| Home > Help Needed / General Tech Chat > cinquecento rads | |||||||
12th Apr, 2010 at 08:40:38pm
i know there are a few guys running these, they must be up to the job, is it just the boggo std 1,1l rad to look for? Yes i moved to the darkside |
12th Apr, 2010 at 08:48:27pm
I believe mine was off a ~'96 1.1 Sporting. I'll check ebay for the one I got now
Edited by GaryOS on 12th Apr, 2010. On 12th Nov, 2009 Paul S said:
Gary's description is best |
12th Apr, 2010 at 08:51:50pm
yep, all the rads are the same,
12th Apr, 2010 at 08:55:38pm
i was having a look on ebay couldn't believe the price :) do these rads have 3 ports then or is it 2 and something else? Yes i moved to the darkside |
12th Apr, 2010 at 08:58:39pm
two ports at one end like the Mk1 metro rad and a small "vent" pipe at the other end,
12th Apr, 2010 at 09:00:43pm
i think im going to splash out :) lol, just made some brace bars to clear the std side mount too,
Edited by Brett on 12th Apr, 2010. Yes i moved to the darkside |
12th Apr, 2010 at 09:01:23pm
The other one is just a weird mount. I didn't use it on mine as there are plenty of options to fix them. I will probably cut it off. They do have a fan switch hole which I am using
12th Apr, 2010 at 09:11:06pm
there does appear to be 2 types one is 44mm taller according to a seller on ebay Yes i moved to the darkside |
12th Apr, 2010 at 09:13:08pm
I think the core of mine is ~270mm tall. The total height of the centre section is ~290mm On 12th Nov, 2009 Paul S said:
12th Apr, 2010 at 09:19:28pm
i think the seicento one might be a bit bigger than the cinq one. On 28th Aug, 2011 Kean said:
64 Posts Member #: 8372 Advanced Member wickford , essex |
12th Apr, 2010 at 11:10:39pm
might treat myself to one of these ! :) |
12th Apr, 2010 at 11:21:56pm
p.s what kind of fans do you guys run on these ? how do they work with clearance on the altenator ? :)
12th Apr, 2010 at 11:37:18pm
I have a 7" ebay fan which doesn't look like it will fit at all On 12th Nov, 2009 Paul S said:
15th Apr, 2010 at 10:57:10am
anyone got any pis of one of these fitted please ?
15th Apr, 2010 at 11:46:24am
i bought a mk2 fiesta header, if you search cinq rad there is a couple build threads Yes i moved to the darkside |
15th Apr, 2010 at 11:50:07am
I am using one of the tanks that Demon Rweeks sell, except I didn't pay 8 million euro for it. It has two 32mm pipes, perpendicular to each other
15th Apr, 2010 at 01:16:02pm
i bought a cinq tank for a fiver On 28th Aug, 2011 Kean said:
15th Apr, 2010 at 01:19:54pm
I just got a brand new Cinq rad for £24.50 off eBay.
15th Apr, 2010 at 01:22:24pm
easy,
15th Apr, 2010 at 01:50:56pm
On 15th Apr, 2010 John said:
I just got a brand new Cinq rad for £24.50 off eBay. Just gotta figure out how to plumb it all up in my car now. It's apice of piss really
That is with an electric waerpump. I'm not certain it will work but somebody here will clarify Edited by GaryOS on 15th Apr, 2010. On 12th Nov, 2009 Paul S said:
15th Apr, 2010 at 03:43:00pm
Here's a very old pick of mine.
15th Apr, 2010 at 03:44:57pm
And with fan on. I had to space the grill out an inch or so, and put a slight curve in the grill.
15th Apr, 2010 at 03:57:54pm
Mine is plumbed in like this, with an electric pump though. When using a mechanical pump, I put the heater feed from the bottom rad hose to the expansion tank, then the bleed from the top of the expansion tank to the top of the rad (little outlet pipe). I used a VW expansion tank.
Edited by matty on 15th Apr, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
15th Apr, 2010 at 06:51:12pm
I thought you had seen the light then and gone back to a 5 port |
![]() 209 Posts Member #: 6451 Senior Member South East Northumberland |
18th Apr, 2010 at 08:40:23pm
It's good to here these are capable of handling more heat than I'll need - got one going in here:
t=1212854542
