| Home > General Chat > Turbo choice | |||||||
![]() 338 Posts Member #: 1911 Senior Member Swindon |
4th Oct, 2010 at 08:48:23pm
Given the choice between what would people recommend? Gt20 or t3. I'm stuck between the two. |
4th Oct, 2010 at 08:51:20pm
GT2056 If something is worth doing, it's worth doing half of. |
4th Oct, 2010 at 09:34:17pm
I'd use the t3...
In the 13's at last!.. Just |
4th Oct, 2010 at 10:17:47pm
Neither. Lots of help this thread.
4th Oct, 2010 at 10:20:17pm
i think the gt20 would win hands down, maybe a little big for lower boost though Yes i moved to the darkside |
4th Oct, 2010 at 10:32:17pm
dont be a pussy quinton get a gt 22 :) do it properly Drives
4th Oct, 2010 at 10:34:55pm
or a ball bearing gt25? Yes i moved to the darkside |
4th Oct, 2010 at 10:38:28pm
No one would be daft enough to stick a gt25 on and expect it to make boost would they? On 28th Aug, 2011 Kean said:
4th Oct, 2010 at 11:14:13pm
Lol. Well I aiming high power with a decent spec. Just my original idea was the t3 but after seeing the gt20 now and how well the gt17 has performed a can only want to follow that. But I'm still do work out what comp to go for with the turbo but with the t3 I was thinking 8:1 comp with high 20's psi but dunno now. Stuck with ideas in what I want to do hence the turbo decision first. |
4th Oct, 2010 at 11:17:32pm
gt17 seems to be the one to have it seems to be the jack of all trades comes on boost low and also gives big power Crystal Sound Audio said:
4th Oct, 2010 at 11:18:58pm
Yea true but if you look at the compression maps for both the 20 and 17 it feels like the 20 can be quite promising aswell or am I wrong? |
4th Oct, 2010 at 11:32:29pm
Do you want more than 230bhp?
4th Oct, 2010 at 11:42:55pm
Yea I'm aiming high :) |
5th Oct, 2010 at 05:39:41am
a gt2052 52 trim will work very well up to 230 bhp wit a bit less flow on the turbine side compared to the gt17, but compensated by a better/stronger spool.
5th Oct, 2010 at 09:56:45am
Thanks for that fab. Think I'm sorted for a decision now. |
5th Oct, 2010 at 01:23:28pm
T3 Best 1/4 mile 13.2 seconds @116 mph
5th Oct, 2010 at 02:14:23pm
What sort of boost is the gt17 having to make (yes i no engine spec needed) to produce the 220/230hp and is that straight out of the box, how strained is theat turbo at that power, is it at its limit so if im on track 5/6 times a year its going to kill it? , do you think( i can sacrifice lag) on a gt2056 it wouldnt be straining as much so would be the better option.
6th Oct, 2010 at 02:08:42am
need one or two bag of boost.. On 5th Oct, 2010 cossierick said:
What sort of boost is the gt17 having to make (yes i no engine spec needed) to produce the 220/230hp and is that straight out of the box, how strained is theat turbo at that power, is it at its limit so if im on track 5/6 times a year its going to kill it? , do you think( i can sacrifice lag) on a gt2056 it wouldnt be straining as much so would be the better option. Rick Sorry if im hijacing it mat help others i hope aswell. |
6th Oct, 2010 at 02:10:32am
forgotten to put the t3 in the battle, a 0.48 a/r one with 50 trim compressor will just push as much air, with more lag |
6th Oct, 2010 at 08:57:40am
6th Oct, 2010 at 09:35:49am
bsfc is the volume of fuel needed to produce X amount of power , it is engine specific, and vary with revs, from around 0.45 lb of fuel per hp at max torque to 0.55/0.60 lb of fuel by hp at peak hp rev.
6th Oct, 2010 at 10:00:44am
On 6th Oct, 2010 wolfie said:
Fab you lost me at "maths" Me too, fab make it simple for us!! i congratulate you for nowing and understanding all tha but am afraid it just makes my head spin, so now nowing all what youv'e said, can we have a very simple answer now.lol rick |
6th Oct, 2010 at 10:17:51am
After your calcs I got 491 cfm roughly. What else what I need to take into consideration. The gt2056 sounds like the turbo for me even though it sounds like that's on it limits. |
6th Oct, 2010 at 10:21:35am
6th Oct, 2010 at 10:29:22am
As i said go for the gt22 Drives
