| Home > Technical Chat > Drilling drums and discs | |||||||
520 Posts Member #: 2093 Post Whore Grenoble, France |
29th Jun, 2010 at 10:42:08am
Edited by alpa on 29th Jun, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
29th Jun, 2010 at 10:48:09am
well you can get off the shelf drilled and groved disks and i gont see why you couldnt drill a drum but im not sure i would want to Drives
29th Jun, 2010 at 11:00:35am
Why not ?
29th Jun, 2010 at 11:03:32am
well concidering where the drum has its frection plate there arent many places you can then drill to save enough weight to make it worth while and still be safe and not failing on you Drives
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
29th Jun, 2010 at 11:39:19am
just get some superfin drums and drilled and grooved discs, this way you know is going to do what you want, and your discs and drums shouldn't crack on you! |
29th Jun, 2010 at 11:41:26am
Drilling is not to save weight, it's to improve cooling and dust/water evacuation.
29th Jun, 2010 at 11:42:14am
Where do you find superfin drums ? std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
29th Jun, 2010 at 12:59:14pm
mini spares and lots of other sites, they are alloy finned drums to help cooling :) Drives
29th Jun, 2010 at 01:47:03pm
On 29th Jun, 2010 alpa said:
Drilling is not to save weight, it's to improve cooling and dust/water evacuation. Most of the drum weight is in the center plate. Water evacuation? If there aren't holes, water wouldn't get in in the first place
29th Jun, 2010 at 01:48:44pm
On 29th Jun, 2010 Vegard said:
Water evacuation? If there aren't holes, water wouldn't get in in the first place ![]() It would. It seems to be a quite common problem on old cars. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
29th Jun, 2010 at 01:49:43pm
On 29th Jun, 2010 Paul R said:
mini spares and lots of other sites, they are alloy finned drums to help cooling :) Sure, alloy. A bit expensive. Much more than drilling few holes. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
29th Jun, 2010 at 01:52:53pm
you need to apply the simple formula
29th Jun, 2010 at 03:23:42pm
maccamcvey
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
29th Jun, 2010 at 03:44:35pm
My guess was
In boost we trust |
29th Jun, 2010 at 04:57:19pm
Serious guess :) .
388 Posts Member #: 442 Senior Member Manchester |
29th Jun, 2010 at 07:34:58pm
I dont see the point! The only reason you would want to modify the original drums is to save weight. Any form of drilling the drums will only weaken them.
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
29th Jun, 2010 at 08:00:24pm
grooved and drilled discs are not that expensive and can lightened drums make up for the extra weight a 165 tire carries vs a 145 ?
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
29th Jun, 2010 at 10:08:09pm
Why not to buy alloy drums and grooved discs ?
29th Jun, 2010 at 10:28:47pm
BAC |
29th Jun, 2010 at 10:29:04pm
on tmf? |
29th Jun, 2010 at 10:29:19pm
BAN?. |
29th Jun, 2010 at 10:31:56pm
why not, if the pro's out weigh the con's in your eyes then the benefits are seen in your eyes
Yes i moved to the darkside |
29th Jun, 2010 at 11:42:00pm
So far the only con argument was that drilling would weaken drums. That seems to be exactly the same argument that was used 50 years ago in the US. I still don't see how a few 20 4mm holes would weaken the drum.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
30th Jun, 2010 at 12:35:38am
maybe if you drilled them in at an angle so they self vent?
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
30th Jun, 2010 at 01:56:18am
I still don't see how a few 20 4mm holes would weaken the drum. Well I'll see. Well i dont see how a few 20 4mm holes could streghten a drum(which go out of true all the time). Or improve a drum ( which may be adequate, if no dust getting in the holes, if no water getting in the holes) |
