Home > Help Needed / General Tech Chat > FFS - the head gasket is blown AGAIN!!!
MrOz
Member #: 5007
Crazyhill, Livi
Right - I'm getting really pissed off and getting to the end of my tether with this FI lark.
I've managed to blow a head gasket again.....
Just a couple of questions....
Should I go for the AF470 or BK450
Also, gonna get the head pocketed - how do I work out how much material to remove?
Sorry about the leading comment - it's been a bad day..... i don't mean it - I'm lovin' the boost.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi."
head pocketed?
MrOz
Member #: 5007
Crazyhill, Livi
Sorry - combustion chamber enlarged.......
You need to remove the amount of material required to give you the compression ratio you desire.
are you torqeing the headto 55 ft pounds ?
are you sure! that the engines not running into detonation ...ie mixture not right .. too lean and or ignition timing too advanced for the fuel you are running
whats the CR you running and the boost your running ? have you an intercooler ? whats the engine short spec ?
MrOz
Member #: 5007
Crazyhill, Livi
kk - how do I work this out?
The Standard CC for a 1275 head is about 21cc (ish) is this still the same for the MPI?
Edited by MrOz on 25th Mar, 2010.
21.4cc is "standard" but they can vary quite a bit. On another note, the gaskets don't usually blow for no reason. As Benross said you could be getting detonation which is taking the gasket out, incorrect head torque, poor or old studs/nuts, head warped etc
Edited by Turbo Phil on 25th Mar, 2010.
BK450 and AF470 are basically the same.
The fact you are even suggesting opening the chamber up to try and stop head gaskets blowing...leads me to suggest you take the car to someone who knows what they are doing.
Andy500
Member #: 2443
Cheshire
Is this an M45 supercharger set up? If so check the charge temps and boost pressure, you will probably find temps are sky high and boost is higher than expected also......ala detonation
MrOz
Member #: 5007
Crazyhill, Livi
Yeah, the last time I replaced that head gasket - torqued to 55ft/lb.
According to Stuart Gurr the CR is 8.5:1, not using an intercooler - Vmax Chargecooler system. Short engine specs are MPI standard.
I'll need to investigate the dentonation question
If I can work out the amount of materal to be removed from the head, I'll be able to get the techs at my old college to do me a favour (hopefully) if not there are a couple of good engineering firms in my area that should be able to do it.
Yeah, it's the Vmax MPI150 kit - the boost gauge was reading 0.8 bar - not sure about the temps - I'll check this soon as possible.
And thanx once again for the great info/help.
Assuming that the engine is a standard MPi engine and the head is a standard chamber, you are running a decompression plate?
Andy500
Member #: 2443
Cheshire
My money is on detonation. I bet your seeing charge temps in excess of 90 degrees C!
MrOz
Member #: 5007
Crazyhill, Livi
Yeah, again accoring to Stuart Gurr - two head gaskets and the decompression plate add 12cc.
I'll check that once I've got the Mini up and running again.
I'm gonna be using the decompression plate again - until I have enough money to sort things properly.
nibble36
Member #: 4273
stoke on trent
mate of mine had got a vmaxscart supercharger and head and he call my house lsat night car running like bag of shit we did a compresion test and nothing on 2 and 3 so head gastek has gone this is the second time its happend in 6mth
he useing 2 head gastkets and a decompresion plate... hes not happy chat
going look at the head when he gets it off se what cc it is and go from there
good luck with yours mate
MrOz
Member #: 5007
Crazyhill, Livi
Cheers fella - like wise with your mates.
Why not just have the thing tuned properly ?
its a bit extreme to start butchering cylinder heads when it could probably be resolved much easier.
Have you had the block refaced? I just decked a block and it needed 4/10mm to become straight. They sink between number 1 and 4 it seems.
Andy500
Member #: 2443
Cheshire
MrOz
Ive been running the same kit for the past 3 or 4 years. Ive spent a hell of a lot of money and time getting it right and spent a lot of time at Emerald with Dave Walker on the rollers. Not sure if yours is the same but mine ran a recirc of the bottom of the charger to drop the boost. With a standard mpi bottom pulley and standard bini charger pulley the charger created 18psi without the recirc and abut 14 with it! Have you fitted a map sensor. I installed one and stuck the IAT sensor in the inlet manifold..... In the end i had a new supercharger pulley made to drop the boost. It now runs 8psi without the recirc and only lost 2hp over what it produced at 18psi!!!! shows how inefficient the chargers are! Ive only ever taken 1 hg out but fooked a piston crown and pinched a ring when before it was sorted. When it was at 18psi the charge temp hit 110 degrees C!!!!! it was hotter than the coolant in the engine!
where abouts do you mean exactly Ve? between the cylinders?
Yes, that's what I mean.
Hmm. I better check my block before I build it up then *smiley*
mine is definitely going for a skim before i rebuild
From what I have read the Accralites I have sit about 0.6mm down the block so I have a bit to play with.
Did you say your Omega's sat 0.5mm down?
Doesn't the re-circ valve help with the over-run so you don't stall the car when coming to a stop from boost?
On 26th Mar, 2010 Andy500 said:
MrOz
Andy500
Member #: 2443
Cheshire
No the eatons have an internal recirc for this. The recirc that vmax fits is basically a bleed off the outlet of the charger.
