| Home > Help Needed / General Tech Chat > Engine Running Question | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
1st May, 2010 at 01:29:26pm
Hi
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
1st May, 2010 at 03:32:28pm
Coilpack, wasted spark, EDIS - what have you fitted ?
1st May, 2010 at 03:48:24pm
Are you sure it's ignition related and not fuel? On 11th Feb, 2015 robert said:
1st May, 2010 at 04:26:28pm
Having spoken to Neil at Slark he has said it definately is not the fueling.
2nd May, 2010 at 09:39:32am
Hi
2nd May, 2010 at 08:54:09pm
Jon.
2nd May, 2010 at 09:46:29pm
Hi
2nd May, 2010 at 10:03:25pm
Also can you post up a link to to the capacitor I would need to buy?
4th May, 2010 at 01:02:58pm
Jon.
4th May, 2010 at 09:17:01pm
I had the same issuse when I first fitted the MJ it would die and the rev counter drop to 0..
10th May, 2010 at 07:16:30pm
Hi
10th May, 2010 at 08:28:55pm
Jon.
10th May, 2010 at 08:55:23pm
Hi
10th May, 2010 at 09:38:57pm
if all else checks out in the electrical department ok, then any misfires
11th May, 2010 at 07:16:08am
Excellent - I am pretty sure the electrics are ok, with the exception of the trigger wheel timing which I will get checked so hopefully it is just down to a fueling issue.
11th May, 2010 at 03:17:28pm
Slarks have been doing some testing and the is very little load reading coming from the TPS.
11th May, 2010 at 03:41:35pm
A TPS is fed with 5V constant and ground on two of the three pins. So one will be a constant 5V and the other a constant 0V. The third pin "reads" the position so registers between 0 and 5V as the throttle is moved.
11th May, 2010 at 03:51:06pm
OK -
11th May, 2010 at 04:47:06pm
Is this a turbo?
11th May, 2010 at 05:02:47pm
You shouldn't be trying to measure what comes "out" of the MJ.....
Edited by Rod S on 11th May, 2010. Schrödinger's cat - so which one am I ??? |
11th May, 2010 at 08:31:30pm
I've just tested the TPS with the following results:
Edited by jonb_5 on 11th May, 2010. |
11th May, 2010 at 09:43:31pm
I've just found this link which suggests that C is 5V.
11th May, 2010 at 09:59:16pm
What plugs are you using? On 26th Oct, 2004 TurboDave16v said:
12th May, 2010 at 04:27:42pm
Not sure what plugs they are but they were knew last time it was rolling roaded.
12th May, 2010 at 05:55:47pm
On 11th May, 2010 jonb_5 said:
I've just tested the TPS with the following results: Measuring resistance, meter on the following pins: A-B -> Resistance goes from Low to High B-C -> High to Low Based on that would you think the following pin outs... A=5V B=Signal return to MJ C=0V Cheers, If when you say "goes from low to high" etc, you mean "goes to" as the throttle is openned, then no, A and C other way around. B is obviously the signal out so if B-C is low resistance with throttle open, C is the 5V input from the MJ power supply (to make the signal (B) 5V with throttle open) Your next post seems to suggest you have a photo agreeing with this. EDIT - at least your tests show the TPS is tracking the resistances from low to high as it should, so check your 5V, 0V and signal wires now match and check the MJ is providing 5V at C and A is 0V... Edited by Rod S on 12th May, 2010. Schrödinger's cat - so which one am I ??? |
