| Home > Help Needed / General Tech Chat > Simple Fuel line question | |||||||
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
16th Jan, 2005 at 08:45:26pm
I am running my fuel lines inside the car, the question is should I go over or through the cross member??? As I said simple. |
16th Jan, 2005 at 09:05:41pm
I went over on mine i was lazy and i broke my drill! I wanted the fuel filter mounted on top of the cross member by the hand brake nayway Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
![]() 1014 Posts Member #: 238 Post Whore essex |
16th Jan, 2005 at 09:53:46pm
i ran mine under the crossmember, as the holes were already there, looks neater aswell!!! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
421 Posts Member #: 245 Senior Member |
16th Jan, 2005 at 10:12:10pm
straight through the crossmember,less bends the better. |
16th Jan, 2005 at 10:58:28pm
well it's 2 to 1 in favour of going through the crossmember at the moment. |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
17th Jan, 2005 at 08:41:00am
Mine run through the crossmember.
339 Posts Member #: 399 Senior Member Austria |
17th Jan, 2005 at 10:55:52am
Also through... |
17th Jan, 2005 at 12:06:32pm
Mine run over, but I wish I'd put them through, can't be arsed now.
216 Posts Member #: 370 Reads "my mates" max power whilst wearing my Mrs's underwear |
17th Jan, 2005 at 12:53:13pm
i was gonna run mine inside i was worried about if crash and it all caught fire inside... |
17th Jan, 2005 at 01:08:37pm
Im putting mine through |
17th Jan, 2005 at 02:18:03pm
Under the floor! On 17th Nov, 2014 Tom Fenton said:
17th Jan, 2005 at 02:49:58pm
Nah thats too easy |
17th Jan, 2005 at 03:25:52pm
Why run them inside the car? I could understand the benifits if it was a rally car, but a track or road car - i just dont get it... |
17th Jan, 2005 at 07:00:48pm
Looks like through is the winner then, cheers people |
17th Jan, 2005 at 07:56:38pm
im doing it to put in my bias valve/gauges easier.
17th Jan, 2005 at 09:55:15pm
And it's more aerodynamic! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 2641 Posts Member #: 19 Post Whore newcastle |
17th Jan, 2005 at 10:01:41pm
i knew there was a reason ... cheers wil h Everyone knows that instructions only have to be read if the thing doesn't work....
![]() 48 Posts Member #: 349 Member Lutterworth |
17th Jan, 2005 at 10:11:17pm
What fuel lines are you running, braided or cooper |
17th Jan, 2005 at 11:41:58pm
im just using bog standard 8mmn rubber hose running through the bulkhead, down along the exhaust tunnel in the centre, straight through the heelboard into boot and up to top of tank Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
18th Jan, 2005 at 12:23:19pm
Im going to use a mixture of copper and braided and rubber lined P clips |
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
18th Jan, 2005 at 03:34:48pm
i will be going through the cross member, only running inside the car becouse it seems harder to mount it to the floor under the car than runnthem inside, lol
18th Jan, 2005 at 04:15:41pm
ill see if i can. its never cheap though. |
18th Jan, 2005 at 05:17:25pm
did not expect cheep, lol but i think i can get 'cheep' rubber fuel line i will waigh up the difference in cost tho i do think the rubber will win.
18th Jan, 2005 at 06:36:38pm
can you get 8mm copper tube and fittings
18th Jan, 2005 at 06:49:37pm
8mm copper tube is about ?10 for 10m, just go to B&Q or a plumbers merchants and get some 8mm microbore, bends pretty easily too. On 20th Oct, 2015 Tom Fenton said:
