Home > Help Needed / General Tech Chat > shorter oil filter
is there an oil filter thats a bit shorter that will fit the mini filter housing and still give good filtration?
Whats your maximum height measuring down from the face of the filter head?
Ill measure the one I use which is shorter
there's a smaller one,
I'm pretty sure its a 4x4 cossie one.
I know the 16v Renaults use a short filter as I use one on my 205, however not sure if its the same thread as the Mini one.
honda civics have surprisingly stubby filters
Scruffy
Member #: 328
Seaford Rise, South Australia
Ford KA Halfords own 263/4/6 ones of these look it up. The champion one is longer and the same as a Mini but their own one is what I use as i have a sandwich plate cooler
On 5th Sep, 2011 Vegard said:
renault clio dci's also have very short filters, did one the other day
Scruffy
Member #: 328
HOF264
good info scruffy,
fords often (always?) have the same filter thread as minis, xr3i's had the same water to oil cooler as the metro.
Is this still the short filter to use? I have a sandwich plate stat and need a little one and mine is too long and hits the cross member...
Thanks all
appears that there are two HOF264... a viltron branded version that is longer and a halfords branded version that is much shorter... both have the same HOF264 part number.
Halfords branded filters will be shit
They don't fit anyway... Some tape and filing required...
welshdan
Member #: 1111
s wales
tape? fuck that!
Smaller filters will be just that, smaller. Its maybe suggesting replacing the filter twice as often if you have to use one.
Andy is right, the halfords filters are shite. The can might be the same size as an OEM filter, but the paper element inside is much smaller. I ahev cut various filters open before now and I have always found the OEM branded filters to have a much larger element than any of the after market brands. It is beneficial to pay a bit more for a filter.
So no bits get into the filter housing, I will need to make a small notch out of the cross member
On 22nd Jan, 2014 welshdan said:
tape? fuck that!
Ok I have had the file out tonight and made a small notch so the filter can clear the subframe.
Your not wrong on the Halfords filter I pulled out a lump of glue whilst use in gone for the mock up.. Not good.
Will have to look for an oem
graemec
Member #: 1424
Carnforth, Lancs
Can you not get an adapter for the block and then use a remote filter?
I don't have much space, it's all sorted now.
evolotion
Member #: 83
Glasgow, Scotland
And the solution was?
Denis O'Brien.
A small notch in the subframe so I can spin the filter on. I have ordered some better quality short filters
Just found this useful reference page on the Fram Europe website
http://www.sogefifilterdivision.com/catalo...me=V&figure=301
Untitled by g19asn, on Flickr
JT
Member #: 637
Hertfordshire
http://m.ebay.co.uk/itm/WIX-FILTERS-WL7064...1101?nav=SEARCH
Is this the one you used in the end?
My build thread..
Yep I change it more often
