| Home > Help Needed / General Tech Chat > Engine Rebuild - what parts? | ||||||
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
7th Mar, 2005 at 02:09:00pm
Yo. |
7th Mar, 2005 at 02:11:27pm
Full gasket set
7th Mar, 2005 at 02:12:10pm
Cheers :)
7th Mar, 2005 at 02:15:42pm
go for the avonbar oil pump
7th Mar, 2005 at 02:17:01pm
oh and some new cam followers and a btl of cam lube for the rebuild
7th Mar, 2005 at 02:26:22pm
![]() 2641 Posts Member #: 19 Post Whore newcastle |
7th Mar, 2005 at 05:01:35pm
timing disc
7th Mar, 2005 at 05:38:35pm
Main bearings.
7th Mar, 2005 at 05:47:40pm
Double overhead manifold sproket and flux capacitor.
Edited by T3Tone on 7th Mar, 2005. -MINI CLUBMAN 1380 TURBO- |
7th Mar, 2005 at 06:00:51pm
Thrust washers
7th Mar, 2005 at 06:38:50pm
CRANK ???
7th Mar, 2005 at 06:39:29pm
rod nuts?? Everyone knows that instructions only have to be read if the thing doesn't work....
7th Mar, 2005 at 07:43:49pm
Spark Plugs
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
Site Admin ![]() 1921 Posts Member #: 333 Post Whore Tadley, Hampshire |
7th Mar, 2005 at 08:36:18pm
Ouch, thanks for all the info guys, slightly encouraging the bits that we do have, but I haven't even heard of some of those parts! And I'm not a complete amateur/girl (read that as you will)! |
7th Mar, 2005 at 08:54:46pm
Tom F:
7th Mar, 2005 at 08:56:50pm
no Everyone knows that instructions only have to be read if the thing doesn't work....
7th Mar, 2005 at 08:58:48pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...ssPageName=WD1V
7th Mar, 2005 at 08:59:37pm
Way wrong then, thank you! |
7th Mar, 2005 at 09:02:49pm
Yes 4 off like mark says. Two of them have a lug on them in the centre of the radius pointing outwards. That locates in a cutout in the bearing cap. When you dismantle your engine you will easily spot them, they control the endfloat of the crank which needs to be checked using feeler gauges and adjusted to get it within spec limits.
Edited by Tom Fenton on 7th Mar, 2005.
7th Mar, 2005 at 09:06:04pm
note to self ......
7th Mar, 2005 at 09:22:08pm
that's correct. Steel to the block, copper to the crank.
7th Mar, 2005 at 09:32:22pm
Imperial tap set to 'chase' out all the threads in the block.
7th Mar, 2005 at 09:54:23pm
Some good info here (even if i say so myself!)
7th Mar, 2005 at 10:55:13pm
Jon's helping US* build it (if he's still up for it!!) - so I think he may already have most of the tools needed? :)
Edited by Nicky on 7th Mar, 2005. |
7th Mar, 2005 at 11:46:48pm
I find test tube bottle brushes are good for cleaning the galleries out with, if you know someone that works in a lab easy to get hold of as well.
