Home > Show Us Yours! > My attempt at subframe lightening
Just slightly holey :) much more to come :d
Edited by Paul R on 22nd May, 2010.
looks good so far any ideas how much weight you lost?
tbh im not sure im going to weigh it next to a bare std subby when im finished with it.
Things to do next on it is more holes on the rear as thats still quite heavy, seam weld it, add some supports at the front rear and on the tie rod mounts
that'll flex nicely with 200hp going through it*happy*
I have been adding weight to mine today, tommorow to finish off the welding
well others have done the same and i dont have a flipfront and will be adding braces to it as well so hopefully wont to much =/
how much would this practice affect rigidity?
Considering that the chassis is weakened by putting in a bulkhead box is it really a good idea bar the out and out racers?
ahh beaten to it slightly by colin
Edited by wolfie on 22nd May, 2010.
The standard subframe I fitted last year is bent where the tie bars fix and I have dyno footage where you can see the front end flex. Its a welded front, but no inner wings and no brace bars, but if it flexes that much in standard form, adding lots of holes is not going to help much.
I personaly have been adding gussets ( *hehe!* ) all over the frame and seam welding where there is none
Edited by Sprocket on 22nd May, 2010.
mines braced as well i did it because of the bulkhead box
well i will see when its done what its like, it seems alot of people have done it and its not hampered them that much. i want to add brace bars but not use inner wings make some sort of frame insead idk if anyone has done that before
jamz
Member #: 2292
Tool
Herne Bay, kent
mines seem weldeds with a few holes in and then bracing either side of the tie rod mounts and extra triangle bracing on the turrets
cant beat a good blowout.
does yours flex alot?
Jackman
Member #: 984
Westhoughton, Bolton
Sprox, any pics of what your doing?
Manchester Minis
Ive been busy, heres a peek.
lower subframe brace?
I used to have lower brace on my mk1 gti sharpened up the handling no end, never thought about it on the mini
Mike you teaser!
looks a bit transplantesque to me....
Show em your meat Mike
Is the large chunk of flat steel heaver than all the tube you replaced it with?
What about triangulation for the towers?
Teeheehee
lol
jamz
Member #: 2292
Tool
Herne Bay, kent
mine doesnt flex as far as im aware. its feels fucking rigid lol
Mine deffinately doesnt flex.
longy
Member #: 2727
Bicester
ooooh mike you've been busy, i like
1972 998 TURBO SLEEPER
Come on then, how much does it weigh?
