Home > Help Needed / General Tech Chat > Can't get the bloody hub nut off!
Cooper1999
Member #: 6451
South East Northumberland
As it says really - I'm changing the discs and I can't get the drivers-side nut off.
Tried using the search - I guess no-one else has had this problem!
Is this my excuse to buy a compressor and impact wrench, or do I just need a longer graunch bar?
Any suggestions welcome!
Fire!
longer bar, wd 40,
tru undoing it with the wheel on and on the ground, you want a 3ft bar, baybe with a tube over it to make it longer,
if it still wont budge slit it off with a hack saw blade
Rick.SPI
Member #: 8027
i use an old exhaust middle pipe on the end of my rathcet lol!
have you taken the split pin out lol *tongue*
Edited by Rick.SPI on 1st Jun, 2010.
You say drivers side... is it one of those foreign cars with the steering wheel on the wrong side? lol
Edited by matty on 1st Jun, 2010.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Graham.
You wuss, just get a 5 ft scaffold pole on a decent breaker bar, put the wheel & tyre back on the ground with the centre cap out, get yer misses to apply the footbrake and 'crack it off', as they say.
Good luck buddy.
Richard.
chinlesswonder
Member #: 1192
In the garage......again!!
righty tighty, lefty loosey!
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Oli
Member #: 1910
Wilts
Graham, i've got a 38" breaker bar if you want to borrow it?
I had the same problem I snapped the end off my old torque wrench.. I used this peice of shite.. but it worked a treat however I'm sure I only paid £19.99??? looks like they have out the price up since
http://www.argos.co.uk/webapp/wcs/stores/s...s=IMPACT+WRENCH
makes this look a good price..
http://www.machinemart.co.uk/shop/product/...c-impact-wrench
Are you sure? I thought that the hub nuts were right & left handed, although there's a nagging little voice at the back of my head that says I got it the wrong way round.
Cooper1999
Member #: 6451
On 1st Jun, 2010 turbominivanman said:
get yer misses to 'crack it off'
I should be so lucky *happy*
Split pin out, steering wheel in the right place (last time I checked!), and I should say I've got a 'Y' tool thats retained by the wheel nuts on the studs which 'digs' into the ground, so don't need to put the wheel on/stand on the brakes.
As for being a wuss - yeah you're probably right *happy*, but I was lifting the front of the car from the axle stands when I tried starting at the 3 o-clock position, rather than the 9 o-clock.
I'll soak the nut in WD40 as advised and let it soak in over the weekend while I work on a car thats already in bits!
I'll try the bloody great graunch bar/heat as well!
Thanks all *Yes*
Cooper1999
Member #: 6451
Rob - the passenger side (LEFT *wink* ) is definitely a right hand thread (anti-clockwise to remove) - this would be left hand thread if it was to self tighten, wouldn't it?
I know the trucks at work are handed but I'm sure the mini's aren't, so as chinlesswonder says.
ETA Thanks Oli - might take you up on that after the weekend.
Edited by Cooper1999 on 1st Jun, 2010.
chinlesswonder
Member #: 1192
treat them both as normal nuts, looking directly at them its anticlockwise to undo.
They are not lefthand thread as some people seem to think.
ive had it before where the wheel spins rather than the nut undoing, i had to wedge the brakes on, wheel on the ground and me standing on my 1m breaker bar balancing my self from the wing it came of with a good crack
theres a lot to be said for drilled disk, a reea handy place to jam a quality screwdreiver,lol
Passenger side rear hub nut is left handed thread.
miniman899
Member #: 5252
essex
i had this problem both sides on mine i put the wheels back on put it on the ground and used a breaker bar with a lenth of exhaust and got my dad to stand on the brakes came off quite easy then .the 6ft lever helped*smiley*
evolotion
Member #: 83
Glasgow, Scotland
amateurs. 4mm drill bit straight down the low parts (where the spit pin would sit) 180 degrees apart.Then one swift blow with a cold chizel .. obv this requires a new nut, mine used to always weld themselfs on :(
Denis O'Brien.
an impact gun, apparently able to do 225ft.lbs is the current weapon of choice :)
Try that on the Left (i don't know my left from my right) rear *hehe!*
Edited by Sprocket on 2nd Jun, 2010.
Butcher, lol. Use a 3/4" drive 4ft breaker bar with the car on the ground wheel chocked and the wifie pressing for all her might on the brake *hehe!*, works for me everytime. On the other hand, I have had some front hub nuts you can wind off by hand after removing the split pin, some one elses bad job.
MrTurbo
Member #: 814
Utrecht, The Netherlands
Air impact gun works perfect!
Asphalt
Member #: 1027
Germini, black forrest
If everything else fails *wink*
[X] nail here for new monitor
metroturbo
Member #: 989
North Yorkshire
I have the same as the argos one and I have been surprised how good it actually is. I only paid around £12 for it a couple of years ago, and it has been worth it weight in gold.
DO NOT use the impact wrench to tighten the nut!!!
