| Home > Show Us Yours! > Miglia alloy dash | |||||||
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
9th Jan, 2010 at 04:06:35pm
Just thought i put some pic's of my miglia alloy dash build as i havent seen any other thread's on this i will be up dating this build as i go along. Any comments w Edited by Chris Dillow on 9th Jan, 2010. |
9th Jan, 2010 at 04:09:03pm
Pics dont work Chris, are you using photobucket?
I seriously doubt it! |
9th Jan, 2010 at 04:26:56pm
9th Jan, 2010 at 04:44:33pm
Is that better paul ? took me awhile |
9th Jan, 2010 at 04:47:15pm
Well done mate, Ill come do that welding when the weathers better
9th Jan, 2010 at 04:54:39pm
looks great, not sure about the cardboard though |
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
9th Jan, 2010 at 05:47:51pm
Out of interest, why do the miglia dashes have 'dimples' in them. For a little more rigidity? On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
9th Jan, 2010 at 07:54:40pm
On 9th Jan, 2010 Oli said:
Out of interest, why do the miglia dashes have 'dimples' in them. For a little more rigidity? The dash in mine has dimples (as does the parcel shelf,gear linkage bracket,boot floor etc) I had always assumed it was something Pete Vickers did as a sort of trademark if you like having seen them in lots of other cars he has done.Dont know for certain though. On 20th Jan, 2011 apbellamy said:
I have a bit of a fetish for tools |
![]() 83 Posts Member #: 7115 Advanced Member essex |
9th Jan, 2010 at 08:32:42pm
Cardboard is light though!! Will be good to see it come along! |
9th Jan, 2010 at 08:35:35pm
i think there used to increase stiffness and reduce vibrations Yes i moved to the darkside |
10th Jan, 2010 at 12:08:16am
I am going to add a dimple in the lower section of the dash to add a little strenght as i will be mounting things to it. ie wiring loom, fuse box. |
10th Jan, 2010 at 12:11:28am
Cardbord is proberly lighter than carbon fibre but wouldnt be the best fire wall! |
10th Jan, 2010 at 12:17:10am
Easy enough to make a dimple tool to save cost.
On 10th Jan, 2010 chris dillow said:
I am going to add a dimple in the lower section of the dash to add a little strenght as i will be mounting things to it. ie wiring loom, fuse box. On 19th Jan, 2010 wil_h said:
10th Jan, 2010 at 12:23:38am
Very easy to dimple Chris I seriously doubt it! |
10th Jan, 2010 at 12:31:50am
At the risk of sounding special,how is it done? On 20th Jan, 2011 apbellamy said:
10th Jan, 2010 at 12:34:17am
Push a male dome into a female dome with the panel inbetween
10th Jan, 2010 at 12:35:31am
Thanks Paul,doesnt get much simpler than that! Do you need to have a flat area around the domed formers to stop the panel bending too much around the dimple if that makes sense? Edited by rosco454 on 10th Jan, 2010. On 20th Jan, 2011 apbellamy said:
10th Jan, 2010 at 12:44:15am
That will depend on the material and its thickness. I seriously doubt it! |
10th Jan, 2010 at 12:49:53am
The dimple will have to be pointing upwards (into the engine bay) as it would catch the pedal box. |
10th Jan, 2010 at 12:52:10am
Paul do you notice the large amount of wiring in my dash. This is why i had to re do it (what a mess) |
11th Jan, 2010 at 08:18:52pm
a pic of my new loom. Had to make a new one as i would have had to heavily modify a std one.
11th Jan, 2010 at 08:21:06pm
Dads armchair? I seriously doubt it! |
11th Jan, 2010 at 08:23:20pm
Just sit him in front of him and let him go. ha ha |
14th Jan, 2010 at 08:46:52pm
My new clocks arrived today. |
14th Jan, 2010 at 09:22:01pm
i have the sport comp guages there a bit bright at night i have a switch to turn the backlighting off Crystal Sound Audio said:
elcome:)
