| Home > Technical Chat > 16V K headed turbo, race engine, need for restrictor | |||||||
28th Sep, 2010 at 08:22:50am
As you know from my project thread I am building a "proper" racecar based on a 1970 shell.
Edited by miniminor63 on 28th Sep, 2010. |
28th Sep, 2010 at 05:09:20pm
obviously there are many considerations, but the obvious one to me would be the entrance to the turbo surely isn't much more then 32mm. I'll go measure my gt17.
Edited by minimole23 on 28th Sep, 2010. On 7th Oct, 2010 5haneJ said:
28th Sep, 2010 at 07:01:13pm
32mm square restrictor aloud? Yes i moved to the darkside |
28th Sep, 2010 at 07:50:56pm
a round 32mm turbo restrictor is a world rally group N requirement. The restrictors are fitted on the inlet side, and yes, certain turbos have an inlet not far off 32mm.
28th Sep, 2010 at 08:30:05pm
Thanks for the thoughts guys!it is the same as group N restrictor yes. It should be put close to the inlet but no stringent rule on how close. Edited by miniminor63 on 28th Sep, 2010. |
28th Sep, 2010 at 09:10:48pm
You could get clever and do what Toyota did. I heard that the modified restrictor was so clever that it passed all FIA scrutineering for several events, and wasn't until a changed out turbo unit was inspected by scrutineers on a service stop, that something was thought to be not quite right.
28th Sep, 2010 at 09:19:30pm
PMSL!!!
29th Sep, 2010 at 06:20:24am
lol.
29th Sep, 2010 at 07:55:30am
well to make 200bhp (150 x 1.343) you'll need 22 lb/min. Depending on what rpm you make this at you'll need around 16 to 20psi boost.
29th Sep, 2010 at 10:34:18am
The restrictor will not impose a maximum limit on the flow until the velocity goes supersonic. But it will produce a pressure loss at the compressor inlet that will severly restrict its performance throughout the power range.
29th Sep, 2010 at 01:02:58pm
Thanks Paul!
29th Sep, 2010 at 01:15:50pm
On 29th Sep, 2010 miniminor63 said:
Thanks Paul! Would it have any impact on the compressor other than making it work harder due to a larger Pressure relation? The pressure ratio of the comressor will be artificialy higher than it would without the restrictor, so selection of compressor will be important, well on big motors at least
29th Sep, 2010 at 02:03:38pm
The problem is that the performance of centrifugal machines, like the turbo compressor, are affected once the absolute pressure at the inlet goes below a certain value.
29th Sep, 2010 at 02:10:24pm
hmm, food for thought. Maybe it would be a good idea to go to someone with vast turbo engine and turbo selection knowledge and ask them for turbo selection advice... I am able to read and understand compressor maps, but this adds another dimension...
30th Sep, 2010 at 01:11:53pm
okay, here is the current plan (funds permitting):
30th Sep, 2010 at 01:16:52pm
Are you sure that the improved efficiency of the higher CR is going to offset the lower calorific value of the E85 ???? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
30th Sep, 2010 at 01:18:52pm
As I wrote in another post:
I am just of the phone with one of the larger turbo/turbo engine experts in Norway. We talked a while about putting a turbo on my K16V 1343 cc engine. I told him that I would need to run a 32 mm restrictor (due to class regulations) he knew about that as he is already competing in the extreme class in the same series, with a audi S1. He asked quite a few questions about current engine spec, things like cams, CR, pistons, volume, max rpm and the like. I then asked him what he wanted the CR to be, if I should be running with a turbo. He wanted it to stay where it is, at 12:1. It would be fine if we ran it on E85 and played a little with cam timing. I think this sounds quite extreme, is it at all possible? He would then aim for around the 230 hp mark with max rpm around 7500. I pretty much outline the above spec to see what you guys responded. But seeing as all the high CR high boost people at least here in Norway prefer E85 over race fuel I think it is a safe bet. I have not done any calculations on it myself. The guy I mentioned above told me directly on the phone: "If you are not thinking about using E85 on such an engine, we do not need to talk anylonger :)" Are you skeptical about the gain Paul? one would typically run quite a bit richer on E85. Edited by miniminor63 on 30th Sep, 2010. |
30th Sep, 2010 at 01:27:23pm
I am sceptical until I've done the sums.
30th Sep, 2010 at 01:38:22pm
stochiometric AFR for E85 is 9.75 |
30th Sep, 2010 at 01:38:33pm
Well, apparently E85 gives maximum power at an AFR of about 7:1, so you should be on to winner.
Edited by Paul S on 30th Sep, 2010. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
30th Sep, 2010 at 01:40:47pm
lol, you beat me to it! Edited by miniminor63 on 30th Sep, 2010. |
![]() 6752 Posts Member #: 828 Post Whore uranus |
30th Sep, 2010 at 03:47:45pm
On 29th Sep, 2010 Paul S said:
The restrictor will not impose a maximum limit on the flow until the velocity goes supersonic. But it will produce a pressure loss at the compressor inlet that will severly restrict its performance throughout the power range. . if a restrictor flows enough air to supply 100 bhp .then at 100 bhp and below ,the restrictor would not ''restrict''.. its effect will only be there once the demand for air outstrips the capacity to supply it . so instead of a ''restriction throughout the power range '', id say there would be an increasing level of restriction ,the higher the air demand , starting from when the orifice size becomes too small . its possible to find out the cfm flow for a orifice at 25 '' h2o pressure drop ,and then see when it would start to effect power .id then design the engine to create as much torque as possible below that point .then gear accordingly to utilise that torque . bhp will probably remain fairly level ,after that ,because as the rpm rises ,the flow becomes more restricted . ah the wrc cars apparently have a 34mm reducer ,and make just over 300 bhp .... so they must suck like mad on that little hole ! Edited by robert on 30th Sep, 2010. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
30th Sep, 2010 at 07:03:02pm
when talking about how rich the fueling should be with E85 it is easier to understand if you use Lambda instead. One reason why VEMS uses a Lambda target table instead of an AFR target table (lots of Sweeds use E85 and lots of Sweeds use VEMS). Its only the VE table that then changes, as the fuel demand is much higher. You will need to check the demand on your injectors. On 26th Oct, 2004 TurboDave16v said:
30th Sep, 2010 at 07:27:14pm
On 30th Sep, 2010 robert said:
its possible to find out the cfm flow for a orifice at 25 '' h2o pressure drop ,and then see when it would start to effect power .id then design the engine to create as much torque as possible below that point .then gear accordingly to utilise that torque . bhp will probably remain fairly level ,after that ,because as the rpm rises ,the flow becomes more restricted . I incorrectly stated that it would "severly" restrict flow through the power range, but check out the Bernouli: It will affect the flow from zero flow upwards, but it will be negligable to start with, then rising at the square of the velocity. It will not suddenly start to restrict above a certain flow but the impact will build gradually, getting to a point where it will seem like it has hit a brick wall. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
30th Sep, 2010 at 08:19:33pm
On 30th Sep, 2010 Paul S said:
It will not suddenly start to restrict above a certain flow but the impact will build gradually, getting to a point where it will seem like it has hit a brick wall. This is infact technically called 'Stone wall' in the industry
