Home > Technical Chat > Solenoid Actuators
Ben H
Member #: 184
Melton Mowbray, Pie Country
Has anybody ever seen an electric solenoid used as an actuator? I was just thinking about boost control in different gears and at different RPM and what a pain it is to plumb into a pneumatic actuator.
For example if you have a 10psi actuator you can never run less than 10psi and the spring might not be strong enough to hold onto 25psi. However if you have a solenoid acting directly on the wastegate then you can just switch it on and off whenever you want from 0psi to infinity. This will obviously rely on having a separate electronic box of tricks, but this is no big issue these days.
Has anyone tried this? Am I overlooking an obvious reason why this is not done. Please don't say because if it fails you will overboost, because this is the same as a pipe disconnecting, which is all to common. Solenoids are simple electro mechanical devices, and in my eyes perfectly suited to the job.
Ben
http://www.twin-turbo.co.uk
I have beeen thinking about this as it looks particuarly applicable to VNT's,
The only problem with the solenoid is that it is effectly an on-off switch, although you can get some to oscilate at high frequency and achive some form of control by varying the frequency.
How about using a stepper motor. The stepper motor that I use for idle control off a peugeot can be bought for a few quid yet has a lot of potential. It winds in and out under control from the ECU.
The control would be a bit more complex but I would have thought it could be configured for a simple control circuit without a logic controller.
Just an idea.
I was also thinking about that Paul,
I have a cheap stepper RC motor on the way to me that I was going to have a play with,
I'll stick some of my thoghts down when I get home and get a beer in my mitts.
Taking both Joe and Paul's points, so far as I'm aware the modern turbo diesels with VNT use a stepper motor to move the guide vanes (the guide vanes being the VN* bit of the turbo).
My Mondeo TDCi piece of cr*p has a conventional actuator on the guide vanes but the year after mine used a stepper motor.
Not sure if a wastegate could be driven fast enough by a stepper motor though, or if a stepper motor could cope with the mechanical loads ???
Ben H
Member #: 184
I know what you are saying paul, but a normal actuator with either an electronic boost controler or a MBC is effectively a switch too. Think about 10psi actuator only seeing 15psi as the MBC opens, I bet it opens very quickly. So from a control point of view I can't see a problem. It will osscelate a little as normal actuators do.
Ok,
I came across this a while ago....
http://www.msextra.com/forums/viewtopic.php?f=67&t=18971
It enables a 4 wire stepper (such as the pugeot, ford or fiat idle stepper) to be driven from a PWM MS idle signal.
I was thinking at the time that it may enable me to control the VNT using an idle stepper from the megasquirt boost control map.
for conventinal wastegates I think the simple solenoid may work quite well working against a sprung wastegate, after all you can get fairly strong solenoids cheaply, i'd imagine an equivalent stepper would be pricey.
i think something like this could drive a solenoid, and in turn could have a pressure sensor pluged into the input rather than the pot. you may find that it oscilates though.
http://www.discovercircuits.com/PDF-FILES/SIMPLEPWM2.pdf
Edited by Joe C on 18th Feb, 2010.
But isn't wastegate control somewhat modular in so much that the actuator sets the wastegate position so that it achieves the set boost? It is not a simple open or closed situation, or is it?
I always thought that the wastegate actuator only opened the wastegate as far as it needed and then effectively modulated to control the boost.
yep, hence the 555 doing a voltage to PWM conversion above,
I'm thinking as boost rises a pressure sensor tells the 555 to increase the PWM signal, which in turn moves the solenoid,
In pracice it may well not wok like that though.
Would heat be an issue? I'm not sure how long a linear actuator would last if you stuck it next to a turbo.
Kean
Member #: 341
aka T2clubby
South Staffs
I've considered this in the past, you could have a long actuating arm to position the solenoid away from heat. Would be great to have so much control over boost.
Ben H
Member #: 184
Not to repeat myself, but just consider the MBC control, surely an open and shut case.
not quite Ben,
I belive the MBC itself is open or shut, but when it is open the actuator then works in a linear fashion from that point on.
That's what I thought. The MBC just fools the actuator which carries on doing a simple control loop but at a different boost level.
evolotion
Member #: 83
Glasgow, Scotland
my concern here would be exhaust gasses pushig the gate open, affecting asolenoid, a servo would be un affected. its quite a substancial force, especially if a small turbo is used!!
Denis O'Brien.
whats a wastgate hole diameter? about 3/4"?
that equates to 1.75 sq inches,
if we assume TIP= 2x boost, and boost = 20psi that means 70 lbs pushing against the solenoid/ servo *surprised*
Ben H
Member #: 184
This is what I don't understand. A 10psi actuator opens fully at 10psi, correct? So an MBC set to 15psi will operate the actuator like a switch. I can't see how a 10psi actuator seeing 15psi can do anything else. As soon as the boost falls below the 15psi the MBC closes and the 10psi actuator shuts fully. Where is the clever closed loop control here?
If you don't have an MBC then you get wastegate creep, which you don't want as it increases your boost threshold.
What does happen though is that as boost comes to the MBC setting the wastegate opens and the boost drops slightly and so the MBC closes, then the boost rises and the MBC opens again. This happens at a high frequency until enough gas is flowing to have the desired boost and the wastegate is fully open. I have seen this on logs that we have take. Well this is what I think is happening anyway.
My understanding is this:
A 10 psi actuator will, if set with the correct preload, control the boost at 10 psi. As boost rises to 10psi, it will start to open. As the wastegate opens exhaust gas will be bled off. The wastegate opening will reach a point of equilibrium where the amount of opening sustains the boost at 10 psi. As revs rise, it will open further to bleed of more gas but it may never fully open.
The MBC does modulate by only letting the actuator see enough pressure to hold the boost higher, but the wastegate will not open as far.
Ben H
Member #: 184
Is see what you are saying. If the 10psi is reached and the boost then increases the actuator opens further this reducing boost. However, if it open further then the boost will drop and the actuator will try to close again back down to its 10psi position. So it must also be to do with the pressure of the exhaust gas on the wastegate as well. Which makes it a much more complex system and difficult to replicate.
So if you wanted to use a solenoid you would need a multiposition one which is a stepper motor, which is not worth the effort.
A worthwhile discussion I think. I still need to improve the boost control on the TT though.
I'm a newbie to electronics, but I would have thought that there were ICs out there that would do the job.
Just thinking out loud, but you would need a MAP sensor, a reference voltage that you could control from a potentiometer, then an IC that would give an output to a stepper IC.
The MS drivesthe stepper with one of these:
http://www.allegromicro.com/en/Products/Pa.../2916/index.asp
There must be a way.
0.75 * 0.75 * 3.1418 / 4 = 0.44
So about 9lbs at 1*TIP.
These Peugeot steppers are heavy little beggars with a worm/rack gear type output capability, so may do it.
Edited by Paul S on 18th Feb, 2010.
huh?
where does the /4 come from?
jbelanger
Member #: 831
Montreal, Canada
It's radius squared not diameter.
Jean
http://www.jbperf.com/
DOH!!
what a berk...
