| Home > General Chat > One For John K - 7Port Head? | |||||||
559 Posts Member #: 2775 Post Whore Aberdeen |
10th Jan, 2010 at 07:33:51pm
I have just seen an adevert for specialist Components that mentions a new 7 port head out in Feb. Can we get any preview information? and maybe even an idea of cost?
297 Posts Member #: 2276 Senior Member sheffield / derby |
10th Jan, 2010 at 07:39:33pm
have a look here
1425 Posts Member #: 690 Post Whore Norfolk |
10th Jan, 2010 at 08:10:35pm
Sure, We want to bring a product to market which in complexity terms is a lot easier and quicker to do than the K conversion but offers a whole heap of the benfits of it.
If Carling made Mini engines
10th Jan, 2010 at 08:16:01pm
ooo I was wondering if anything new will be at Bingley... I run a supercharger and I don't care the TB is on the wrong side.
10th Jan, 2010 at 08:20:28pm
Probably a stupid question, but how do you machine water galleries into a solid piece of billet? Some very clever piece of machinery, that can bend into all sorts of weird angles?
10th Jan, 2010 at 08:29:27pm
good question - the yanks sometimes make the head in 2 or more pieces then weld the piece together and finish machine - I didn't fancy this option. So there is some very long drilling - from one side of the head to the other, at the heater tap end there will be a cover plate. Where the inlet ports would be on a 5 port there are drillings which go all the way to the edges of the chamber and pass through the long drillings going the other direction. Then there will be the std positions of water way on the A gasket which again meet up with the long drillings going through the head. The proto head will run thermocouples down the cross drillings to monitor temps around the chambers and ports.
10th Jan, 2010 at 08:30:34pm
cut in 1/2 and use JB weld to put it back together :) I run a supercharger and I don't care the TB is on the wrong side.
10th Jan, 2010 at 08:38:40pm
hehe If Carling made Mini engines
10th Jan, 2010 at 09:01:53pm
Thats it! I did a search too and could not find it. Thank you
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
10th Jan, 2010 at 09:20:00pm
so this is going to be a bolt on conversion then? sounds very interesting John!
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
61 Posts Member #: 1885 Advanced Member somewhere |
10th Jan, 2010 at 09:23:24pm
same really, bolt on? or is it a case for new exhaust manifolds and stuff. you said about the inlet...does that rule out webers etc? |
10th Jan, 2010 at 09:33:31pm
you will be able to use std exhaust stuff,
10th Jan, 2010 at 10:06:34pm
Here is my big question that I have been thinking about / contemplating with one of the other 7 port heads out there. I currently run a suck through supercharger setup. What I was thinking was to bolt it to a 7 port head. ie mount my current inlet manifold so that it is effectively trying to blow into a dead end, i would blank the manifold so I didnt have to rely on the gasket. Then make a new single outlet from the manifold that i blow through an intercoller then into a plenum at he fron with fuel injection. What do pepole think. I hope you understand what I am getting at? |
11th Jan, 2010 at 07:48:01am
John, have you considered an alloy 5 port at all?
I seriously doubt it! |
11th Jan, 2010 at 08:07:24am
On 10th Jan, 2010 lockfast said:
Here is my big question that I have been thinking about / contemplating with one of the other 7 port heads out there. I currently run a suck through supercharger setup. What I was thinking was to bolt it to a 7 port head. ie mount my current inlet manifold so that it is effectively trying to blow into a dead end, i would blank the manifold so I didnt have to rely on the gasket. Then make a new single outlet from the manifold that i blow through an intercoller then into a plenum at he fron with fuel injection. What do pepole think. I hope you understand what I am getting at? I have had similar ideas, but in my case that's way into the future. Sounds like the same principle as turboing a head like this. I think I will be keeping an eye on this head to see how well it performs and costs in comparison to the bike heads. On 11th Feb, 2015 robert said:
11th Jan, 2010 at 09:12:57am
Paul - I think the 5 port in alloy and cast iron is pretty well covered?
69 Posts Member #: 1670 Advanced Member |
11th Jan, 2010 at 11:11:35am
Looking forward to see the dyno results |
11th Jan, 2010 at 11:43:37am
On 11th Jan, 2010 johnK said:
Paul - I think the 5 port in alloy and cast iron is pretty well covered? JK Im not so sure I seriously doubt it! |
11th Jan, 2010 at 11:56:34am
I like the 7 port idea, but I agree with Paul W.
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
11th Jan, 2010 at 12:01:48pm
Any ideas germinating somewhere Paul ? Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
784 Posts Member #: 912 Post Whore North Yorkshire |
11th Jan, 2010 at 12:07:07pm
Here you go Paul.
I drill holes in everything..! |
11th Jan, 2010 at 12:32:44pm
Wouldnt it be possible to run a head from b series engine? Ive never had my hands on one but from the pictures they look really similair.
11th Jan, 2010 at 12:37:51pm
b-series heads are much bigger mike. If something is worth doing, it's worth doing half of. |
11th Jan, 2010 at 12:41:12pm
Even the best ported 5 port iron head can be improved upon if starting from scratch with billet I seriously doubt it! |
857 Posts Member #: 1778 Post Whore Northants |
11th Jan, 2010 at 12:47:20pm
A billet 5 port is top on my wish list for the miglia but i might have to make do with the cast alloy one that med do. |
