| Home > Help Needed / General Tech Chat > Bonnet fit problem - picture heavy | |||||||
![]() 428 Posts Member #: 39 Senior Member Bristol |
18th Jan, 2011 at 10:03:28pm
The bonnet I used for the van when fitting all the new panels turned out to be badly rippled. Under advice from the sprayer I bought a brand new Heritage bonnet and I am have fitting issues....
Edited by Monster22 on 18th Jan, 2011. |
18th Jan, 2011 at 10:48:04pm
was your old bonet a non heritage one?
18th Jan, 2011 at 10:56:14pm
Old - unknown
19th Jan, 2011 at 12:17:28am
Its pretty normal that TBH.
19th Jan, 2011 at 06:30:55am
Ive seen this many times. Basically the top of the front panel is in too far and needs pulling outward/forward, this will bring the wing tops down to meet your bonnet aswell as lining up with the front edge of the bonnet. Unfortunately though you would have to release to front panel from the inner wings and reweld it
I seriously doubt it! |
19th Jan, 2011 at 09:34:22am
Thanks guys. What do you think of my plan with bending the bonnet corners in and then welding additional metal onto the bonnet?
Edited by Monster22 on 19th Jan, 2011. |
19th Jan, 2011 at 09:42:50am
yes, seen these issue in the past. I know you used a damaged one for the build up but have you tried a good second hand one on it to see how it fits? I've had similar issues in the past with other panels and it ended up being a bit of mix and match to get the closest match before modding.
19th Jan, 2011 at 11:03:05am
shells fully painted and back at home |
19th Jan, 2011 at 11:29:10am
I would get the bonnet that does fit repaired and painted.
19th Jan, 2011 at 11:51:08am
That was my thought too.
On 19th Jan, 2011 Tom Fenton said:
I would get the bonnet that does fit repaired and painted. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
19th Jan, 2011 at 04:49:53pm
Im sure if you go to a sheetmetal fabrication shop they will have a crimper, they will be able to crimp the edges of the bonnet to bring it in a bit, which will help the sticking out forward part, like you say.
Edited by Johnny on 19th Jan, 2011. |
19th Jan, 2011 at 10:16:51pm
Will have a think and speak to the painter about the rippled bonnet. Cheers |
19th Jan, 2011 at 10:48:24pm
Where does the back edge of the bonnet sit in relation to the wings? Is it too low aswell?
20th Jan, 2011 at 10:19:03am
i set the rear of the bonnet so it sits at the right height and the right distance from the scuttle. I think the front corners will bend in.
20th Jan, 2011 at 11:16:48am
Have you thought about trying a fg one on to see how that fits?? Edited by MikeRace on 20th Jan, 2011. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Jan, 2011 at 11:29:59am
That's a fair point. you can get ready to fit ones and put them on the hinges etc, might be flexible enough to pull it all ino line On 11th Feb, 2015 robert said:
20th Jan, 2011 at 11:32:42am
Yep, or you ask the kind folks at tdk not to trim off your edges and you could do it yourself and make it custom fit? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Jan, 2011 at 01:27:27pm
Not touched Glassfibre before so you have to trim it to fit do you? these aren't the strengthening bends at the edges as on steel bonnets? Suppose being GRP you just make it thicker. Am I thinking correctly? |
20th Jan, 2011 at 01:56:28pm
With GRP bonnets you dont usually have any trimming to do, however when it comes out of the mould there is a couple inches of excess that has to be trimmed. Basically if the edges were left you could cut them yourself to suit?
20th Jan, 2011 at 05:19:14pm
the excess on the front of the bonnet would be in towards the engine though, not down towards the grille... |
20th Jan, 2011 at 10:51:21pm
Ive got a decent second hand one you could try out. It will need the lower lip cutting off mind. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st Jan, 2011 at 08:39:41am
thanks for offer Matty, just googled where you are 2hrs 8mins |
21st Jan, 2011 at 11:47:06am
Not true fb bonnets excess actually down and outwards.
On 20th Jan, 2011 miniminor63 said:
the excess on the front of the bonnet would be in towards the engine though, not down towards the grille... 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
21st Jan, 2011 at 06:22:19pm
On 21st Jan, 2011 Monster22 said:
thanks for offer Matty, just googled where you are 2hrs 8mins ( . think operation hack the old rippled bonnet will sartat the weekend. wil post on progress.
I'd like steel tbh wrt GRP, plus the sprayer whos fully paid up by the way doesn't like it. M Im going to Bingley if thats any use? I may also be able to get a colleague to pick it up from the office next week and bring it home with him, he lives in Hanham. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st Jan, 2011 at 08:23:27pm
thats very decent of you thanks. I think though that even another may have the same issue 10mm is alot to find. I'll give the cut a s.ut a go. will post a picture, |
