to sort this out PRONTO! if only to save your pistons and espcially to releive the ear Ach for the missus .....lol I have a wide band sensor, but in the short term I was gonna rely on the gauge within the Emerald app. I really can't afford a session on a rolling road ATM - uber-skint. On 23rd Dec, 2009 joeybaby83 said:
could you not stick a dizzy on it temp to eliminate emerald from the equation? It's an MPI engine - so that's not possible. On 23rd Dec, 2009 turbominivanman said:
If you are using Wasted Spark coilpack with your ECU, it's worth fitting a 20 microfarad capacitor off a Ford coilpack to prevent misfiring. Certainly sorted mine out on the van. Lots of info on fitting the capacitor at: www.extraefi.co.uk Good luck Richard. Hmmmm, that's interesting - I'll have a good look at the recommended site and see what it says. On 24th Dec, 2009 Sprocket said:
post up a screen shot of your fuel and ignition maps. Have you calibrated the crank position sensor with a timing light? Will do Sprocket. How do you calibrate the CPS? Not that I have a usable timing light, but I can get one no problems. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
12th Jan, 2010 at 04:52:00pm
Ok, had another attempt at getting the Mini running and I can't even get it started. I'm starting to get seriously pissed off with this - but I know it will be worthwhile once up and running.
15th Jan, 2010 at 04:24:42pm
Right, I've said bollocks to studying for my Project Management exam next week for the time being and spent yesterday and today going over my install.
15th Jan, 2010 at 04:31:59pm
the idle advance area looks quite bumpy,
15th Jan, 2010 at 05:24:56pm
Cheers mini13 - I'll give that a try. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
17th Jan, 2010 at 04:44:09pm
Just when I thought everything was starting to go my way.....
17th Jan, 2010 at 04:55:38pm
DOH!!
17th Jan, 2010 at 05:02:48pm
Aye - soooo gonna get the head pocketed, but still skint and student loan and my wages are just paying household bills..... :( So it's gonna take a while.
17th Jan, 2010 at 05:08:27pm
If the two graphs are the same orientation one shows throttle rising from the bottom left while the other shows throttle falling towards the bottom left. That in itself is a problem? Edited by Sprocket on 17th Jan, 2010. On 26th Oct, 2004 TurboDave16v said:
17th Jan, 2010 at 06:18:07pm
On 17th Jan, 2010 MrOz said:
Wife ain't talking to me.... Not all bad then
17th Jan, 2010 at 07:20:15pm
I agree with Joe about the lumpy map at idle. I'd also have a look at smoothing the rest of the ignition map aswell tbh.
17th Jan, 2010 at 07:25:48pm
Thats the big problem Matty, we don't know as there is no lambda gauge or sensor On 26th Oct, 2004 TurboDave16v said:
17th Jan, 2010 at 09:01:55pm
I have a wideband lambda sensor fitted - TechEdge 2J1 - I'm just using the display in Emerald in the mean time.
17th Jan, 2010 at 09:05:48pm
11 is about right at first start up. once warm you should be seeing roughly stoich (14.7)
